Hi Everyone!
I have a problem after update Ubuntu to version 24.10, My nvidia-driver-565-open can not be loaded. Looks like is installed but when I call nvidia-smi it shows a message : NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
similar with nvidia-settings, the message is : ERROR: NVIDIA driver is not loaded
(nvidia-settings:10171): GLib-GObject-CRITICAL **: 14:11:14.584: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
** (nvidia-settings:10171): CRITICAL **: 14:11:14.586: ctk_powermode_new: assertion ‘(ctrl_target != NULL) && (ctrl_target->h != NULL)’ failed
ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at
/usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated,
and will not be listed in the help text. Please see the README for possible values and descriptions.
Before update from Ubuntu 24.04 LTS everything worked fine.
Now I’m running on AMD Radeon™ 610M integrated, but I can’t use external monitor…
Please, help!
Thanks in advance and regards!
