Latest Ubuntu 20.04, RTX3060 video card. Driver doesn’t load. I used the drivers from the ppa repo. Here are some logs from syslog:
May 7 17:51:02 silviu-linux kernel: [ 3.734022] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
May 7 17:51:02 silviu-linux kernel: [ 3.734685] NVRM: request_mem_region failed for 0M @ 0x0. This can
May 7 17:51:02 silviu-linux kernel: [ 3.734685] NVRM: occur when a driver such as rivatv is loaded and claims
May 7 17:51:02 silviu-linux kernel: [ 3.734685] NVRM: ownership of the device’s registers.
May 7 17:51:02 silviu-linux kernel: [ 3.734689] nvidia: probe of 0000:01:00.0 failed with error -1
May 7 17:51:02 silviu-linux kernel: [ 3.734704] NVRM: The NVIDIA probe routine failed for 1 device(s).
May 7 17:51:02 silviu-linux kernel: [ 3.734705] NVRM: None of the NVIDIA devices were initialized.
May 7 17:51:02 silviu-linux kernel: [ 3.734810] nvidia-nvlink: Unregistered the Nvlink Core, major device number 234
May 7 17:51:02 silviu-linux systemd-udevd[386]: nvidia: Process ‘/sbin/modprobe nvidia-modeset’ failed with exit code 1.
May 7 17:51:02 silviu-linux kernel: [ 3.872978] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
May 7 17:51:02 silviu-linux kernel: [ 3.873536] NVRM: request_mem_region failed for 0M @ 0x0. This can
May 7 17:51:02 silviu-linux kernel: [ 3.873536] NVRM: occur when a driver such as rivatv is loaded and claims
May 7 17:51:02 silviu-linux kernel: [ 3.873536] NVRM: ownership of the device’s registers.
May 7 17:51:02 silviu-linux kernel: [ 3.873539] nvidia: probe of 0000:01:00.0 failed with error -1
May 7 17:51:02 silviu-linux kernel: [ 3.873554] NVRM: The NVIDIA probe routine failed for 1 device(s).
May 7 17:51:02 silviu-linux kernel: [ 3.873554] NVRM: None of the NVIDIA devices were initialized.
May 7 17:51:02 silviu-linux kernel: [ 3.873661] nvidia-nvlink: Unregistered the Nvlink Core, major device number 234nvidia-bug-report.log.gz (682.8 KB)
Bios bug on all recent MSI notebooks. Please set kernel parameter
pci=realloc
Worked perfectly. Thank you.
How did you set the kernel parameter to that?
In debian/ubuntu you edit the file /etc/default/grub.
Use either of those variables: GRUB_CMDLINE_LINUX_DEFAULT, or GRUB_CMDLINE_LINUX.
Then run sudo update-grub - reboot.
For a one-shot testing you can select your kernel version and press “e” in the grub menu at boot time and edit the parameters for just that one particular boot.
