ello, i Can’t get Nvidia 3060 hardware to work
nvidia-bug-report.log.gz (453.1 KB)
my systemlog:
2/16/25 1:41 PM kernel NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
NVRM: BAR0 is 0M @ 0x0 (PCI:0000:01:00.0)
2/16/25 1:41 PM kernel nvidia: probe of 0000:01:00.0 failed with error -1
2/16/25 1:41 PM kernel NVRM: The NVIDIA probe routine failed for 1 device(s).
2/16/25 1:41 PM kernel NVRM: None of the NVIDIA devices were initialized.
2/16/25 1:41 PM kernel nvidia-nvlink: Unregistered Nvlink Core, major device number 510
2/16/25 1:41 PM (udev-worker) nvidia: Process ‘/sbin/modprobe nvidia-uvm’ failed with exit code 1.
my lspci -k:
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GA106M [GeForce RTX 3060 Mobile / Max-Q]
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
please help me
my nvidia-smi:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
if start of console nvidia-settings:
RROR: NVIDIA driver is not loaded
(nvidia-settings:27805): GLib-GObject-CRITICAL **: 13:45:10.837: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
** (nvidia-settings:27805): CRITICAL **: 13:45:10.847: ctk_powermode_new: assertion ‘(ctrl_target != NULL) && (ctrl_target->h != NULL)’ failed
ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at /usr/share/nvidia/nvidia-application-profiles-key-documentation. The
application profiles will continue to work, but values cannot be prepopulated or validated, and will not be listed in the help text. Please see the README for possible values and descriptions.
** Message: 13:45:10.945: PRIME: Requires offloading
** Message: 13:45:10.945: PRIME: is it supported? yes
** Message: 13:45:10.979: PRIME: Usage: /usr/bin/prime-select nvidia|intel|on-demand|query
** Message: 13:45:10.979: PRIME: on-demand mode: “1”
** Message: 13:45:10.979: PRIME: is “on-demand” mode supported? yes
