I have an HP Envy DV7 7212 with the GeForce GT 650M. I dual boot Windows 8 and Linux 12.10, Quantal. The video hardware operates properly under Windows 8. The Linux drivers are not loaded by the time that I try to login to X.
I get what looks like a safe X boot screen at 600x800 resolution
nvidia-bug-report.log.tar.gz is the nvidia-bug-report log
nvidia-debugdump--dumpall--device_0.zip is the result of nvidia --debug-dump --dump-all --device 0 --file
nvidia-installer.log is the install log created from running the 313.18 installer
kern.log is a kern.log entry from the relevant boot sequence
Xorg.0.log is also attached. It shows some errors claiming
[ 24.355] Initializing built-in extension DRI2
[ 24.355] (II) LoadModule: "glx"
[ 24.593] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 26.822] (II) Module glx: vendor="NVIDIA Corporation"
[ 26.822] compiled for 4.0.2, module version = 1.0.0
[ 26.822] Module class: X.Org Server Extension
[ 26.822] (II) NVIDIA GLX Module 313.18 Wed Jan 9 15:34:35 PST 2013
[ 26.845] Loading extension GLX
[ 26.845] (II) LoadModule: "nvidia"
[ 26.845] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 27.003] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 27.003] compiled for 4.0.2, module version = 1.0.0
[ 27.003] Module class: X.Org Video Driver
[ 27.060] (II) NVIDIA dlloader X Driver 313.18 Wed Jan 9 15:15:26 PST 2013
[ 27.060] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 27.076] (++) using VT number 7
[ 27.076] (EE) No devices detected.
[ 28.531] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
The system is running
Linux TheTurk 3.7.0-030700-generic #201212102335 SMP Tue Dec 11 04:36:24 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
lsb_release produces the following output
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 12.10
Release: 12.10
Codename: quantal
Using the nvidia-debugdump tool to list graphics devices I receive the following output
Hi Birdie, thanks for the quick response. You can see the full output of lsmod attached. Neither nouveau, nor nvidiafb is loaded.
I have the blacklist entry under /etc/modprobe.d for nouveau
I do not have the blacklist entry under /etc/modprobe.d for nvidiafb
However, neither module is loaded and so the recommendation is moot. If I’m mistaken, please let me know. lsmod.log (3.08 KB)
Hi Bridie,
I just wanted to update that I have the system up and running now. I installed bumblebee using their ubuntu installation instructions, then used “Additional Drivers”, aka, jockey-text to specify the Nvidia_313 driver. This all came together really nicely and I have a running Ubuntu 12.10 Quantal installation with the Nvidia proprietary drivers operating.
glxspheres ~= 60 FPS
optirun glxspheres ~= 120 FPS
