I’m using archlinux on a clevo W350T Laptop, with a Geforce 660M.
Since kernel 3.13 I have troubles running programs using the nvidia card with optimus/bumblebee. Everything on my machine is up to date and it used to work before the kernel/driver update. I’m now using the last released driver (334.21).
I try the following in a terminal, and I get an error.
$ optirun glxgears
[ 143.680] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA GPU at PCI:1:0:0. Please
[ 143.680] [ERROR]Aborting because fallback start is disabled.
The Xorg.conf has the following concerning the nvidia card :
[ 143.680] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA GPU at PCI:1:0:0. Please
[ 143.680] (EE) NVIDIA(GPU-0): check your system's kernel log for additional error
[ 143.680] (EE) NVIDIA(GPU-0): messages and refer to Chapter 8: Common Problems in the
[ 143.680] (EE) NVIDIA(GPU-0): README for additional information.
[ 143.680] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 143.680] (EE) NVIDIA(0): Failing initialization of X screen 0
and here what I found in dmesg :
[ 132.329828] bbswitch: enabling discrete graphics
[ 134.207859] nvidia: module license 'NVIDIA' taints kernel.
[ 134.207863] Disabling lock debugging due to kernel taint
[ 134.213628] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 134.214133] [drm] Initialized nvidia-drm 0.0.0 20130102 for 0000:01:00.0 on minor 1
[ 134.214139] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 334.21 Thu Feb 27 15:55:45 PST 2014
[ 134.409222] nvidia 0000:01:00.0: irq 49 for MSI/MSI-X
[ 134.416229] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 134.416283] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 134.416313] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 134.416340] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 134.416367] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 134.416393] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 134.416435] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 134.416462] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 139.568317] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131115/nsarguments-95)
[ 143.840959] NVRM: RmInitAdapter failed! (0x25:0x28:1155)
[ 143.840967] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 143.840994] NVRM: nvidia_frontend_open: minor 0, module->open() failed, error -5
It looks like other people have this issue, unsolved, still I have not found any traces of that issue on that forum so I am reporting this.
I though at first it was related to the vbios problem debated here or here but the dmesg is not mentionning it.
Any idea ?
Best,
Paul
nvidia-bug-report.log.gz (62.4 KB)
