I run OpenSuSE Tumbleweed on my Lenovo T530.
I’m currently attempting to test the 352.09 Driver (I like to test out beta drivers)
The Driver builds correctly and installs without issue.
When attempting to start X it appears the kernel module runs into an issue.
[ 69.123410] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 0
[ 69.123415] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 352.09 Tue May 12 14:47:49 PDT 2015
[ 69.125106] nvidia_uvm: Loaded the UVM driver, major device number 245
[ 69.127896] nvidia_uvm: Unregistered the UVM driver
[ 99.290118] ACPI Warning: _SB_.PCI0.PEG_.VID_.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20150410/nsarguments-95)
[ 99.290325] ACPI Warning: _SB.PCI0.PEG_.VID_.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20150410/nsarguments-95)
[ 99.290506] ACPI Warning: _SB.PCI0.PEG_.VID_.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20150410/nsarguments-95)
[ 99.290671] ACPI Warning: _SB.PCI0.PEG_.VID_.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20150410/nsarguments-95)
[ 99.290827] ACPI Warning: _SB.PCI0.PEG_.VID_.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20150410/nsarguments-95)
[ 99.291408] ACPI Warning: _SB.PCI0.PEG_.VID_.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20150410/nsarguments-95)
[ 99.291955] ACPI Warning: _SB.PCI0.PEG_.VID_.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20150410/nsarguments-95)
[ 99.292116] ACPI Warning: _SB.PCI0.PEG_.VID_.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20150410/nsarguments-95)
[ 99.362885] ACPI Warning: _SB.PCI0.PEG_.VID_._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20150410/nsarguments-95)
[ 99.367303] NVRM: RmInitAdapter failed! (0x2c:0x59:1340)
[ 99.367312] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 99.367332] NVRM: nvidia_frontend_open: minor 0, module->open() failed, error -5
This does not happen with the 349.16 driver.
I will attach an nvidia-bug-report.log.gz.
This was generated on my laptop after installing 352.09 attempting to start X and having it fail. Then installing 349.16 and having it work. So the dmesg output covers both drivers… I will also include my Xorg.0.log.old file which has the Xorg start attempt that failed with 352.09 as the one in the nvidia-bug-report.log.gz does not include that information.
nvidia-bug-report.log.gz (99.5 KB)
Xorg.0.log.old.gz (2.03 KB)
