Hardware is Dell Precision Mobile 5540.
Same exact configuration works with 520.56.06.
520.56.06:
Jan 17 06:19:24 hostname kernel: Command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-6.1.6-200.fc37.x86_64 root=/dev/mapper/blivet-root ro rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia.modeset=1
Jan 17 06:19:24 hostname kernel: Kernel command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-6.1.6-200.fc37.x86_64 root=/dev/mapper/blivet-root ro rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia.modeset=1
Jan 17 06:19:24 hostname kernel: ACPI: bus type drm_connector registered
Jan 17 06:19:24 hostname kernel: [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
Jan 17 06:19:24 hostname kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Jan 17 06:19:26 hostname kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
Jan 17 06:19:26 hostname kernel: i915 0000:00:02.0: [drm] GuC firmware i915/kbl_guc_70.1.1.bin version 70.1.1
Jan 17 06:19:26 hostname kernel: i915 0000:00:02.0: [drm] HuC firmware i915/kbl_huc_4.0.0.bin version 4.0.0
Jan 17 06:19:26 hostname kernel: i915 0000:00:02.0: [drm] HuC authenticated
Jan 17 06:19:26 hostname kernel: i915 0000:00:02.0: [drm] GuC submission disabled
Jan 17 06:19:26 hostname kernel: i915 0000:00:02.0: [drm] GuC SLPC disabled
Jan 17 06:19:27 hostname kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
Jan 17 06:19:27 hostname kernel: fbcon: i915drmfb (fb0) is primary device
Jan 17 06:19:27 hostname kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Jan 17 06:19:29 hostname systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
Jan 17 06:19:33 hostname kernel: nvidia: module license 'NVIDIA' taints kernel.
Jan 17 06:19:33 hostname kernel: nvidia: unknown parameter 'modeset' ignored
Jan 17 06:19:33 hostname kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 510
Jan 17 06:19:33 hostname kernel: nvidia 0000:01:00.0: enabling device (0000 -> 0003)
Jan 17 06:19:33 hostname kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 520.56.06 Thu Oct 6 21:38:55 UTC 2022
Jan 17 06:19:33 hostname kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Jan 17 06:19:33 hostname kernel: nvidia-uvm: Loaded the UVM driver, major device number 508.
Jan 17 06:19:35 hostname kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 520.56.06 Thu Oct 6 21:22:53 UTC 2022
Jan 17 06:19:35 hostname kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Jan 17 06:19:35 hostname kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
525.78.01:
Jan 17 13:37:35 hostname kernel: Command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-6.1.6-200.fc37.x86_64 root=/dev/mapper/blivet-root ro rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia.modeset=1
Jan 17 13:37:35 hostname kernel: Kernel command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-6.1.6-200.fc37.x86_64 root=/dev/mapper/blivet-root ro rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia.modeset=1
Jan 17 13:37:35 hostname kernel: ACPI: bus type drm_connector registered
Jan 17 13:37:35 hostname kernel: [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
Jan 17 13:37:35 hostname kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Jan 17 13:37:36 hostname kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
Jan 17 13:37:36 hostname kernel: i915 0000:00:02.0: [drm] GuC firmware i915/kbl_guc_70.1.1.bin version 70.1.1
Jan 17 13:37:36 hostname kernel: i915 0000:00:02.0: [drm] HuC firmware i915/kbl_huc_4.0.0.bin version 4.0.0
Jan 17 13:37:36 hostname kernel: i915 0000:00:02.0: [drm] HuC authenticated
Jan 17 13:37:36 hostname kernel: i915 0000:00:02.0: [drm] GuC submission disabled
Jan 17 13:37:36 hostname kernel: i915 0000:00:02.0: [drm] GuC SLPC disabled
Jan 17 13:37:37 hostname kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
Jan 17 13:37:37 hostname kernel: fbcon: i915drmfb (fb0) is primary device
Jan 17 13:37:37 hostname kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Jan 17 13:37:39 hostname systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
Jan 17 13:37:42 hostname kernel: nvidia: module license 'NVIDIA' taints kernel.
Jan 17 13:37:42 hostname kernel: nvidia: unknown parameter 'modeset' ignored
Jan 17 13:37:42 hostname kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 510
Jan 17 13:37:42 hostname kernel: nvidia 0000:01:00.0: enabling device (0000 -> 0003)
Jan 17 13:37:42 hostname kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.78.01 Mon Dec 26 05:58:42 UTC 2022
Jan 17 13:37:42 hostname kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Jan 17 13:37:42 hostname kernel: nvidia-uvm: Loaded the UVM driver, major device number 508.
Jan 17 13:37:42 hostname kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 525.78.01 Mon Dec 26 05:38:56 UTC 2022
Jan 17 13:37:42 hostname kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Jan 17 13:37:44 hostname kernel: NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x40:1423)
Jan 17 13:37:44 hostname kernel: NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
Jan 17 13:37:44 hostname kernel: [drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NvKmsKapiDevice
Jan 17 13:37:44 hostname kernel: [drm:nv_drm_probe_devices [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to register device
Jan 17 13:37:48 hostname kernel: NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x62:0x65:2366)
Jan 17 13:37:48 hostname kernel: NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
