Nvidia drivers failing to initialise using a new 4070Ti on 525.85.05 drivers on linux61:
[ +0.047971] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.85.05 Sat Jan 14 00:49:50 UTC 2023
[ +0.012568] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 525.85.05 Sat Jan 14 00:40:03 UTC 2023
[ +0.009419] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ +0.048740] nvidia-uvm: Loaded the UVM driver, major device number 235.
[ +0.001700] [drm] [nvidia-drm] [GPU ID 0x00000400] Loading driver
[ +1.373248] NVRM: GPU 0000:04:00.0: RmInitAdapter failed! (0x26:0x56:1469)
[ +0.000235] NVRM: GPU 0000:04:00.0: rm_init_adapter failed, device minor number 0
[ +0.000097] [drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000400] Failed to allocate NvKmsKapiDevice
[ +0.000163] [drm:nv_drm_probe_devices [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000400] Failed to register device
Unfortunately downgrading drivers is not an option as legacy drivers would not have support for the 4070Ti.
