The driver is not installed. 352.30 and 346.87
I deleted the “blacklist nvidia” in modprobe.d from bumblebee file.
Earlier, I used the advice to resolve the error, it did not help. -https://devtalk.nvidia.com/default/topic/838768/linux/problems-with-geforce-gtx-980-on-asustek-g20aj/post/4571775/#4571775.
nvidia-bug-report.sh not working(freezes\hangs\crashes). Log not found.
ERROR: Unable to load the kernel module.
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun Aug 9 03:23:15 2015
installer version: 352.30
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/VirtualGL/bin:/usr/local/cuda-7.0/bin
nvidia-installer command line:
./nvidia-installer
--dkms
-Z
Using: nvidia-installer ncurses user interface
-> Detected 4 CPUs online; setting concurrency level to 4.
WARNING: You do not appear to have an NVIDIA GPU supported by the 352.30 NVIDIA Linux graphics driver installed in this system. For further details, please see the appendix SUPPORTED NVIDIA GRAPHICS CHIPS in the README available on the Linux driver download page at www.nvidia.com.
-> License accepted.
-> Installing NVIDIA driver version 352.30.
-> There appears to already be a driver installed on your system (version: 346.82). As part of installing this driver (version: 352.30), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be sure you have rebooted your system since these files were written. If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file. Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to correctly disable the Nouveau kernel driver.
-> For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
-> One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to reenable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Installing both new and classic TLS OpenGL libraries.
-> Installing classic TLS 32bit OpenGL libraries.
WARNING: Unable to find a suitable destination to install 32-bit compatibility libraries. Your system may not be set up for 32-bit compatibility. 32-bit compatibility files will not be installed; if you wish to install them, re-run the installation and set a valid directory with the --compat32-libdir option.
-> Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
-> nvidia-installer will install the libvdpau and libvdpau_trace libraries that were included with this installer package. These libraries are available separately through the libvdpau project and will be removed from the NVIDIA Linux driver installer package in the future, so it is recommended that VDPAU users install libvdpau separately, e.g. by using packages available from their distributions, or by building from the sources available at:
http://people.freedesktop.org/~aplattner/vdpau
-> Searching for conflicting files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (352.30):
executing: '/sbin/ldconfig'...
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
-> done.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
“modprobe nvidia”:
[ 1370.671985] ------------[ cut here ]------------
[ 1370.671997] WARNING: CPU: 2 PID: 7641 at /build/linux-H6_NPX/linux-3.18.6/fs/proc/generic.c:315 proc_register+0xd8/0x170()
[ 1370.671999] proc_dir_entry 'driver/nvidia' already registered
[ 1370.672000] Modules linked in: nvidia(PO+) xt_TCPMSS xt_tcpmss xt_tcpudp iptable_mangle ip_tables x_tables pppoe pppox nfnetlink_log bbswitch(O) nfnetlink binfmt_misc ppp_generic slhc loop dm_crypt joydev arc4 ath9k i915 ath9k_common ath9k_hw snd_hda_codec_hdmi snd_hda_codec_realtek ath mac80211 cfg80211 acer_wmi drm_kms_helper snd_hda_codec_generic sparse_keymap psmouse intel_powerclamp i2c_algo_bit rfkill iTCO_wdt snd_hda_intel snd_hda_controller drm i2c_i801 snd_hda_codec i2c_core evdev serio_raw iTCO_vendor_support lpc_ich mfd_core snd_hwdep snd_pcm snd_timer snd mei_me mei coretemp soundcore intel_ips mxm_wmi kvm_intel kvm battery ac wmi video acpi_cpufreq processor thermal_sys button ext4 crc16 mbcache jbd2 dm_mod sg sr_mod cdrom sd_mod hid_generic ata_generic usbhid hid broadcom ata_piix ehci_pci ehci_hcd crc32c_intel tg3 ptp pps_core libphy libata scsi_mod usbcore usb_common [last unloaded: nvidia]
[ 1370.672065] CPU: 2 PID: 7641 Comm: modprobe Tainted: P W O 3.18.0-kali3-amd64 #1 Debian 3.18.6-1~kali2
[ 1370.672067] Hardware name: Acer Aspire 5742G/Aspire 5742G, BIOS V1.30 08/13/2012
[ 1370.672069] 0000000000000000 0000000000000009 ffffffff81554a5e ffff88008e0d3bb8
[ 1370.672072] ffffffff8106db8b ffff8801d42f3340 ffff8801d42f3e35 ffff8801d42f3dc0
[ 1370.672074] ffff8801d4ce8e40 0000000000000000 ffffffff8106dc7a ffffffff81733338
[ 1370.672077] Call Trace:
[ 1370.672086] [<ffffffff81554a5e>] ? dump_stack+0x41/0x51
[ 1370.672093] [<ffffffff8106db8b>] ? warn_slowpath_common+0x8b/0xc0
[ 1370.672095] [<ffffffff8106dc7a>] ? warn_slowpath_fmt+0x4a/0x50
[ 1370.672098] [<ffffffff81228e28>] ? proc_register+0xd8/0x170
[ 1370.672101] [<ffffffff81228fd0>] ? proc_mkdir_data+0x50/0x70
[ 1370.672194] [<ffffffffa0c0d6ab>] ? nv_register_procfs+0x5b/0x210 [nvidia]
[ 1370.672250] [<ffffffffa17a336d>] ? nvidia_init_module+0x2bb/0x709 [nvidia]
[ 1370.672258] [<ffffffffa17a3000>] ? 0xffffffffa17a3000
[ 1370.672301] [<ffffffffa17a3082>] ? nvidia_frontend_init_module+0x82/0xb2 [nvidia]
[ 1370.672306] [<ffffffff81002158>] ? do_one_initcall+0xd8/0x210
[ 1370.672311] [<ffffffff810e77e5>] ? load_module+0x1ce5/0x2660
[ 1370.672314] [<ffffffff810e35a0>] ? unset_module_core_ro_nx+0x80/0x80
[ 1370.672318] [<ffffffff8118d516>] ? vmap_page_range_noflush+0x256/0x370
[ 1370.672321] [<ffffffff810e8224>] ? SyS_init_module+0xc4/0x110
[ 1370.672326] [<ffffffff8155a9ed>] ? system_call_fast_compare_end+0xc/0x11
[ 1370.672327] ---[ end trace 748a9d8cb660179e ]---
[ 1370.672373] NVRM: This is a 64-bit BAR mapped above 4GB by the system
[ 1370.672373] NVRM: BIOS or the Linux kernel, but the PCI bridge
[ 1370.672373] NVRM: immediately upstream of this GPU does not define
[ 1370.672373] NVRM: a matching prefetchable memory window.
[ 1370.672376] NVRM: This may be due to a known Linux kernel bug. Please
[ 1370.672376] NVRM: see the README section on 64-bit BARs for additional
[ 1370.672376] NVRM: information.
[ 1370.672382] nvidia: probe of 0000:01:00.0 failed with error -1
[ 1370.672421] Error: Driver 'nvlink' is already registered, aborting...
[ 1370.672690] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 1370.672693] NVRM: None of the NVIDIA graphics adapters were initialized!
[ 1370.672695] [drm] Module unloaded
[ 1370.672866] NVRM: NVIDIA init module failed!
ERROR: could not insert 'nvidia': No such device
uname -a
Linux kali 3.18.0-kali3-amd64 #1 SMP Debian 3.18.6-1~kali2 (2015-03-02) x86_64 GNU/Linux
dmesg | grep nvidia
[ 8.289329] nvidia: module license 'NVIDIA' taints kernel.
[ 8.299501] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 8.300068] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 1
[ 309.361991] nvidia: probe of 0000:01:00.0 failed with error -1
[ 391.639046] proc_dir_entry 'driver/nvidia' already registered
[ 391.640515] Modules linked in: nvidia(PO+) xt_TCPMSS xt_tcpmss xt_tcpudp iptable_mangle ip_tables x_tables pppoe pppox nfnetlink_log bbswitch(O) nfnetlink binfmt_misc ppp_generic slhc loop dm_crypt joydev arc4 ath9k i915 ath9k_common ath9k_hw snd_hda_codec_hdmi snd_hda_codec_realtek ath mac80211 cfg80211 acer_wmi drm_kms_helper snd_hda_codec_generic sparse_keymap psmouse intel_powerclamp i2c_algo_bit rfkill iTCO_wdt snd_hda_intel snd_hda_controller drm i2c_i801 snd_hda_codec i2c_core evdev serio_raw iTCO_vendor_support lpc_ich mfd_core snd_hwdep snd_pcm snd_timer snd mei_me mei coretemp soundcore intel_ips mxm_wmi kvm_intel kvm battery ac wmi video acpi_cpufreq processor thermal_sys button ext4 crc16 mbcache jbd2 dm_mod sg sr_mod cdrom sd_mod hid_generic ata_generic usbhid hid broadcom ata_piix ehci_pci ehci_hcd crc32c_intel tg3 ptp pps_core libphy libata scsi_mod usbcore usb_common [last unloaded: nvidia]
[ 391.670790] [<ffffffffa14366ab>] ? nv_register_procfs+0x5b/0x210 [nvidia]
[ 391.672645] [<ffffffffa17a336d>] ? nvidia_init_module+0x2bb/0x709 [nvidia]
[ 391.676340] [<ffffffffa17a3082>] ? nvidia_frontend_init_module+0x82/0xb2 [nvidia]
[ 391.717557] nvidia: probe of 0000:01:00.0 failed with error -1
notebook Acer ASPIRE 5742G-386G32Mnkk (Core i3 380M 2530 Mhz/15.6"/1366x768/6144Mb/320Gb/DVD-RW/Wi-Fi/Win 7 HB)
video NVIDIA GeForce 610M 1024 Мб GDDR3
please help me!
