I seem to have run into an issue with Nvidia T550 mobile graphics card, using the 525.147.05 driver version, and running in Debian 12 on kernel 6.1.0-18-amd64: the gpu does not want to enter the suspended runetime state (cat /sys/bus/pci/devices/0000:03:00.0/power/runtime_status always returns active) even if there is no process running on the gpu at all and the gpu is in performance state P8.
I have attached the nvidia-smi output here:
| NVIDIA-SMI 525.147.05 Driver Version: 525.147.05 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA T550 Lap... On | 00000000:03:00.0 Off | N/A |
| N/A 43C P8 1W / 25W | 0MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
I have tried multiple potential solutions, including modifying the /etc/modprobe.d/nvidia.conf file by appending
options nvidia "NVreg_DynamicPowerManagement=0x02"
with little effect.
Perhaps a process is preventing the gpu to enter the suspended state? I have tried turning off the persistence mode however, after doing so, powertop reports an increase in power usage. Additionally, even with the persistence mode turned off (nvidia-smi -pm 0) the runetime_status still reads as active even after a couple of minutes.
Executing sudo fuser -v /dev/nvidia*
returns no process id with persistence disabled, so I am not sure why the gpu is not entering a suspended mode.
Any suggestions are very much appreciated!
