I’m trying to get my old GTX 1080 up and running on Debian 13, fresh install, with the proprietary 580 drivers (last version that supports it) for use with headless CUDA for local Ollama execution.
I did manage to get it working, but then rebooted, and now even after purging drivers, reinstalling drivers, etc, I keep getting this:
[ 4.863289] nvidia: loading out-of-tree module taints kernel.
[ 4.863301] nvidia: module license 'NVIDIA' taints kernel.
[ 4.863302] Disabling lock debugging due to kernel taint
[ 4.863306] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 4.863308] nvidia: module license taints kernel.
[ 5.495070] nvidia-nvlink: Nvlink Core is being initialized, major device number 243
[ 5.504807] nvidia 0000:00:0c.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[ 5.621660] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 580.105.08 Wed Oct 29 23:15:11 UTC 2025
[ 5.684392] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 5.703219] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 580.105.08 Wed Oct 29 22:15:26 UTC 2025
[ 5.886821] NVRM: GPU 0000:00:0c.0: RmInitAdapter failed! (0x23:0xffff:1574)
[ 5.886837] NVRM: GPU 0000:00:0c.0: rm_init_adapter failed, device minor number 0
[ 5.897322] NVRM: GPU 0000:00:0c.0: RmInitAdapter failed! (0x23:0xffff:1574)
[ 5.897330] NVRM: GPU 0000:00:0c.0: rm_init_adapter failed, device minor number 0
[ 6.371431] NVRM: GPU 0000:00:0c.0: RmInitAdapter failed! (0x23:0xffff:1574)
[ 6.371437] NVRM: GPU 0000:00:0c.0: rm_init_adapter failed, device minor number 0
[ 6.371509] [drm] [nvidia-drm] [GPU ID 0x0000000c] Loading driver
[ 6.378278] NVRM: GPU 0000:00:0c.0: RmInitAdapter failed! (0x23:0xffff:1574)
[ 6.378283] NVRM: GPU 0000:00:0c.0: rm_init_adapter failed, device minor number 0
[ 6.378865] [drm:nv_drm_dev_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x0000000c] Failed to allocate NvKmsKapiDevice
[ 6.385350] NVRM: GPU 0000:00:0c.0: RmInitAdapter failed! (0x23:0xffff:1574)
[ 6.385355] NVRM: GPU 0000:00:0c.0: rm_init_adapter failed, device minor number 0
[ 6.551984] NVRM: GPU 0000:00:0c.0: RmInitAdapter failed! (0x23:0xffff:1574)
[ 6.551991] NVRM: GPU 0000:00:0c.0: rm_init_adapter failed, device minor number 0
[ 6.559040] NVRM: GPU 0000:00:0c.0: RmInitAdapter failed! (0x23:0xffff:1574)
[ 6.559045] NVRM: GPU 0000:00:0c.0: rm_init_adapter failed, device minor number 0
I’m following Debian — NVIDIA Driver Installation Guide instructions, installed these 2 packages nvidia-kernel-dkms nvidia-driver-cuda which then, of course, installed all the dependencies.
Hardware/kernel info
# uname -a
Linux darkllama 6.12.63+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.63-1 (2025-12-30) x86_64 GNU/Linux
# lspci | grep -i nvi
00:0c.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1080] (rev a1)
00:0d.0 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
