Here it is the full debug of labwc:
00:00:00.000 [INFO] [../src/main.c:139] using config dir (/home/attila/.config/labwc)
00:00:00.000 [INFO] [../src/config/session.c:59] read environment file /home/attila/.config/labwc/environment
00:00:00.000 [INFO] [../src/config/rcxml.c:1286] read config file /home/attila/.config/labwc/rc.xml
00:00:00.000 [DEBUG] [../src/config/rcxml.c:1002] Loaded 28 merged mousebinds
00:00:00.000 [INFO] [../src/config/rcxml.c:308] create mousebind for Root
00:00:00.000 [DEBUG] [../src/config/rcxml.c:1068] Replaced 1 keybinds
00:00:00.000 [DEBUG] [../src/config/rcxml.c:1033] Replaced 1 mousebinds
00:00:00.000 [INFO] [../src/config/rcxml.c:1149] load default window switcher fields
00:00:00.000 [DEBUG] [../src/main.c:153] LABWC_PID=88797
00:00:00.000 [INFO] [libseat] [libseat/backend/seatd.c:64] Could not connect to socket /run/seatd.sock: File o directory non esistente
00:00:00.000 [INFO] [libseat] [libseat/libseat.c:76] Backend 'seatd' failed to open seat, skipping
00:00:00.016 [INFO] [libseat] [libseat/libseat.c:73] Seat opened with backend 'logind'
00:00:00.016 [INFO] [backend/session/session.c:109] Successfully loaded libseat session
00:00:00.019 [INFO] [backend/backend.c:220] Found 1 GPUs
00:00:00.019 [INFO] [backend/drm/backend.c:200] Initializing DRM backend for /dev/dri/card0 (nvidia-drm)
00:00:00.019 [DEBUG] [backend/drm/drm.c:88] Using atomic DRM interface
00:00:00.019 [INFO] [util/env.c:9] Loading WLR_DRM_NO_MODIFIERS option: 1
00:00:00.019 [DEBUG] [backend/drm/drm.c:96] WLR_DRM_NO_MODIFIERS set, disabling modifiers
00:00:00.019 [INFO] [backend/drm/drm.c:253] Found 4 DRM CRTCs
00:00:00.019 [INFO] [backend/drm/drm.c:180] Found 12 DRM planes
00:00:00.025 [INFO] [render/egl.c:201] Supported EGL client extensions: EGL_EXT_platform_base EGL_EXT_device_base EGL_EXT_device_enumeration EGL_EXT_device_query EGL_KHR_client_get_all_proc_addresses EGL_EXT_client_extensions EGL_KHR_debug EGL_KHR_platform_x11 EGL_EXT_platform_x11 EGL_EXT_platform_device EGL_MESA_platform_surfaceless EGL_EXT_explicit_device EGL_KHR_platform_wayland EGL_EXT_platform_wayland EGL_KHR_platform_gbm EGL_MESA_platform_gbm EGL_EXT_platform_xcb
00:00:00.027 [DEBUG] [render/egl.c:469] Using EGL device /dev/dri/card0
00:00:00.028 [INFO] [render/egl.c:347] Using EGL 1.5
00:00:00.028 [INFO] [render/egl.c:348] Supported EGL display extensions: EGL_ANDROID_native_fence_sync EGL_EXT_buffer_age EGL_EXT_client_sync EGL_EXT_create_context_robustness EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_MESA_image_dma_buf_export EGL_EXT_output_base EGL_EXT_output_drm EGL_EXT_protected_content EGL_EXT_stream_consumer_egloutput EGL_EXT_stream_acquire_mode EGL_EXT_sync_reuse EGL_IMG_context_priority EGL_KHR_config_attribs EGL_KHR_create_context_no_error EGL_KHR_context_flush_control EGL_KHR_create_context EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_partial_update EGL_KHR_swap_buffers_with_damage EGL_KHR_no_config_context EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_reusable_sync EGL_KHR_stream EGL_KHR_stream_attrib EGL_KHR_stream_consumer_gltexture EGL_KHR_stream_cross_process_fd EGL_KHR_stream_fifo EGL_KHR_stream_producer_eglsurface EGL_KHR_surfaceless_context EGL_KHR_wait_sync EGL_NV_nvrm_fence_sync EGL_NV_quadruple_buffer EGL_NV_stream_consumer_eglimage EGL_NV_stream_cross_display EGL_NV_stream_cross_object EGL_NV_stream_cross_process EGL_NV_stream_cross_system EGL_NV_stream_dma EGL_NV_stream_flush EGL_NV_stream_metadata EGL_NV_stream_remote EGL_NV_stream_reset EGL_NV_stream_socket EGL_NV_stream_socket_inet EGL_NV_stream_socket_unix EGL_NV_stream_sync EGL_NV_stream_fifo_next EGL_NV_stream_fifo_synchronous EGL_NV_stream_consumer_gltexture_yuv EGL_NV_stream_attrib EGL_NV_stream_origin EGL_NV_system_time EGL_NV_output_drm_flip_event EGL_NV_triple_buffer EGL_NV_robustness_video_memory_purge EGL_EXT_present_opaque EGL_WL_bind_wayland_display EGL_WL_wayland_eglstream
00:00:00.028 [INFO] [render/egl.c:350] Supported EGL device extensions: EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_EXT_device_query_name EGL_EXT_device_persistent_id
00:00:00.028 [INFO] [render/egl.c:352] EGL vendor: NVIDIA
00:00:00.028 [INFO] [render/egl.c:354] EGL driver name: nvidia
00:00:00.028 [INFO] [util/env.c:9] Loading WLR_EGL_NO_MODIFIERS option: 1
00:00:00.028 [INFO] [render/egl.c:112] WLR_EGL_NO_MODIFIERS set, disabling modifiers for EGL
00:00:00.028 [DEBUG] [render/egl.c:121] Supported DMA-BUF formats:
00:00:00.028 [DEBUG] [render/egl.c:165] AB24 (0x34324241)
00:00:00.028 [DEBUG] [render/egl.c:104] INVALID (0x00FFFFFFFFFFFFFF): ✓ texture ✓ render
00:00:00.028 [DEBUG] [render/egl.c:104] LINEAR (0x0000000000000000): ✓ texture ✓ render
00:00:00.028 [DEBUG] [render/egl.c:165] XB24 (0x34324258)
00:00:00.028 [DEBUG] [render/egl.c:165] R8 (0x20203852)
00:00:00.028 [DEBUG] [render/egl.c:165] RG88 (0x38384752)
00:00:00.028 [DEBUG] [render/egl.c:165] R16 (0x20363152)
00:00:00.028 [DEBUG] [render/egl.c:165] RG32 (0x32334752)
00:00:00.028 [DEBUG] [render/egl.c:165] GR32 (0x32335247)
00:00:00.028 [DEBUG] [render/egl.c:165] UYVY (0x59565955)
00:00:00.028 [DEBUG] [render/egl.c:165] AR12 (0x32315241)
00:00:00.028 [DEBUG] [render/egl.c:165] AB12 (0x32314241)
00:00:00.028 [DEBUG] [render/egl.c:165] RA12 (0x32314152)
00:00:00.028 [DEBUG] [render/egl.c:165] BA12 (0x32314142)
00:00:00.028 [DEBUG] [render/egl.c:165] XR15 (0x35315258)
00:00:00.028 [DEBUG] [render/egl.c:165] XB15 (0x35314258)
00:00:00.028 [DEBUG] [render/egl.c:165] RX15 (0x35315852)
00:00:00.028 [DEBUG] [render/egl.c:165] BX15 (0x35315842)
00:00:00.028 [DEBUG] [render/egl.c:165] AR15 (0x35315241)
00:00:00.028 [DEBUG] [render/egl.c:165] AB15 (0x35314241)
00:00:00.028 [DEBUG] [render/egl.c:165] RA15 (0x35314152)
00:00:00.028 [DEBUG] [render/egl.c:165] BA15 (0x35314142)
00:00:00.028 [DEBUG] [render/egl.c:165] AB4H (0x48344241)
00:00:00.028 [DEBUG] [render/egl.c:165] XB4H (0x48344258)
00:00:00.028 [DEBUG] [render/egl.c:165] AR24 (0x34325241)
00:00:00.028 [DEBUG] [render/egl.c:165] AS24 (0x34325341)
00:00:00.028 [DEBUG] [render/egl.c:165] XS24 (0x34325358)
00:00:00.028 [DEBUG] [render/egl.c:165] XR24 (0x34325258)
00:00:00.028 [DEBUG] [render/egl.c:165] RGB8 (0x38424752)
00:00:00.028 [DEBUG] [render/egl.c:165] BGR8 (0x38524742)
00:00:00.028 [DEBUG] [render/egl.c:165] RG16 (0x36314752)
00:00:00.028 [DEBUG] [render/egl.c:165] BG16 (0x36314742)
00:00:00.028 [DEBUG] [render/egl.c:165] RG24 (0x34324752)
00:00:00.028 [DEBUG] [render/egl.c:165] BG24 (0x34324742)
00:00:00.028 [DEBUG] [render/egl.c:165] AR30 (0x30335241)
00:00:00.028 [DEBUG] [render/egl.c:165] RX24 (0x34325852)
00:00:00.028 [DEBUG] [render/egl.c:165] BX24 (0x34325842)
00:00:00.028 [DEBUG] [render/egl.c:165] RA24 (0x34324152)
00:00:00.028 [DEBUG] [render/egl.c:165] BA24 (0x34324142)
00:00:00.028 [DEBUG] [render/egl.c:165] XR30 (0x30335258)
00:00:00.028 [DEBUG] [render/egl.c:165] XB30 (0x30334258)
00:00:00.028 [DEBUG] [render/egl.c:165] RX30 (0x30335852)
00:00:00.028 [DEBUG] [render/egl.c:165] BX30 (0x30335842)
00:00:00.028 [DEBUG] [render/egl.c:165] RA30 (0x30334152)
00:00:00.028 [DEBUG] [render/egl.c:165] BA30 (0x30334142)
00:00:00.028 [DEBUG] [render/egl.c:165] R101 (0x31303152)
00:00:00.028 [DEBUG] [render/egl.c:165] R100 (0x30303152)
00:00:00.028 [DEBUG] [render/egl.c:165] AB30 (0x30334241)
00:00:00.028 [DEBUG] [render/egl.c:165] B101 (0x31303142)
00:00:00.028 [DEBUG] [render/egl.c:165] B100 (0x30303142)
00:00:00.028 [DEBUG] [render/egl.c:165] YU12 (0x32315559)
00:00:00.028 [DEBUG] [render/egl.c:165] NV12 (0x3231564E)
00:00:00.028 [DEBUG] [render/egl.c:165] NV21 (0x3132564E)
00:00:00.029 [DEBUG] [render/egl.c:104] INVALID (0x00FFFFFFFFFFFFFF): ✓ texture ✓ render
00:00:00.029 [DEBUG] [render/egl.c:104] LINEAR (0x0000000000000000): ✓ texture ✓ render
00:00:00.029 [DEBUG] [render/egl.c:165] NV16 (0x3631564E)
00:00:00.029 [DEBUG] [render/egl.c:165] NV24 (0x3432564E)
00:00:00.029 [DEBUG] [render/egl.c:165] P010 (0x30313050)
00:00:00.029 [DEBUG] [render/egl.c:165] P210 (0x30313250)
00:00:00.029 [DEBUG] [render/egl.c:165] P012 (0x32313050)
00:00:00.029 [DEBUG] [render/egl.c:165] HD01 (0x31304448)
00:00:00.029 [DEBUG] [render/egl.c:165] UHD0 (0x30444855)
00:00:00.042 [DEBUG] [render/egl.c:420] Obtained high priority context
00:00:00.042 [DEBUG] [render/egl.c:518] Using EGL_PLATFORM_DEVICE_EXT
00:00:00.061 [INFO] [render/gles2/renderer.c:718] Creating GLES2 renderer
00:00:00.061 [INFO] [render/gles2/renderer.c:719] Using OpenGL ES 3.2 NVIDIA 545.23.06
00:00:00.061 [INFO] [render/gles2/renderer.c:720] GL vendor: NVIDIA Corporation
00:00:00.061 [INFO] [render/gles2/renderer.c:721] GL renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
00:00:00.061 [INFO] [render/gles2/renderer.c:722] Supported GLES2 extensions: GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_buffer_storage GL_EXT_clear_texture GL_EXT_clip_control GL_EXT_clip_cull_distance GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_conservative_depth GL_EXT_copy_image GL_EXT_depth_clamp GL_EXT_debug_label GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_EGL_image_array GL_EXT_EGL_image_storage GL_EXT_EGL_image_external_wrap_modes GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_map_buffer_range GL_EXT_multi_draw_indirect GL_EXT_multisample_compatibility GL_EXT_multisampled_render_to_texture GL_EXT_multisampled_render_to_texture2 GL_EXT_multiview_texture_multisample GL_EXT_multiview_timer_query GL_EXT_occlusion_query_boolean GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_primitive_bounding_box GL_EXT_raster_multisample GL_EXT_render_snorm GL_EXT_robustness GL_EXT_separate_shader_objects GL_EXT_shader_group_vote GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_shader_io_blocks GL_EXT_shader_non_constant_global_initializers GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sparse_texture GL_EXT_sparse_texture2 GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_compression_bptc GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map_array GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_format_BGRA8888 GL_EXT_texture_mirror_clamp_to_edge GL_EXT_texture_norm16 GL_EXT_texture_query_lod GL_EXT_texture_rg GL_EXT_texture_shadow_lod GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_view GL_EXT_draw_transform_feedback GL_EXT_unpack_subimage GL_EXT_window_rectangles GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_fd GL_NV_memory_object_sparse GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_fd GL_NV_timeline_semaphore GL_KHR_shader_subgroup GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_KHR_texture_compression_astc_hdr GL_NV_bgr GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NVX_blend_equation_advanced_multi_draw_buffers GL_NV_blend_minmax_factor GL_NV_clip_space_w_scaling GL_NV_conditional_render GL_NV_conservative_raster GL_NV_conservative_raster_pre_snap_triangles GL_NV_copy_buffer GL_NV_copy_image GL_NV_draw_buffers GL_NV_draw_instanced GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_EGL_stream_consumer_external GL_NV_explicit_attrib_location GL_NV_fbo_color_attachments GL_NV_fill_rectangle GL_NV_fragment_coverage_to_color GL_NV_fragment_shader_interlock GL_NV_framebuffer_blit GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample GL_NV_generate_mipmap_sRGB GL_NV_geometry_shader_passthrough GL_NV_instanced_arrays GL_NV_internalformat_sample_query GL_NV_gpu_shader5 GL_NV_image_formats GL_NV_memory_attachment GL_NV_occlusion_query_samples GL_NV_non_square_matrices GL_NV_pack_subimage GL_NV_packed_float GL_NV_packed_float_linear GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_buffer_object GL_NV_polygon_mode GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_shader_atomic_fp16_vector GL_NV_shader_noperspective_interpolation GL_NV_shader_subgroup_partitioned GL_NV_shadow_samplers_array GL_NV_shadow_samplers_cube GL_NV_sRGB_formats GL_NV_stereo_view_rendering GL_NV_texture_array GL_NV_texture_barrier GL_NV_texture_border_clamp GL_NV_texture_compression_latc GL_NV_texture_compression_s3tc GL_NV_texture_compression_s3tc_update GL_NV_timer_query GL_NV_viewport_array GL_NV_viewport_array2 GL_NV_viewport_swizzle GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_buffer GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_view GL_OES_primitive_bounding_box GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_EXT_read_format_bgra GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_cube_map_array GL_OES_texture_npot GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_vertex_array_object GL_OES_vertex_half_float GL_OES_viewport_array GL_OVR_multiview GL_OVR_multiview2 GL_OVR_multiview_multisampled_render_to_texture GL_ANDROID_extension_pack_es31a
00:00:00.064 [DEBUG] [render/allocator/allocator.c:106] Trying to create gbm allocator
00:00:00.082 [DEBUG] [render/allocator/gbm.c:210] Created GBM allocator with backend drm
00:00:00.082 [DEBUG] [render/allocator/gbm.c:213] Using DRM node /dev/dri/card0
00:00:00.084 [DEBUG] [../src/config/keybind.c:108] Found layout Italian
00:00:00.084 [DEBUG] [../src/config/keybind.c:108] Found layout English (US)
00:00:00.090 [DEBUG] [xcursor/wlr_xcursor.c:243] Loaded cursor theme 'Adwaita' at size 16 (123 available cursors)
00:00:00.090 [DEBUG] [types/wlr_idle.c:246] idle manager created
00:00:00.090 [DEBUG] [types/wlr_drm_lease_v1.c:638] Creating wlr_drm_lease_device_v1 for /dev/dri/card0
00:00:00.090 [DEBUG] [../src/xwayland.c:790] xwayland is running on display :0
00:00:00.090 [DEBUG] [backend/libinput/backend.c:87] Starting libinput backend
00:00:00.119 [DEBUG] [backend/libinput/events.c:70] Adding Power Button [0:1]
00:00:00.120 [DEBUG] [backend/libinput/events.c:70] Adding Power Button [0:1]
00:00:00.121 [DEBUG] [backend/libinput/events.c:70] Adding Sleep Button [0:3]
00:00:00.122 [DEBUG] [backend/libinput/events.c:70] Adding PixArt USB Optical Mouse [2362:9488]
00:00:00.122 [INFO] [../src/seat.c:90] tap unavailable
00:00:00.122 [INFO] [../src/seat.c:100] tap-and-drag not configured
00:00:00.122 [INFO] [../src/seat.c:109] drag lock not configured
00:00:00.122 [INFO] [../src/seat.c:120] natural scroll configured
00:00:00.122 [INFO] [../src/seat.c:127] left-handed mode not configured
00:00:00.122 [INFO] [../src/seat.c:137] pointer acceleration configured
00:00:00.122 [INFO] [../src/seat.c:150] middle emulation not configured
00:00:00.122 [INFO] [../src/seat.c:159] dwt not configured
00:00:00.122 [INFO] [../src/seat.c:191] map pointer to output (null)
00:00:00.122 [DEBUG] [backend/libinput/events.c:70] Adding SEM USB Keyboard [6700:8484]
00:00:00.123 [DEBUG] [backend/libinput/events.c:70] Adding SEM USB Keyboard Consumer Control [6700:8484]
00:00:00.124 [INFO] [../src/seat.c:90] tap unavailable
00:00:00.124 [INFO] [../src/seat.c:100] tap-and-drag not configured
00:00:00.124 [INFO] [../src/seat.c:109] drag lock not configured
00:00:00.124 [INFO] [../src/seat.c:120] natural scroll configured
00:00:00.124 [INFO] [../src/seat.c:127] left-handed mode not configured
00:00:00.124 [INFO] [../src/seat.c:135] pointer acceleration unavailable
00:00:00.124 [INFO] [../src/seat.c:150] middle emulation not configured
00:00:00.124 [INFO] [../src/seat.c:159] dwt not configured
00:00:00.124 [INFO] [../src/seat.c:191] map pointer to output (null)
00:00:00.124 [DEBUG] [backend/libinput/events.c:70] Adding SEM USB Keyboard System Control [6700:8484]
00:00:00.126 [DEBUG] [backend/libinput/events.c:70] Adding Asus WMI hotkeys [0:0]
00:00:00.127 [DEBUG] [backend/libinput/events.c:70] Adding Eee PC WMI hotkeys [0:0]
00:00:00.128 [DEBUG] [backend/libinput/backend.c:128] libinput successfully initialized
00:00:00.128 [INFO] [backend/drm/drm.c:1338] Scanning DRM connectors on /dev/dri/card0
00:00:00.128 [INFO] [backend/drm/drm.c:1389] Found connector 'DVI-D-1'
00:00:00.128 [INFO] [backend/drm/drm.c:1389] Found connector 'HDMI-A-1'
00:00:00.131 [INFO] [backend/drm/drm.c:1389] Found connector 'DP-1'
00:00:00.131 [INFO] [backend/drm/drm.c:1414] 'DP-1' connected
00:00:00.131 [DEBUG] [backend/drm/drm.c:1220] Current CRTC: -1
00:00:00.131 [INFO] [util/env.c:9] Loading WLR_NO_HARDWARE_CURSORS option: 1
00:00:00.131 [DEBUG] [types/output/output.c:382] WLR_NO_HARDWARE_CURSORS set, forcing software cursors
00:00:00.131 [INFO] [backend/drm/drm.c:1230] Physical size: 600x340
00:00:00.131 [INFO] [backend/drm/drm.c:1287] Detected modes:
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1920x1080 @ 119,982 Hz (preferred)
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 3840x2160 @ 60,000 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1920x1080 @ 165,008 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1920x1080 @ 143,999 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1920x1080 @ 99,930 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1920x1080 @ 60,000 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1920x1080 @ 59,939 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1920x1080 @ 50,000 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1680x1050 @ 59,954 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1280x1024 @ 75,025 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1280x1024 @ 60,020 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1440x900 @ 59,887 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1280x960 @ 60,000 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1280x800 @ 59,810 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1152x864 @ 75,000 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1280x720 @ 60,000 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1280x720 @ 59,943 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1280x720 @ 50,000 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1024x768 @ 75,029 Hz
00:00:00.131 [INFO] [backend/drm/drm.c:1315] 1024x768 @ 70,069 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 1024x768 @ 60,004 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 800x600 @ 75,000 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 800x600 @ 72,188 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 800x600 @ 60,317 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 800x600 @ 56,250 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 720x576 @ 50,000 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 720x480 @ 59,940 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 640x480 @ 75,000 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 640x480 @ 59,940 Hz
00:00:00.132 [INFO] [backend/drm/drm.c:1315] 640x480 @ 59,929 Hz
00:00:00.132 [DEBUG] [backend/drm/drm.c:1011] Reallocating CRTCs
00:00:00.132 [DEBUG] [backend/drm/drm.c:1022] State before reallocation:
00:00:00.132 [DEBUG] [backend/drm/drm.c:1036] 'DVI-D-1' crtc=-1 status=2 want_crtc=0
00:00:00.132 [DEBUG] [backend/drm/drm.c:1036] 'HDMI-A-1' crtc=-1 status=2 want_crtc=0
00:00:00.132 [DEBUG] [backend/drm/drm.c:1036] 'DP-1' crtc=-1 status=1 want_crtc=0
00:00:00.132 [DEBUG] [backend/drm/drm.c:1078] State after reallocation:
00:00:00.132 [DEBUG] [backend/drm/drm.c:1085] 'DVI-D-1' crtc=-1 status=2
00:00:00.132 [DEBUG] [backend/drm/drm.c:1085] 'HDMI-A-1' crtc=-1 status=2
00:00:00.132 [DEBUG] [backend/drm/drm.c:1085] 'DP-1' crtc=-1 status=1
00:00:00.132 [INFO] [backend/drm/drm.c:1447] connector DP-1: Requesting modeset
00:00:00.132 [DEBUG] [types/wlr_drm_lease_v1.c:531] Offering output DP-1
00:00:00.132 [DEBUG] [../src/output.c:121] enable output
00:00:00.132 [DEBUG] [../src/output.c:130] set preferred mode
00:00:00.132 [DEBUG] [types/output/render.c:229] Attaching empty buffer to output for modeset
00:00:00.132 [DEBUG] [backend/drm/drm.c:1036] 'DP-1' crtc=-1 status=1 want_crtc=1
00:00:00.132 [DEBUG] [backend/drm/drm.c:1085] 'DP-1' crtc=3 status=1
00:00:00.132 [DEBUG] [types/output/render.c:75] Choosing primary buffer format XR24 (0x34325258) for output 'DP-1'
00:00:00.132 [DEBUG] [render/swapchain.c:105] Allocating new swapchain buffer
00:00:00.132 [DEBUG] [render/allocator/gbm.c:143] Allocated 1920x1080 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.132 [ERROR] [GLES2] GL_INVALID_OPERATION error generated. EGLImage not supported
00:00:00.132 [ERROR] [render/gles2/renderer.c:139] Failed to create FBO
00:00:00.132 [DEBUG] [../src/output.c:143] preferred mode rejected, falling back to another mode
00:00:00.132 [DEBUG] [render/allocator/gbm.c:143] Allocated 3840x2160 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.133 [DEBUG] [types/output/render.c:229] Attaching empty buffer to output for modeset
00:00:00.133 [DEBUG] [types/output/render.c:75] Choosing primary buffer format XR24 (0x34325258) for output 'DP-1'
00:00:00.133 [DEBUG] [render/swapchain.c:105] Allocating new swapchain buffer
00:00:00.133 [DEBUG] [render/allocator/gbm.c:143] Allocated 1920x1080 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.133 [ERROR] [GLES2] GL_INVALID_OPERATION error generated. EGLImage not supported
00:00:00.133 [ERROR] [render/gles2/renderer.c:139] Failed to create FBO
00:00:00.133 [DEBUG] [render/allocator/gbm.c:143] Allocated 1680x1050 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.134 [ERROR] [GLES2] GL_INVALID_OPERATION error generated. EGLImage not supported
00:00:00.134 [ERROR] [render/gles2/renderer.c:139] Failed to create FBO
00:00:00.134 [DEBUG] [types/output/render.c:229] Attaching empty buffer to output for modeset
00:00:00.134 [DEBUG] [types/output/render.c:75] Choosing primary buffer format XR24 (0x34325258) for output 'DP-1'
00:00:00.134 [DEBUG] [render/swapchain.c:105] Allocating new swapchain buffer
00:00:00.134 [DEBUG] [render/allocator/gbm.c:143] Allocated 1280x1024 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.134 [DEBUG] [render/allocator/gbm.c:143] Allocated 1440x900 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.134 [DEBUG] [render/allocator/gbm.c:143] Allocated 1280x960 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.135 [DEBUG] [render/allocator/gbm.c:143] Allocated 1280x800 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.135 [ERROR] [GLES2] GL_INVALID_OPERATION error generated. EGLImage not supported
00:00:00.135 [ERROR] [render/gles2/renderer.c:139] Failed to create FBO
00:00:00.135 [DEBUG] [types/output/render.c:229] Attaching empty buffer to output for modeset
00:00:00.135 [DEBUG] [types/output/render.c:75] Choosing primary buffer format XR24 (0x34325258) for output 'DP-1'
00:00:00.135 [DEBUG] [render/swapchain.c:105] Allocating new swapchain buffer
00:00:00.135 [DEBUG] [render/allocator/gbm.c:143] Allocated 1152x864 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.135 [DEBUG] [render/allocator/gbm.c:143] Allocated 1280x720 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.135 [DEBUG] [render/allocator/gbm.c:143] Allocated 1024x768 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.136 [DEBUG] [types/output/render.c:229] Attaching empty buffer to output for modeset
00:00:00.136 [ERROR] [GLES2] GL_INVALID_OPERATION error generated. EGLImage not supported
00:00:00.136 [ERROR] [render/gles2/renderer.c:139] Failed to create FBO
00:00:00.136 [DEBUG] [types/output/render.c:75] Choosing primary buffer format XR24 (0x34325258) for output 'DP-1'
00:00:00.136 [DEBUG] [render/swapchain.c:105] Allocating new swapchain buffer
00:00:00.136 [DEBUG] [render/allocator/gbm.c:143] Allocated 800x600 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.136 [DEBUG] [render/allocator/gbm.c:143] Allocated 720x576 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.137 [DEBUG] [types/output/render.c:229] Attaching empty buffer to output for modeset
00:00:00.137 [DEBUG] [types/output/render.c:75] Choosing primary buffer format XR24 (0x34325258) for output 'DP-1'
00:00:00.137 [DEBUG] [render/swapchain.c:105] Allocating new swapchain buffer
00:00:00.137 [DEBUG] [render/allocator/gbm.c:143] Allocated 720x480 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.137 [ERROR] [GLES2] GL_INVALID_OPERATION error generated. EGLImage not supported
00:00:00.137 [ERROR] [render/gles2/renderer.c:139] Failed to create FBO
00:00:00.137 [DEBUG] [render/allocator/gbm.c:143] Allocated 640x480 GBM buffer with format XR24 (0x34325258), modifier INVALID (0x00FFFFFFFFFFFFFF)
00:00:00.137 [ERROR] [../src/output.c:416] failed to get output layout box
00:00:00.138 [DEBUG] [types/output/cursor.c:432] Falling back to software cursor on output 'DP-1'
00:00:00.138 [DEBUG] [../src/server.c:481] WAYLAND_DISPLAY=wayland-0
00:00:00.138 [INFO] [../src/theme.c:500] read theme /home/attila/.local/share/themes/Vent-dark/openbox-3/themerc
00:00:00.140 [INFO] [../src/theme.c:520] no theme override '/home/attila/.config/labwc/themerc-override'
00:00:00.147 [DEBUG] [../src/button/button-svg.c:35] error reading svg /home/attila/.local/share/themes/Vent-dark/openbox-3/menu-active.svg-I/O error: Errore nell'aprire il file /home/attila/.local/share/themes/Vent-dark/openbox-3/menu-active.svg: File o directory non esistente
00:00:00.147 [DEBUG] [../src/button/button-svg.c:35] error reading svg /home/attila/.local/share/themes/Vent-dark/openbox-3/menu-inactive.svg-I/O error: Errore nell'aprire il file /home/attila/.local/share/themes/Vent-dark/openbox-3/menu-inactive.svg: File o directory non esistente
00:00:00.147 [DEBUG] [../src/button/button-svg.c:35] error reading svg /home/attila/.local/share/themes/Vent-dark/openbox-3/iconify-active.svg-I/O error: Errore nell'aprire il file /home/attila/.local/share/themes/Vent-dark/openbox-3/iconify-active.svg: File o directory non esistente
00:00:00.147 [DEBUG] [../src/button/button-svg.c:35] error reading svg /home/attila/.local/share/themes/Vent-dark/openbox-3/iconify-inactive.svg-I/O error: Errore nell'aprire il file /home/attila/.local/share/themes/Vent-dark/openbox-3/iconify-inactive.svg: File o directory non esistente
00:00:00.147 [DEBUG] [../src/button/button-svg.c:35] error reading svg /home/attila/.local/share/themes/Vent-dark/openbox-3/max-active.svg-I/O error: Errore nell'aprire il file /home/attila/.local/share/themes/Vent-dark/openbox-3/max-active.svg: File o directory non esistente
00:00:00.147 [DEBUG] [../src/button/button-svg.c:35] error reading svg /home/attila/.local/share/themes/Vent-dark/openbox-3/max-inactive.svg-I/O error: Errore nell'aprire il file /home/attila/.local/share/themes/Vent-dark/openbox-3/max-inactive.svg: File o directory non esistente
00:00:00.147 [DEBUG] [../src/button/button-svg.c:35] error reading svg /home/attila/.local/share/themes/Vent-dark/openbox-3/close-active.svg-I/O error: Errore nell'aprire il file /home/attila/.local/share/themes/Vent-dark/openbox-3/close-active.svg: File o directory non esistente
00:00:00.147 [DEBUG] [../src/button/button-svg.c:35] error reading svg /home/attila/.local/share/themes/Vent-dark/openbox-3/close-inactive.svg-I/O error: Errore nell'aprire il file /home/attila/.local/share/themes/Vent-dark/openbox-3/close-inactive.svg: File o directory non esistente
00:00:00.147 [INFO] [../src/menu/menu.c:546] read menu file /home/attila/.config/labwc/menu.xml
00:00:00.149 [ERROR] [../src/action.c:336] Invalid action: lxqt-wlogout
00:00:00.149 [INFO] [../src/config/session.c:89] Updating dbus execution environment
00:00:00.153 [INFO] [../src/config/session.c:132] run autostart file /home/attila/.config/labwc/autostart
00:00:00.158 [INFO] [xwayland/server.c:108] Starting Xwayland on :0
qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
isPrimaryInstance
00:00:00.218 [DEBUG] [types/wlr_compositor.c:673] New wlr_surface 0x55e54d72acd0 (res 0x55e54d75fbb0)
00:00:00.218 [DEBUG] [xwayland/server.c:273] Xserver is ready
00:00:00.218 [DEBUG] [xwayland/xwm.c:1817] xfixes version: 6.0
00:00:00.218 [DEBUG] [xwayland/xwm.c:1838] xres version: 1.2
KMS: DRM_IOCTL_MODE_CREATE_DUMB failed: Permission denied
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Unsupported maximum keycode 708, clipping.
> X11 cannot support keycodes above 255.
Errors from xkbcomp are not fatal to the X server
00:00:00.224 [DEBUG] [xwayland/xwm.c:1551] unhandled X11 event: 34
00:00:00.255 [DEBUG] [types/wlr_compositor.c:673] New wlr_surface 0x55e54d751df0 (res 0x55e54d752150)
00:00:00.255 [DEBUG] [types/xdg_shell/wlr_xdg_surface.c:387] new xdg_surface 0x55e54d7521e0 (res 0x55e54d710ee0)
00:00:00.262 [ERROR] [../src/view.c:211] invalid output set for view
00:00:00.262 [ERROR] [../src/view.c:392] view has no output, not centering
00:00:00.262 [DEBUG] [../src/action.c:531] Handling action 18: ToggleAlwaysOnBottom
00:00:00.262 [DEBUG] [../src/action.c:531] Handling action 14: Maximize
00:00:00.262 [ERROR] [../src/view.c:622] view has no output, not updating geometry
00:00:00.262 [DEBUG] [../src/view-impl-common.c:74] [map] identifier=pcmanfm-qt, title=pcmanfm-desktop0
00:00:00.274 [DEBUG] [types/wlr_compositor.c:673] New wlr_surface 0x55e54d88fec0 (res 0x55e54d890220)
00:00:00.487 [DEBUG] [types/wlr_compositor.c:673] New wlr_surface 0x55e54d922ac0 (res 0x55e54d922e20)
00:00:08.757 [DEBUG] [xwayland/xwm.c:1551] unhandled X11 event: 34
00:00:09.672 [DEBUG] [backend/libinput/events.c:140] Removing Asus WMI hotkeys [0:0]
00:00:09.672 [DEBUG] [backend/libinput/events.c:140] Removing Eee PC WMI hotkeys [0:0]
00:00:09.672 [DEBUG] [backend/libinput/events.c:140] Removing SEM USB Keyboard Consumer Control [6700:8484]
00:00:09.673 [DEBUG] [backend/libinput/events.c:140] Removing Power Button [0:1]
00:00:09.673 [DEBUG] [backend/libinput/events.c:140] Removing PixArt USB Optical Mouse [2362:9488]
00:00:09.728 [DEBUG] [backend/libinput/events.c:140] Removing SEM USB Keyboard [6700:8484]
00:00:09.728 [DEBUG] [backend/libinput/events.c:140] Removing Sleep Button [0:3]
00:00:09.728 [DEBUG] [backend/libinput/events.c:140] Removing SEM USB Keyboard System Control [6700:8484]
00:00:09.729 [INFO] [libseat] [libseat/backend/logind.c:382] Disabling seat
00:00:09.729 [INFO] [backend/drm/backend.c:141] DRM fd paused
00:00:10.230 [INFO] [xwayland/server.c:215] Restarting Xwayland (lazy)
00:00:22.570 [DEBUG] [types/output/cursor.c:432] Falling back to software cursor on output 'DP-1'
00:01:01.642 [DEBUG] [types/wlr_compositor.c:673] New wlr_surface 0x55e54d6e02c0 (res 0x55e54d56e170)
00:01:01.642 [DEBUG] [types/xdg_shell/wlr_xdg_surface.c:387] new xdg_surface 0x55e54d529aa0 (res 0x55e54d74de40)
00:01:01.643 [ERROR] [../src/view.c:211] invalid output set for view
00:01:01.643 [ERROR] [../src/view.c:392] view has no output, not centering
00:01:01.643 [DEBUG] [../src/action.c:527] Handling action 30: SnapToRegion notifications
00:01:01.643 [DEBUG] [../src/view-impl-common.c:74] [map] identifier=lxqt-notificationd, title=lxqt-notificationd
00:01:01.653 [DEBUG] [types/wlr_compositor.c:673] New wlr_surface 0x55e54d759100 (res 0x55e54d88f330)
01:48:59.871 [DEBUG] [types/output/cursor.c:432] Falling back to software cursor on output 'DP-1'
01:48:59.871 [DEBUG] [types/wlr_drm_lease_v1.c:522] Handle destruction of output DP-1
01:48:59.871 [DEBUG] [types/wlr_drm_lease_v1.c:585] Withdrawing output DP-1
01:48:59.871 [DEBUG] [types/wlr_drm_lease_v1.c:70] Destroying connector DP-1
01:48:59.871 [DEBUG] [backend/drm/drm.c:979] connector DP-1: De-allocating CRTC 3
01:48:59.871 [ERROR] [backend/drm/atomic.c:72] connector DP-1: Atomic commit failed: Permesso negato
01:48:59.871 [DEBUG] [backend/drm/atomic.c:76] (Atomic commit flags: ATOMIC_ALLOW_MODESET)
01:48:59.871 [ERROR] [backend/drm/drm.c:991] connector DP-1: Failed to disable CRTC 71
01:48:59.871 [DEBUG] [types/wlr_drm_lease_v1.c:103] Destroying wlr_drm_lease_device_v1 for /dev/dri/card0
01:48:59.992 [DEBUG] [types/wlr_drm_lease_v1.c:685] Destroying wlr_drm_lease_v1_manager
Regards
