log-codec.txt (119.2 KB)
There is no node when debugging es8388. See the attachment for the device tree and log.
What is the reason?
dts.tar.gz (3.5 KB)
What is the reason?
dts.tar.gz (3.5 KB)
Please provide details for what have been done, SW version…etc, then can know how to support.
Yopu can also refer to Audio Setup and Development — NVIDIA Jetson Linux Developer Guide 1 documentation to see if can find more clues. Thanks
Could you help me look into this issue?
Excuse me, is there a problem with the device tree configuration?
Hi zhang,
In above comment, I could see APE card is registered. Is the codec node still not available? If yes, please share below details:
ls /sys/kernel/debug/regmap/dtb.tar.gz (57.4 KB)
0001-dmesg.txt (79.9 KB)
When debugging started, no APE node was generated. After modifying the dts, APE was generated.
Now there is no sound when playing music.
Please help with some more details:
From the recent log, the codec driver is throwing below error
No MCLK Configured
Did you modify machine driver to add support for snd_soc_dai_set_sysclk() callback to codec driver?, please refer Audio Setup and Development — Jetson Linux Developer Guide documentation
Due to above failure, the codec driver hw_params callback failed.
Can you fix the above issue and provide the error log if still issues exist.
es8388.txt (8.6 KB)
If you modify the driver according to the content in the link above, an error will occur. What is the problem?
Seems the es8328 codec driver doesn’t support the snd_soc_dai_set_pll() callback. you can try removing the below code in the driver and check again
err = snd_soc_dai_set_pll(rtd->dais[rtd->num_cpus], 0,
pll_src, bclk_rate, srate * 256);
if (err < 0) {
printk(“failed to set codec pll\n”);
return err;
Sorry for the delay.
These properties makes tegra I2S as Slave. If these are not present it will be set as Master. Will suggest to try without setting these properties.
Please share the mixer controls details.
settings.txt (788.2 KB)
es8388.txt (6.2 KB)
es8388-logo.txt (101.7 KB)
See the attachment for the modification.
Could observe only ‘CVB-RT Left Mixer Right Bypass Volume’ and ‘CVB-RT Left Mixer Left Bypass Volume’ set to some non-zero value, apart from that no other codec controls related to switch not required to be ON as mentioned here The audio codec ES8388 does not work on Jetson nano - #17 by user32489?
