I am a new developer and haven’t had much experience with dev boards, any help is appreciated.
I am having Troubleshooting both issue 1: No Sound Cards Found and Issue 2: Sound Not Audible
Issue 1:
Following the trouble shooting steps I get the following from [dmesg | grep ASoC] command.
[ 6.276363] tegra210-ape-admaif tegra210-admaif: ASoC: Failed to create codec debugfs directory
[ 6.277859] tegra210-adsp adsp_audio.3: ASoC: Failed to create platform debugfs directory
then the output similar to the drivers documentation
When checking the Codec driver instantiation via Device Tree
The directory for the following doesn’t exist
$KERNEL_TOP/arch/arm64/boot/dts/
Is this an error from flashing the OS? Looking at it after installation it said everything was successful.
However in Issue 2:
I’ve confirmed multiple time that the DAPM path is completed.
Yet the files to confirm the pinmux setting for I2S master/slave mode don’t exist as a file/directory
arch/arm64/boot/dts/tegra210-foster-e-p2530-common.dtsi
arch/arm64/boot/dts/tegra210-platforms/tegra210-foster-e-pinmux-p2530-0930-e00.dtsi
same with the arch/arm64/boot/dts/tegra210-common.dtsi
Also, trying to form an internal DAPM path connecting I2S with the same I2S instance using the command:
amixer -c 0 sset ‘I2S Mux’ ‘I2S’
results in:
amixer: unable to find simple control ‘ADX1 MUX’, 0
any help or clues would be great. I haven’t been able to find a lot of documentation other than the drivers package development guide. I have also looked at ALSA project website and some of the forums but haven’t been able to find a solution
