No output on I2S5 with APE driver on JetPack 35.3.1
I am having issues getting I2S working on the Xavier NX under JetPack 35.3.1 (kernel 5.10.104) and am seeking some assistance. It seems that the design of the ALSA soc drivers have changed from that used by older JetPack versions, and the documentation or examples I’m finding (frequently involving a ‘tegra-alt’ driver) seem to no longer apply for this kernel version.
This is a custom board with a MAX98365 audio codec, which is just a DAC accepting 2-channel I2S. ALSA DAPM requires a codec to establish a channel, so I’ve chosen to use the MAX98357A driver (have also tried simple-audio-amplifier). However, the codec is not the focus of this question, and I would be happy just being able to observe raw I2S output on the pins. These are the I2S0 pins, which seem to be attached to the I2S5 peripheral on this SoC.
I have tried to follow the examples to link I2S5 to the APE PCM via ADMAIF1. If I define the device tree as I’ve provided below, I can see the below output in dmesg (dynamic debugging is on so some rates are displayed).
[   12.491417] tegra210_i2s_probe:1228: tegra210-i2s 2901400.i2s: can't retrieve I2S sync input clock
[   16.191844] tegra_machine_dai_init:175: pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[   16.205230] tegra_machine_dai_init:175: pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, sample rate = 44100 Hz
[   16.216690] tegra210-i2s 2901400.i2s: timeout: failed to reset I2S for playback
[   16.216921] tegra210-i2s 2901400.i2s: ASoC: PRE_PMU: I2S5 RX event failed: -110
Despite being overridden in the device tree, alsamixer control values seem to always load as 0. For example, ‘I2S5 FSYNC Width’ and ‘I2S5 codec master mode’ are both 0, which is not a valid selection. Is this normal? I have also tried to explicitly set every one of these controls via amixer, and I see no change in behavior: I run ‘aplay’ but I see no output on any pin.
  • I am running all these tests on a freshly flashed device with no changes from the release other than a new kernel.
  • To help with debugging, I’ve gathered trace events for asoc during boot, where it appears that I2S5 Mux gets routed to and from ADMAIF1. I have culled this down to list only the selected routes so that it’s actually readable. dapm_trace_snippets.txt (13.6 KB)
  • I have also collected all alsamixer values for every control. amixer_contents.txt (215.6 KB)
Is there an obvious mistake I’m making, or is there an example that applies to JetPack 35.3.1 to just drive raw I2S5 output and no input?
Here is the relevant portion of the device tree. I’ve tried to explicitly set the sample rate and format to match the default FSYNC and BCLK values, but I don’t actually care what they are.
pinmux@2430000 {
pinmux_state: pinmux {
	// I2S5
	dap5_sclk_pt5 {
		nvidia,pins = "dap5_sclk_pt5";
		nvidia,function = "i2s5";
		nvidia,pin-label = "i2s5_sclk";
		nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
		nvidia,tristate = <TEGRA_PIN_DISABLE>;
		nvidia,enable-input = <TEGRA_PIN_ENABLE>;
		nvidia,lpdr = <TEGRA_PIN_DISABLE>;
	dap5_dout_pt6 {
		nvidia,pins = "dap5_dout_pt6";
		nvidia,pin-label = "i2s5_dout";
		nvidia,enable-input = <TEGRA_PIN_DISABLE>;
	dap5_din_pt7 {
		nvidia,pins = "dap5_din_pt7";
		nvidia,pin-label = "i2s5_din";
		nvidia,tristate = <TEGRA_PIN_ENABLE>;
	dap5_fs_pu0 {
		nvidia,pins = "dap5_fs_pu0";
		nvidia,pin-label = "i2s5_fs";
	tegra_sound: sound {
		status = "okay";
		compatible = "nvidia,tegra186-ape";
		nvidia-audio-card,name = "NVIDIA Jetson Xavier NX APE";
		clocks = <&bpmp_clks TEGRA194_CLK_PLLA>,
			 <&bpmp_clks TEGRA194_CLK_PLLA_OUT0>,
			 <&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
		clock-names = "pll_a", "pll_a_out0", "extern1";
		assigned-clocks = <&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
		assigned-clock-parents = <&bpmp_clks TEGRA194_CLK_PLLA_OUT0>;
		nvidia-audio-card,mclk-fs = <256>;
		nvidia-audio-card,widgets =
			"Headphone",         "MONOAMP IntSpkr";
		nvidia-audio-card,routing =
			"MONOAMP IntSpkr",   "MONOAMP Speaker";
	// I2S DAC + Amplifier
	// Could also use simple-audio-amplifier
	max98365: max98365 {
		#sound-dai-cells = <0>;
		sound-name-prefix = "MONOAMP";
		compatible   = "maxim,max98357a";
		sdmode-gpios = <&iox 7 GPIO_ACTIVE_HIGH>;
		sdmode-delay = <0>;
		status       = "okay";
		port {
			max98365_ep: endpoint {
				remote-endpoint = <&i2s5_dap_ep>;
				mclk-fs         = <256>;
				link-name       = "max98365-spkamp";
&tegra_i2s5 {
	status      = "okay";
	fsync-width = <31>;
	bclk-ratio  = <64>;
&i2s5_to_codec {
	link-type   = <C2C_LINK>;
	format      = "i2s";
	srate       = <48000>;
	num-channel = <2>;
	bit-format  = "s32_le";
	status      = "okay";
	bitclock-master;
	frame-master;
	i2s5_cpu: cpu {
		sound-dai = <&tegra_i2s5 I2S_DAP>;
	codec {
		sound-dai = <&max98365>;
		prefix    = "MONOAMP";
&i2s5_dap_ep {
	bitclock-master;
	frame-master;
	remote-endpoint = <&max98365_ep>;
Thank you.
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
If you still see an issue; Could you please read the PINMUX registers? the values should be as below.
pinmux.0x02431020 = 0x00000408; # aud_mclk_ps4: aud, pull-up, tristate-disable, input-disable, lpdr-disable
pinmux.0x02431080 = 0x00000444; # dap5_sclk_pt5: i2s5, pull-down, tristate-disable, input-enable, lpdr-disable
pinmux.0x02431078 = 0x00000404; # dap5_dout_pt6: i2s5, pull-down, tristate-disable, input-disable, lpdr-disable
pinmux.0x02431070 = 0x00000454; # dap5_din_pt7: i2s5, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x02431068 = 0x00000444; # dap5_fs_pu0: i2s5, pull-down, tristate-disable, input-enable, lpdr-disable
You can also refer:
Thanks for checking back! I have not gotten this working and would still appreciate support.
I checked the pinmux values as suggested below by DRAMESH, and everything matches except for the MCLK pin. This isn’t particularly surprising since I’d set everything explicitly in the device tree, but it never hurts to check. (I don’t need MCLK or SCLK).
user@xavnx:~$ sudo busybox devmem 0x02431020 32  #aud_mclk_ps4
0x00000059
user@xavnx:~$ sudo busybox devmem 0x02431080 32  #dap5_sclk_pt5
0x00000444
user@xavnx:~$ sudo busybox devmem 0x02431078 32  #dap5_dout_pt6
0x00000404
user@xavnx:~$ sudo busybox devmem 0x02431070 32  #dap5_din_pt7
0x00000454
user@xavnx:~$ sudo busybox devmem 0x02431068 32  #dap5_fs_pu0
0x00000444
Could you please provide the I2S Bit Clock that is connected to the Tegra? The error message indicates that the Tegra controller is unable to receive the Bit Clock signal from the external codec, which is configured as the master.
(or) you can try Tegra as Master.
Regarding comment:
"Despite being overridden in the device tree, alsamixer control values seem to always load as 0. For example, ‘I2S5 FSYNC Width’ and ‘I2S5 codec master mode’ are both 0, which is not a valid selection. Is this normal? "
It’s expected in the current audio driver. Get alsamixer control values are updated with cached one and hence you are seeing “0”.
Okay, well that error would make sense if it is indeed acting as a slave. I’d like the Tegra to act as the master device. How can I do this? Is specifying bitclock-master and frame-master in the device tree not sufficient?
Sorry for the late response, Please remove bitclock-master and frame-master from i2s5_to_codec node to set Tegra as master.
