Hi
- I work with tx1+SDK 28.2; the speaker device is tas5751 with i2s4(0-4), it always sound less. I have no idear to debug it!! help help help
- kernel show trace as follow :
[ 18.067337] tegra210-i2s tegra210-i2s.0: Failed at I2S0_RX sw reset
[ 18.082612] tegra210-i2s tegra210-i2s.0: ASoC: PRE_PMU: I2S1 DAP RX event failed: -22 - my dts as follow:
4)additional important info : aplay can not work until few seconds going on
trace as follow:
ALSA lib pcm_hw.c:1700:(_snd_pcm_hw_open) Invalid value for card
aplay: main:722: audio open error: No such device
DTS:
gpio: gpio@6000d000 {
gpio-init-names = “default”;
gpio-init-0 = <&gpio_default>;
gpio_default: default {
/* Transfer pins from GPIO to I2S for audio. /
gpio-to-sfio = < / GPIO# TX1-PIN TX1-FUNC/ERA-FUNC CODEC-PIN /
TEGRA_GPIO(B, 0) / 8 H1 I2S0_LRCLK/SFSYNC R335/3 /
TEGRA_GPIO(B, 1) / 9 G1 I2S0_SDIN R339/5 /
TEGRA_GPIO(B, 2) / 10 H2 I2S0_SDOUT R337/4 /
TEGRA_GPIO(B, 3) / 11 G2 I2S0_CLK/SRCLK R334/2 /
TEGRA_GPIO(K, 0) / 80 D13 I2S1_LRCLK/SFSYNC /
TEGRA_GPIO(K, 1) / 81 C14 I2S1_SDIN /
TEGRA_GPIO(K, 2) / 82 D14 I2S1_SDOUT /
TEGRA_GPIO(K, 3) / 83 C15 I2S1_CLK/SRCLK /
TEGRA_GPIO(BB, 0) / 216 F1 AUDIO_MCLK R1/R332/1 */
sound_card: sound {
compatible = “nvidia,tegra-audio-t210ref-mobile-rt565x”;
nvidia,model = “tegra-snd-t210ref-mobile-rt565x”;
clocks = <&tegra_car TEGRA210_CLK_PLL_P_OUT1>,
<&tegra_car TEGRA210_CLK_PLL_A>,
<&tegra_car TEGRA210_CLK_PLL_A_OUT0>,
<&tegra_car TEGRA210_CLK_D_AUDIO>,
<&tegra_car TEGRA210_CLK_CLK_M>,
<&tegra_car TEGRA210_CLK_EXTERN1>;
clock-names = “pll_p_out1”, “pll_a”, “pll_a_out0”, “ahub”,
“clk_m”, “extern1”;
assigned-clocks = <&tegra_car TEGRA210_CLK_PLL_A>,
assigned-clock-rates = <368640000>, <36864000>,
<36864000>, <12288000>;
nvidia,num-codec-link = <2>;
nvidia,audio-routing =
“x Headphone”, “x OUT”,
“x IN”, “x Mic”,
“y Headphone”, “y OUT”,
“y IN”, “y Mic”,
“l Headphone”, “l OUT”,
“l IN”, “l Mic”,
“s Headphone”, “s OUT”,
“s IN”, “s Mic”,
“w Headphone”, “w OUT”,
“w IN”, “w Mic”,
“z IN”, “z Mic”;
nvidia,xbar = <&tegra_axbar>;
/* The codec-dai here is initialized to dummy and will be /
/ replaced with rt565x codec-dai on detecting super-module */
nvidia,dai-link-1 {
link-name = “rt565x-playback”;
cpu-dai = <&tegra_i2s1>;
codec-dai = <&spdif_dit4>;
cpu-dai-name = “I2S1”;
codec-dai-name = “dit-hifi”;
format = “i2s”;
bitclock-master;
frame-master;
bitclock-noninversion;
frame-noninversion;
bit-format = “s16_le”;
bclk_ratio = <2>;
srate = <96000>;
num-channel = <2>;
ignore_suspend;
name-prefix = “y”;
nvidia,dai-link-2 {
link-name = “tas5751-playback”;
cpu-dai = <&tegra_i2s5>;
codec-dai = <&tas5751>;
cpu-dai-name = “I2S5”;
codec-dai-name = “tas5751-speaker”;
format = “i2s”;
bitclock-slave;
frame-slave;
bclk_ratio = <2>;
srate = <96000>;
num-channel = <2>;
ignore_suspend;
name-prefix = “x”;
