I call Nvbufsurface in the all_box_generated function.
Is this function properly configured in relation to NvBufSurface?
void Deepstream_Main::all_bbox_generated (AppCtx * appCtx, GstBuffer * buf, NvDsBatchMeta * batch_meta, guint index)
cv::Mat frame;
std::vector rect_vec;
std::vector tracking_result_vec;
bool isCount = false;
bool isSensing = false;
bool isSensing1 = false;
bool isSensing2 = false;
int direction = 0; // 0 : nothing, 1 : line1, 2 : line2, 3 : line1 & line2 // 0 : nothing, 1 : Enter, 2: Exit
guint num_objects[128];
GstMapInfo in_map_info;
NvBufSurface* surface = NULL;
NvDsFrameMeta *frame_meta = NULL;
//NvBufSurface* copy_surface = NULL;
//NvBufSurfaceCopy(surface,copy_surface);
NvDsDisplayMeta *display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_RectParams *rect_params = display_meta->rect_params;
NvOSD_TextParams *text_params = display_meta->text_params;
NvOSD_LineParams *line_params = display_meta->line_params;
memset (num_objects, 0, sizeof (num_objects));
if(gst_buffer_map(buf, &in_map_info, GST_MAP_READWRITE))
surface = (NvBufSurface *) in_map_info.data;
NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ_WRITE);
NvBufSurfaceSyncForCpu(surface, -1, -1);
//NvBufSurfaceSyncForDevice(copy_surface,0,0);
//NvBufSurfaceCopy(surface, )
for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next)
frame_meta = (NvDsFrameMeta *)(l_frame->data);
gint frame_width = (gint)surface->surfaceList[frame_meta->batch_id].width;
gint frame_height = (gint)surface->surfaceList[frame_meta->batch_id].height;
void *frame_data = surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0];
size_t frame_step = surface->surfaceList[frame_meta->batch_id].pitch;
frame = cv::Mat(frame_height, frame_width, CV_8UC4, frame_data, frame_step);
cv::Mat detectionFrame = cv::Mat::zeros(frame_height, frame_width, CV_8UC1);
cv::cvtColor(frame, frame, cv::COLOR_BGR2RGB);
if(dM->setStart)
for (NvDsMetaList * l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next)
NvDsObjectMeta *obj = (NvDsObjectMeta *) l_obj->data;
cv::Rect rect;
TrackingBox box;
box.type = 10;
QMapIterator<QString, float> iter(dM->globalData->jobInfo->detectionClass);
while(iter.hasNext())
iter.next();
QString name = iter.key();
float confidence = 0;
if (obj->text_params.display_text == name
&& obj->confidence >= confidence)
if (name == "Person" || name == "person"){ box.type = 0;}
else if (name == "Car"){ box.type = 1; }
else if (name == "Truck"){ box.type = 2; }
else if (name == "Bus"){ box.type = 3; }
else{ box.type = 3; }
rect.width = obj->rect_params.width;
rect.height = obj->rect_params.height;
rect.x = obj->rect_params.left;
rect.y = obj->rect_params.top;
box.box = rect;
box.confidence = obj->confidence;
rect_vec.push_back(box);
tracking_result_vec = dM->hanaTracker(rect_vec);
//Draw Object Information
for(int i=0; i<tracking_result_vec.size(); i++)
// Class Name Start
QString s_id = QString::number(tracking_result_vec[i].id);
QString s_type = "Default"; //Type Of Object
switch(tracking_result_vec[i].type)
case 0:
s_type = "Person";
break;
case 1:
s_type = "Car";
break;
case 2:
s_type = "Truck";
break;
case 3:
s_type = "Bus";
break;
default:
s_type = "Default";
break;
s_type += s_id;
cv::putText(frame, s_type.toUtf8().constData(), tracking_result_vec[i].box.tl(), FONT_HERSHEY_COMPLEX, 0.7, cv::Scalar(255,255,255), 1, LINE_AA);
cv::putText(frame, s_type.toUtf8().constData(), tracking_result_vec[i].box.tl(), FONT_HERSHEY_COMPLEX, 0.7, cv::Scalar(62,200,71), 1, LINE_AA);
// Class Name End
// StandardPoint
// vertical_horizontal
// 0 : bottom_center
// 1 : cetner_left
// 2 : top_center
// 3 : cetner_right
// 4 : center_center
// 5 : Left_Bottom = Rect(SignalPed)
cv::Point2f center;
cv::Rect rect;
cv::Point2f rect_center; //ROI center point
float distance_ratio; //ROI weight by distance from camera (based X-axis)
//float
if (dM->globalData->jobInfo->standardPoint == 0)
center.x = tracking_result_vec[i].box.x + (tracking_result_vec[i].box.width / 2);
center.y = tracking_result_vec[i].box.y + (tracking_result_vec[i].box.height);
else if (dM->globalData->jobInfo->standardPoint == 1)
center.x = tracking_result_vec[i].box.x;
center.y = tracking_result_vec[i].box.y + (tracking_result_vec[i].box.height / 2);
else if (dM->globalData->jobInfo->standardPoint == 2)
center.y = tracking_result_vec[i].box.y;
else if (dM->globalData->jobInfo->standardPoint == 3)
center.x = tracking_result_vec[i].box.x + (tracking_result_vec[i].box.width);
else if (dM->globalData->jobInfo->standardPoint == 4)
else if (dM->globalData->jobInfo->standardPoint == 5)
//ROI Area : Rectangle
rect.x = tracking_result_vec[i].box.x + (tracking_result_vec[i].box.width * 1 / 12);
rect.y = tracking_result_vec[i].box.y + (tracking_result_vec[i].box.height * 1 / 12);
rect.width = tracking_result_vec[i].box.width * 1 / 12;
rect.height = tracking_result_vec[i].box.height * 8 / 12;
//Ellipse Center & ROI Center
rect_center.x = rect.x + (rect.width/2);
rect_center.y = rect.y + (rect.height/2);
// x's Per 1 pixel => 0.015625 // 1280 =>
distance_ratio = (100.0 - (rect_center.x * (1.0/(frame_width/20.0))))/100.0;
// StandardPoint End
// draw tracking item
cv::Rect rect_trk = tracking_result_vec[i].box;
cv::circle(frame, center, 2, cv::Scalar(0,128,255), 5);
cv::ellipse(detectionFrame,rect_center,Size(rect.width/2,rect.height/2),0,0,360,cv::Scalar(255),-1);
cv::ellipse(frame,rect_center,Size(rect.width/2,rect.height/2),0,0,360,cv::Scalar(0,255,0),-1);
//Ellipse ROI (applied distance ratio)
cv::ellipse(detectionFrame,rect_center,Size(rect.width/2 * distance_ratio,rect.height/2* distance_ratio),0,0,360,cv::Scalar(255),-1);
cv::ellipse(frame,rect_center,Size(rect.width/2* distance_ratio,rect.height/2* distance_ratio),0,0,360,cv::Scalar(166,97,243),-1);
//Ellipse ROI
//cv::ellipse(detectionFrame,rect_center,Size(rect.width/2,rect.height/2),0,0,360,cv::Scalar(255),-1);
//cv::ellipse(frame,rect_center,Size(rect.width/2,rect.height/2),0,0,360,cv::Scalar(0,255,0),-1);
//Rect ROI
//cv::rectangle(detectionFrame, rect, cv::Scalar(255), -1);
//cv::rectangle(frame, rect, cv::Scalar(166,97,243), -1);
cv::rectangle(frame, rect_trk, cv::Scalar(166,97,243), 2);
// RSTP Drowing
if (dM->isRTSPOriginal == false)
if(display_meta->num_rects < 10)
rect_params[(display_meta->num_rects)].left = tracking_result_vec[i].box.x;
rect_params[(display_meta->num_rects)].top = tracking_result_vec[i].box.y;
rect_params[(display_meta->num_rects)].width = tracking_result_vec[i].box.width;
rect_params[(display_meta->num_rects)].height = tracking_result_vec[i].box.height;
rect_params[(display_meta->num_rects)].border_width = 1;
NvOSD_ColorParams color;
color.alpha = 1.0;
color.blue = 1.0;
color.green = 0.0;
color.red = 1.0;
rect_params[(display_meta->num_rects)].border_color = color;
display_meta->num_rects++;
text_params[display_meta->num_labels].display_text = (gchar*)g_malloc0(6);
snprintf(text_params[display_meta->num_labels].display_text, 6, s_type.toUtf8().constData());
text_params[display_meta->num_labels].x_offset = tracking_result_vec[i].box.x;
text_params[display_meta->num_labels].y_offset = tracking_result_vec[i].box.y-10;
text_params[display_meta->num_labels].font_params.font_name = (gchar*)"Serif";
text_params[display_meta->num_labels].font_params.font_color.red = 1.0;
text_params[display_meta->num_labels].font_params.font_color.green = 1.0;
text_params[display_meta->num_labels].font_params.font_color.blue = 1.0;
text_params[display_meta->num_labels].font_params.font_color.alpha = 1.0;
text_params[display_meta->num_labels].font_params.font_size = 7;
text_params[display_meta->num_labels].set_bg_clr = 1;
text_params[display_meta->num_labels].text_bg_clr.red = 0.0;
text_params[display_meta->num_labels].text_bg_clr.green = 0.0;
text_params[display_meta->num_labels].text_bg_clr.blue = 0.0;
text_params[display_meta->num_labels].text_bg_clr.alpha = 1.0;
display_meta->num_labels++;
// Check - inside
if (dM->globalData->jobInfo->type == "Vehicle")
if (dM->globalData->jobInfo->roi->SensingVehicle(Point(center.x, center.y)))
isSensing = true;
else if (dM->globalData->jobInfo->type == "NonSignalPed")
if (dM->globalData->jobInfo->roi->SensingNonSignalPed(Point(center.x, center.y)))
isSensing = true;
// Check - inside End
// end tracking
if (dM->globalData->jobInfo->type == "SignalPed")
// check intersection
for (int i = 0; i < dM->globalData->jobInfo->roi->lines.size(); i++)
Mat bitwise = (dM->globalData->jobInfo->roi->lines[i] & detectionFrame);
//cv::imshow("bitwise", bitwise);
//cv::waitKey(0);
int count = cv::countNonZero(bitwise);
if (count != 0)
isSensing = true;
if (i == 0)
isSensing1 = true;
else if (i == 1)
isSensing2 = true;
// Draw ROI
//Draw Line End
NvOSD_ColorParams roi_line_color;
if (isSensing)
roi_line_color.alpha = 1.0;
roi_line_color.blue = 0.0;
roi_line_color.green = 1.0;
roi_line_color.red = 0.0;
else
roi_line_color.green = 0.0;
roi_line_color.red = 1.0;
//Draw Line
for (int i = 0; i < dM->globalData->jobInfo->roi->rois[0].size() - 1; i++)
line_params[display_meta->num_lines].x1 = dM->globalData->jobInfo->roi->rois[0][i].x;
line_params[display_meta->num_lines].y1 = dM->globalData->jobInfo->roi->rois[0][i].y;
line_params[display_meta->num_lines].x2 = dM->globalData->jobInfo->roi->rois[0][i + 1].x;
line_params[display_meta->num_lines].y2 = dM->globalData->jobInfo->roi->rois[0][i + 1].y;
line_params[display_meta->num_lines].line_width = 7;
line_params[display_meta->num_lines].line_color = roi_line_color;
display_meta->num_lines++;
dM->globalData->jobInfo->roi->DrawROI_Vehicle(frame, isSensing);
else if (dM->globalData->jobInfo->type == "SignalPed")
for (int i = 0; i < dM->globalData->jobInfo->roi->rois.size(); i++)
for (int j = 0; j <dM->globalData->jobInfo->roi->rois[i].size() - 1; j++)
dM->globalData->jobInfo->roi->DrawROI_SignalPed(frame, isSensing1, isSensing2);
int vector_size = dM->globalData->jobInfo->roi->rois[i].size();
for (int j = 0; j < vector_size; j++)
line_params[display_meta->num_lines].x2 = dM->globalData->jobInfo->roi->rois[0][(i + 1) % vector_size].x;
line_params[display_meta->num_lines].y2 = dM->globalData->jobInfo->roi->rois[0][(i + 1) % vector_size].y;
dM->globalData->jobInfo->roi->DrawROI_NonSignalPed(frame, isSensing);
else
if (isSensing1 == true && isSensing2 == true)
direction = 3;
else if (isSensing1 == true && isSensing2 == false)
direction = 1;
else if (isSensing1 == false && isSensing2 == true)
direction = 2;
else if (isSensing1 == false && isSensing2 == false)
direction = 0;
//qDebug() << direction;
cv::resize(frame, frame, cv::Size(640,360),INTER_LINEAR);
//Video output Save
//dM->writer.write(frame);
emit dM->image_Load_signals(frame, isSensing, direction, dM->countInLine, isCount);
frame.release();
detectionFrame.release();
rect_vec.clear();
tracking_result_vec.clear();
NvBufSurfaceUnMap(surface, -1, -1);
gst_buffer_unmap(buf, &in_map_info);
