Why Jetson nano memory leaks when Deepstream_app is running and the system is also hang?
I’m trying to run Deesptream_app on Jetson nano. It was run perfectly. But my Jetson nano has 4GB Ram and I am using JetPack is 4.2.2, Deepstream SDK is 4.0.1. When Deepstream_app run, my Ram was increase 1.7 GB to 3.7 GB and it was roughly hang my system. I know this is little bit related to FPS. Is there have any solutions and what should I do now?
Thank you.
Hi faravikhantanmoy,
Please try to set max performance mode before running deepstream.
sudo nvpmodel -m 0
sudo jetson_clocks
Hi, carolyuu
Thanks for replay.
I’ve open my ubuntu terminal and put this two command. This command was run. But nothing to improve my system after Deepstream running. It was same performance.
Please share your deepstream pipeline.
And add more detail steps that we can try to reproduce your issue. Thanks!
Thanks carolyuu for replay.
Here is my deepstream_app.c file
 * Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <string.h>
#include <math.h>
#include <stdlib.h>
#include "deepstream_app.h"
#define MAX_DISPLAY_LEN 64
static guint batch_num = 0;
GST_DEBUG_CATEGORY_EXTERN (NVDS_APP);
GQuark _dsmeta_quark;
#define CEIL(a,b) ((a + b - 1) / b)
#define SOURCE_RESET_INTERVAL_IN_MS 60000
 * @brief  Add the (nvmsgconv->nvmsgbroker) sink-bin to the
 *         overall DS pipeline (if any configured) and link the same to
 *         common_elements.tee (This tee connects
 *         the common analytics path to Tiler/display-sink and
 *         to configured broker sink if any)
 *         NOTE: This API shall return TRUE if there are no
 *         broker sinks to add to pipeline
 * @param  appCtx [IN]
 * @return TRUE if succussful; FALSE otherwise
static gboolean add_and_link_broker_sink (AppCtx * appCtx);
 * @brief  Checks if there are any [sink] groups
 *         configured for source_id=provided source_id
 *         NOTE: source_id key and this API is valid only when we
 *         disable [tiler] and thus use demuxer for individual
 *         stream out
 * @param  config [IN] The DS Pipeline configuration struct
 * @param  source_id [IN] Source ID for which a specific [sink]
 *         group is searched for
static gboolean is_sink_available_for_source_id(NvDsConfig *config, guint source_id);
 * Function called at regular interval when one of NV_DS_SOURCE_RTSP type
 * source in the pipeline is down / disconnected. This function try to
 * reconnect the source by resetting that source pipeline.
static gboolean
watch_source_status (gpointer data)
  NvDsSrcBin *src_bin = (NvDsSrcBin *) data;
  g_print ("watch_source_status %s\n", GST_ELEMENT_NAME(src_bin));
  if (src_bin && src_bin->reconfiguring) {
    // source is still not up, reconfigure it again.
    g_timeout_add (20, reset_source_pipeline, src_bin);
    return TRUE;
  } else {
    // source is reconfigured, remove call back.
    return FALSE;
 * callback function to receive messages from components
 * in the pipeline.
static gboolean
bus_callback (GstBus * bus, GstMessage * message, gpointer data)
  AppCtx *appCtx = (AppCtx *) data;
  GST_CAT_DEBUG (NVDS_APP,
      "Received message on bus: source %s, msg_type %s",
      GST_MESSAGE_SRC_NAME (message), GST_MESSAGE_TYPE_NAME (message));
  switch (GST_MESSAGE_TYPE (message)) {
    case GST_MESSAGE_INFO:{
      GError *error = NULL;
      gchar *debuginfo = NULL;
      gst_message_parse_info (message, &error, &debuginfo);
      g_printerr ("INFO from %s: %s\n",
          GST_OBJECT_NAME (message->src), error->message);
      if (debuginfo) {
        g_printerr ("Debug info: %s\n", debuginfo);
      g_error_free (error);
      g_free (debuginfo);
      break;
    case GST_MESSAGE_WARNING:{
      gst_message_parse_warning (message, &error, &debuginfo);
      g_printerr ("WARNING from %s: %s\n",
      if (debuginfo) {
      g_free (debuginfo);
      break;
    case GST_MESSAGE_ERROR:{
      guint i = 0;
      gst_message_parse_error (message, &error, &debuginfo);
      g_printerr ("ERROR from %s: %s\n",
      if (debuginfo) {
      NvDsSrcParentBin *bin = &appCtx->pipeline.multi_src_bin;
      for (i = 0; i < bin->num_bins; i++) {
        if (bin->sub_bins[i].src_elem == (GstElement *) GST_MESSAGE_SRC (message))
          break;
      if ((i != bin->num_bins) &&
          (appCtx->config.multi_source_config[0].type == NV_DS_SOURCE_RTSP)) {
        // Error from one of RTSP source.
        NvDsSrcBin *subBin = &bin->sub_bins[i];
        if (!subBin->reconfiguring ||
            g_strrstr(debuginfo, "500 (Internal Server Error)")) {
          if (!subBin->reconfiguring) {
            // Check status of stream at regular interval.
            g_timeout_add (SOURCE_RESET_INTERVAL_IN_MS,
                           watch_source_status, subBin);
          // Reconfigure the stream.
          subBin->reconfiguring = TRUE;
          g_timeout_add (20, reset_source_pipeline, subBin);
        g_free (debuginfo);
        return TRUE;
      g_free (debuginfo);
      appCtx->return_value = -1;
      appCtx->quit = TRUE;
      break;
    case GST_MESSAGE_STATE_CHANGED:{
      GstState oldstate, newstate;
      gst_message_parse_state_changed (message, &oldstate, &newstate, NULL);
      if (GST_ELEMENT (GST_MESSAGE_SRC (message)) == appCtx->pipeline.pipeline) {
        switch (newstate) {
          case GST_STATE_PLAYING:
            NVGSTDS_INFO_MSG_V ("Pipeline running\n");
            GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->
                    pipeline.pipeline), GST_DEBUG_GRAPH_SHOW_ALL,
                "ds-app-playing");
            break;
          case GST_STATE_PAUSED:
            if (oldstate == GST_STATE_PLAYING) {
              NVGSTDS_INFO_MSG_V ("Pipeline paused\n");
            break;
          case GST_STATE_READY:
            GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->pipeline.
                    pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-ready");
            if (oldstate == GST_STATE_NULL) {
              NVGSTDS_INFO_MSG_V ("Pipeline ready\n");
            } else {
              NVGSTDS_INFO_MSG_V ("Pipeline stopped\n");
            break;
          case GST_STATE_NULL:
            g_mutex_lock (&appCtx->app_lock);
            g_cond_broadcast (&appCtx->app_cond);
            g_mutex_unlock (&appCtx->app_lock);
            break;
          default:
            break;
      break;
    case GST_MESSAGE_EOS:{
       * In normal scenario, this would use g_main_loop_quit() to exit the
       * loop and release the resources. Since this application might be
       * running multiple pipelines through configuration files, it should wait
       * till all pipelines are done.
      NVGSTDS_INFO_MSG_V ("Received EOS. Exiting ...\n");
      return FALSE;
      break;
    default:
      break;
  return TRUE;
static GstBusSyncReply
bus_sync_handler (GstBus * bus, GstMessage * msg, gpointer data)
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_ELEMENT:
      if (GST_MESSAGE_SRC (msg) == GST_OBJECT (appCtx->pipeline.multi_src_bin.bin)) {
        const GstStructure *structure;
        structure = gst_message_get_structure (msg);
       if (gst_structure_has_name (structure, "GstBinForwarded")) {
          GstMessage *child_msg;
          if (gst_structure_has_field (structure, "message")) {
            const GValue *val = gst_structure_get_value (structure, "message");
            if (G_VALUE_TYPE (val) == GST_TYPE_MESSAGE) {
              child_msg = (GstMessage *) g_value_get_boxed (val);
              if (GST_MESSAGE_TYPE(child_msg) == GST_MESSAGE_ASYNC_DONE) {
                guint i = 0;
                GST_DEBUG ("num bins: %d, message src: %s\n", bin->num_bins,
                           GST_MESSAGE_SRC_NAME(child_msg));
                  if (bin->sub_bins[i].bin == (GstElement *) GST_MESSAGE_SRC (child_msg))
                    break;
                if (i != bin->num_bins) {
                  if (subBin->reconfiguring &&
                    g_timeout_add (20, set_source_to_playing, subBin);
      return GST_BUS_PASS;
    default:
 * Function to dump bounding box data in kitti format. For this to work,
 * property "gie-kitti-output-dir" must be set in configuration file.
 * Data of different sources and frames is dumped in separate file.
static void
write_kitti_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
  gchar bbox_file[1024] = { 0 };
  FILE *bbox_params_dump_file = NULL;
  if (!appCtx->config.bbox_dir_path)
    return;
  for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
    NvDsFrameMeta *frame_meta = l_frame->data;
    guint stream_id = frame_meta->pad_index;
    g_snprintf (bbox_file, sizeof (bbox_file) - 1,
        "%s/%02u_%03u_%06lu.txt", appCtx->config.bbox_dir_path,
        appCtx->index, stream_id, (gulong) frame_meta->frame_num);
    bbox_params_dump_file = fopen (bbox_file, "w");
    if (!bbox_params_dump_file)
      continue;
    for (NvDsMetaList * l_obj = frame_meta->obj_meta_list; l_obj != NULL;
        l_obj = l_obj->next) {
      NvDsObjectMeta *obj = (NvDsObjectMeta *) l_obj->data;
      int left = obj->rect_params.left;
      int top = obj->rect_params.top;
      int right = left + obj->rect_params.width;
      int bottom = top + obj->rect_params.height;
      fprintf (bbox_params_dump_file,
          "%s 0.0 0 0.0 %d.00 %d.00 %d.00 %d.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0\n",
          obj->obj_label, left, top, right, bottom);
    fclose (bbox_params_dump_file);
 * Function to dump bounding box data in kitti format with tracking ID added.
 * For this to work, property "kitti-track-output-dir" must be set in configuration file.
static void
write_kitti_track_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
  if (!appCtx->config.kitti_track_dir_path)
    return;
        "%s/%02u_%03u_%06lu.txt", appCtx->config.kitti_track_dir_path,
      continue;
      guint64 id = obj->object_id;
          "%s %lu 0.0 0 0.0 %d.00 %d.00 %d.00 %d.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0\n",
          obj->obj_label, id, left, top, right, bottom);
static gint
component_id_compare_func (gconstpointer a, gconstpointer b)
  NvDsClassifierMeta *cmetaa = (NvDsClassifierMeta *) a;
  NvDsClassifierMeta *cmetab = (NvDsClassifierMeta *) b;
  if (cmetaa->unique_component_id < cmetab->unique_component_id)
    return -1;
  if (cmetaa->unique_component_id > cmetab->unique_component_id)
    return 1;
  return 0;
 * Function to process the attached metadata. This is just for demonstration
 * and can be removed if not required.
 * Here it demonstrates to use bounding boxes of different color and size for
 * different type / class of objects.
 * It also demonstrates how to join the different labels(PGIE + SGIEs)
 * of an object to form a single string.
static void
process_meta (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
  // For single source always display text either with demuxer or with tiler
  if (!appCtx->config.tiled_display_config.enable ||
      appCtx->config.num_source_sub_bins == 1) {
    appCtx->show_bbox_text = 1;
      gint class_index = obj->class_id;
      NvDsGieConfig *gie_config = NULL;
      gchar *str_ins_pos = NULL;
      if (obj->unique_component_id ==
          (gint) appCtx->config.primary_gie_config.unique_id) {
        gie_config = &appCtx->config.primary_gie_config;
      } else {
        for (gint i = 0; i < (gint) appCtx->config.num_secondary_gie_sub_bins;
            i++) {
          gie_config = &appCtx->config.secondary_gie_sub_bin_config[i];
          if (obj->unique_component_id == (gint) gie_config->unique_id) {
            break;
          gie_config = NULL;
      g_free (obj->text_params.display_text);
      obj->text_params.display_text = NULL;
      if (gie_config != NULL) {
        if (g_hash_table_contains (gie_config->bbox_border_color_table,
                class_index + (gchar *) NULL)) {
          obj->rect_params.border_color =
              *((NvOSD_ColorParams *)
              g_hash_table_lookup (gie_config->bbox_border_color_table,
                  class_index + (gchar *) NULL));
        } else {
          obj->rect_params.border_color = gie_config->bbox_border_color;
        obj->rect_params.border_width = appCtx->config.osd_config.border_width;
        if (g_hash_table_contains (gie_config->bbox_bg_color_table,
          obj->rect_params.has_bg_color = 1;
          obj->rect_params.bg_color =
              g_hash_table_lookup (gie_config->bbox_bg_color_table,
        } else {
          obj->rect_params.has_bg_color = 0;
      if (!appCtx->show_bbox_text)
        continue;
      obj->text_params.x_offset = obj->rect_params.left;
      obj->text_params.y_offset = obj->rect_params.top - 30;
      obj->text_params.font_params.font_color =
          appCtx->config.osd_config.text_color;
      obj->text_params.font_params.font_size =
          appCtx->config.osd_config.text_size;
      obj->text_params.font_params.font_name = appCtx->config.osd_config.font;
      if (appCtx->config.osd_config.text_has_bg) {
        obj->text_params.set_bg_clr = 1;
        obj->text_params.text_bg_clr = appCtx->config.osd_config.text_bg_color;
      obj->text_params.display_text = g_malloc (128);
      obj->text_params.display_text[0] = '\0';
      str_ins_pos = obj->text_params.display_text;
      if (obj->obj_label[0] != '\0')
        sprintf (str_ins_pos, "%s", obj->obj_label);
      str_ins_pos += strlen (str_ins_pos);
      if (obj->object_id != UNTRACKED_OBJECT_ID) {
        sprintf (str_ins_pos, " %lu", obj->object_id);
      obj->classifier_meta_list =
          g_list_sort (obj->classifier_meta_list, component_id_compare_func);
      for (NvDsMetaList * l_class = obj->classifier_meta_list; l_class != NULL;
          l_class = l_class->next) {
        NvDsClassifierMeta *cmeta = (NvDsClassifierMeta *) l_class->data;
        for (NvDsMetaList * l_label = cmeta->label_info_list; l_label != NULL;
            l_label = l_label->next) {
          NvDsLabelInfo *label = (NvDsLabelInfo *) l_label->data;
          if (label->pResult_label) {
            sprintf (str_ins_pos, " %s", label->pResult_label);
          } else if (label->result_label[0] != '\0') {
            sprintf (str_ins_pos, " %s", label->result_label);
 * Function which processes the inferred buffer and its metadata.
 * It also gives opportunity to attach application specific
 * metadata (e.g. clock, analytics output etc.).
static void
process_buffer (GstBuffer * buf, AppCtx * appCtx, guint index)
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
  if (!batch_meta) {
    NVGSTDS_WARN_MSG_V ("Batch meta not found for buffer %p", buf);
    return;
  process_meta (appCtx, batch_meta);
  //NvDsInstanceData *data = &appCtx->instance_data[index];
  //guint i;
  //  data->frame_num++;
  /* Opportunity to modify the processed metadata or do analytics based on
   * type of object e.g. maintaining count of particular type of car.
  if (appCtx->all_bbox_generated_cb) {
    appCtx->all_bbox_generated_cb (appCtx, buf, batch_meta, index);
  //data->bbox_list_size = 0;
   * callback to attach application specific additional metadata.
  if (appCtx->overlay_graphics_cb) {
    appCtx->overlay_graphics_cb (appCtx, buf, batch_meta, index);
 * Buffer probe function to get the results of primary infer.
 * Here it demonstrates the use by dumping bounding box coordinates in
 * kitti format.
static GstPadProbeReturn
gie_primary_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  GstBuffer *buf = (GstBuffer *) info->data;
  AppCtx *appCtx = (AppCtx *) u_data;
  if (!batch_meta) {
    return GST_PAD_PROBE_OK;
  write_kitti_output (appCtx, batch_meta);
 * Probe function to get results after all inferences(Primary + Secondary)
 * are done. This will be just before OSD or sink (in case OSD is disabled).
gie_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  NvDsInstanceBin *bin = (NvDsInstanceBin *) u_data;
  guint index = bin->index;
  AppCtx *appCtx = bin->appCtx;
  if (gst_buffer_is_writable (buf))
    process_buffer (buf, appCtx, index);
 * Buffer probe function after tracker.
analytics_done_buf_prob (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  if (!batch_meta) {
   * Output KITTI labels with tracking ID if configured to do so.
  write_kitti_track_output(appCtx, batch_meta);
  if (appCtx->bbox_generated_post_analytics_cb)
    appCtx->bbox_generated_post_analytics_cb (appCtx, buf, batch_meta, index);
latency_measurement_buf_prob(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  guint i = 0, num_sources_in_batch = 0;
  if(nvds_enable_latency_measurement)
    NvDsFrameLatencyInfo *latency_info = NULL;
    g_mutex_lock (&appCtx->latency_lock);
    latency_info = appCtx->latency_info;
    g_print("\n************BATCH-NUM = %d**************\n",batch_num);
    num_sources_in_batch = nvds_measure_buffer_latency(buf, latency_info);
    for(i = 0; i < num_sources_in_batch; i++)
      g_print("Source id = %d Frame_num = %d Frame latency = %lf (ms) \n",
          latency_info[i].source_id,
          latency_info[i].frame_num,
          latency_info[i].latency);
    g_mutex_unlock (&appCtx->latency_lock);
    batch_num++;
static gboolean
  NvDsConfig *config = &appCtx->config;
  /** Only first instance_bin broker sink
   * employed as there's only one analytics path for N sources
   * NOTE: There shall be only one [sink] group
   * with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
   * a) Multiple of them does not make sense as we have only
   * one analytics pipe generating the data for broker sink
   * b) If Multiple broker sinks are configured by the user
   * in config file, only the first in the order of
   * appearance will be considered
   * and others shall be ignored
   * c) Ideally it should be documented (or obvious) that:
   * multiple [sink] groups with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
   * is invalid
  NvDsInstanceBin *instance_bin = &appCtx->pipeline.instance_bins[0];
  NvDsPipeline *pipeline = &appCtx->pipeline;
  for (guint i = 0; i < config->num_sink_sub_bins; i++) {
    if(config->sink_bin_sub_bin_config[i].type == NV_DS_SINK_MSG_CONV_BROKER)
      if(!pipeline->common_elements.tee) {
         NVGSTDS_ERR_MSG_V ("%s failed; broker added without analytics; check config file\n", __func__);
         return FALSE;
      /** add the broker sink bin to pipeline */
      if(!gst_bin_add (GST_BIN (pipeline->pipeline), instance_bin->sink_bin.sub_bins[i].bin)) {
        return FALSE;
      /** link the broker sink bin to the common_elements tee
       * (The tee after nvinfer -> tracker (optional) -> sgies (optional) block) */
      if (!link_element_to_tee_src_pad (pipeline->common_elements.tee, instance_bin->sink_bin.sub_bins[i].bin)) {
        return FALSE;
  return TRUE;
 * Function to add components to pipeline which are dependent on number
 * of streams. These components work on single buffer. If tiling is being
 * used then single instance will be created otherwise < N > such instances
 * will be created for < N > streams
static gboolean
create_processing_instance (AppCtx * appCtx, guint index)
  gboolean ret = FALSE;
  NvDsInstanceBin *instance_bin = &appCtx->pipeline.instance_bins[index];
  GstElement *last_elem;
  gchar elem_name[32];
  instance_bin->index = index;
  instance_bin->appCtx = appCtx;
  g_snprintf (elem_name, 32, "processing_bin_%d", index);
  instance_bin->bin = gst_bin_new (elem_name);
  if (!create_sink_bin (config->num_sink_sub_bins,
        config->sink_bin_sub_bin_config, &instance_bin->sink_bin, index)) {
    goto done;
  gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->sink_bin.bin);
  last_elem = instance_bin->sink_bin.bin;
  if (config->osd_config.enable) {
    if (!create_osd_bin (&config->osd_config, &instance_bin->osd_bin)) {
      goto done;
    gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->osd_bin.bin);
    NVGSTDS_LINK_ELEMENT (instance_bin->osd_bin.bin, last_elem);
    last_elem = instance_bin->osd_bin.bin;
  NVGSTDS_BIN_ADD_GHOST_PAD (instance_bin->bin, last_elem, "sink");
    NVGSTDS_ELEM_ADD_PROBE (instance_bin->all_bbox_buffer_probe_id,
        instance_bin->osd_bin.nvosd, "sink",
        gie_processing_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER, instance_bin);
  } else {
        instance_bin->sink_bin.bin, "sink",
  ret = TRUE;
done:
  if (!ret) {
    NVGSTDS_ERR_MSG_V ("%s failed", __func__);
  return ret;
 * Function to create common elements(Primary infer, tracker, secondary infer)
 * of the pipeline. These components operate on muxed data from all the
 * streams. So they are independent of number of streams in the pipeline.
static gboolean
create_common_elements (NvDsConfig * config, NvDsPipeline * pipeline,
    GstElement ** sink_elem, GstElement ** src_elem,
    bbox_generated_callback bbox_generated_post_analytics_cb)
  *sink_elem = *src_elem = NULL;
  if (config->primary_gie_config.enable) {
    if (config->num_secondary_gie_sub_bins > 0) {
      if (!create_secondary_gie_bin (config->num_secondary_gie_sub_bins,
              config->primary_gie_config.unique_id,
              config->secondary_gie_sub_bin_config,
              &pipeline->common_elements.secondary_gie_bin)) {
        goto done;
          pipeline->common_elements.secondary_gie_bin.bin);
      if (!*src_elem) {
        *src_elem = pipeline->common_elements.secondary_gie_bin.bin;
      if (*sink_elem) {
        NVGSTDS_LINK_ELEMENT (pipeline->common_elements.secondary_gie_bin.bin,
            *sink_elem);
      *sink_elem = pipeline->common_elements.secondary_gie_bin.bin;
  if (config->tracker_config.enable) {
    if (!create_tracking_bin (&config->tracker_config,
            &pipeline->common_elements.tracker_bin)) {
      g_print ("creating tracker bin failed\n");
      goto done;
        pipeline->common_elements.tracker_bin.bin);
    if (!*src_elem) {
      *src_elem = pipeline->common_elements.tracker_bin.bin;
    if (*sink_elem) {
      NVGSTDS_LINK_ELEMENT (pipeline->common_elements.tracker_bin.bin,
          *sink_elem);
    *sink_elem = pipeline->common_elements.tracker_bin.bin;
    if (!create_primary_gie_bin (&config->primary_gie_config,
            &pipeline->common_elements.primary_gie_bin)) {
      goto done;
        pipeline->common_elements.primary_gie_bin.bin);
    if (*sink_elem) {
      NVGSTDS_LINK_ELEMENT (pipeline->common_elements.primary_gie_bin.bin,
          *sink_elem);
    *sink_elem = pipeline->common_elements.primary_gie_bin.bin;
    if (!*src_elem) {
      *src_elem = pipeline->common_elements.primary_gie_bin.bin;
    NVGSTDS_ELEM_ADD_PROBE (pipeline->common_elements.
        primary_bbox_buffer_probe_id,
        pipeline->common_elements.primary_gie_bin.bin, "src",
        gie_primary_processing_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
        pipeline->common_elements.appCtx);
  if(*src_elem) {
          *src_elem, "src",
          analytics_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
          &pipeline->common_elements);
    pipeline->common_elements.tee = gst_element_factory_make (NVDS_ELEM_TEE, "common_analytics_tee");
    if (!pipeline->common_elements.tee) {
      NVGSTDS_ERR_MSG_V ("Failed to create element 'common_analytics_tee'");
      goto done;
          pipeline->common_elements.tee);
    NVGSTDS_LINK_ELEMENT (*src_elem, pipeline->common_elements.tee);
    *src_elem = pipeline->common_elements.tee;
  ret = TRUE;
done:
  return ret;
static gboolean is_sink_available_for_source_id(NvDsConfig *config, guint source_id) {
  for (guint j = 0; j < config->num_sink_sub_bins; j++) {
    if (config->sink_bin_sub_bin_config[j].enable &&
        config->sink_bin_sub_bin_config[j].source_id == source_id) {
      return TRUE;
  return FALSE;
 * Main function to create the pipeline.
gboolean
create_pipeline (AppCtx * appCtx,
    bbox_generated_callback bbox_generated_post_analytics_cb,
    bbox_generated_callback all_bbox_generated_cb, perf_callback perf_cb,
    overlay_graphics_callback overlay_graphics_cb)
  GstBus *bus;
  GstElement *tmp_elem1;
  GstElement *tmp_elem2;
  guint i;
  GstPad *fps_pad;
  gulong latency_probe_id;
  _dsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
  appCtx->all_bbox_generated_cb = all_bbox_generated_cb;
  appCtx->bbox_generated_post_analytics_cb = bbox_generated_post_analytics_cb;
  appCtx->overlay_graphics_cb = overlay_graphics_cb;
  if (config->osd_config.num_out_buffers < 8) {
    config->osd_config.num_out_buffers = 8;
  pipeline->pipeline = gst_pipeline_new ("pipeline");
  if (!pipeline->pipeline) {
    NVGSTDS_ERR_MSG_V ("Failed to create pipeline");
    goto done;
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline->pipeline));
  pipeline->bus_id = gst_bus_add_watch (bus, bus_callback, appCtx);
  gst_bus_set_sync_handler (bus, bus_sync_handler, appCtx, NULL);
  gst_object_unref (bus);
  if (config->file_loop) {
    /* Let each source bin know it needs to loop. */
    guint i;
    for (i = 0; i < config->num_source_sub_bins; i++)
        config->multi_source_config[i].loop = TRUE;
    NvDsSinkSubBinConfig *sink_config = &config->sink_bin_sub_bin_config[i];
    switch (sink_config->type) {
      case NV_DS_SINK_FAKE:
      case NV_DS_SINK_RENDER_EGL:
      case NV_DS_SINK_RENDER_OVERLAY:
        /* Set the "qos" property of sink, if not explicitly specified in the
           config. */
        if (!sink_config->render_config.qos_value_specified) {
          /* QoS events should be generated by sink always in case of live sources
             or with synchronous playback for non-live sources. */
          if (config->streammux_config.live_source || sink_config->render_config.sync) {
            sink_config->render_config.qos = TRUE;
          } else {
            sink_config->render_config.qos = FALSE;
      default:
        break;
  /** Register multi_src_bin specific callbacks if any */
  pipeline->multi_src_bin.rtcp_sender_report_cb = appCtx->rtcp_sender_report_cb;
   * Add muxer and < N > source components to the pipeline based
   * on the settings in configuration file.
  if (!create_multi_source_bin (config->num_source_sub_bins,
          config->multi_source_config, &pipeline->multi_src_bin))
    goto done;
  gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->multi_src_bin.bin);
if (config->streammux_config.is_parsed)
    set_streammux_properties (&config->streammux_config,
        pipeline->multi_src_bin.streammux);
  if(appCtx->latency_info == NULL)
    appCtx->latency_info = (NvDsFrameLatencyInfo *)
      calloc(1, config->streammux_config.batch_size *
          sizeof(NvDsFrameLatencyInfo));
  if (config->tiled_display_config.enable) {
    /* Tiler will generate a single composited buffer for all sources. So need
     * to create only one processing instance. */
    if (!create_processing_instance (appCtx, 0)) {
      goto done;
    // create and add tiling component to pipeline.
    if (config->tiled_display_config.columns *
        config->tiled_display_config.rows < config->num_source_sub_bins) {
      if (config->tiled_display_config.columns == 0) {
            (guint) (sqrt (config->num_source_sub_bins) + 0.5);
      config->tiled_display_config.rows =
          (guint) ceil (1.0 * config->num_source_sub_bins /
          config->tiled_display_config.columns);
      NVGSTDS_WARN_MSG_V
          ("Num of Tiles less than number of sources, readjusting to "
          "%u rows, %u columns", config->tiled_display_config.rows,
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->instance_bins[0].bin);
    last_elem = pipeline->instance_bins[0].bin;
    if (!create_tiled_display_bin (&config->tiled_display_config,
            &pipeline->tiled_display_bin)) {
      goto done;
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiled_display_bin.bin);
    NVGSTDS_LINK_ELEMENT (pipeline->tiled_display_bin.bin, last_elem);
    last_elem = pipeline->tiled_display_bin.bin;
  } else {
     * Create demuxer only if tiled display is disabled.
    pipeline->demuxer =
        gst_element_factory_make (NVDS_ELEM_STREAM_DEMUX, "demuxer");
    if (!pipeline->demuxer) {
      NVGSTDS_ERR_MSG_V ("Failed to create element 'demuxer'");
      goto done;
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->demuxer);
    for (i = 0; i < config->num_source_sub_bins; i++) {
      gchar pad_name[16];
      GstPad *demux_src_pad;
      /* Check if any sink has been configured to render/encode output for
       * source index `i`. The processing instance for that source will be
       * created only if atleast one sink has been configured as such.
      if (!is_sink_available_for_source_id(config, i))
        continue;
      if (!create_processing_instance (appCtx, i)) {
        goto done;
          pipeline->instance_bins[i].bin);
      g_snprintf (pad_name, 16, "src_%02d", i);
      demux_src_pad = gst_element_get_request_pad (pipeline->demuxer, pad_name);
      NVGSTDS_LINK_ELEMENT_FULL (pipeline->demuxer, pad_name,
          pipeline->instance_bins[i].bin, "sink");
      gst_object_unref (demux_src_pad);
    last_elem = pipeline->demuxer;
  fps_pad = gst_element_get_static_pad (last_elem, "sink");
  pipeline->common_elements.appCtx = appCtx;
  // Decide where in the pipeline the element should be added and add only if
  // enabled
  if (config->dsexample_config.enable) {
    // Create dsexample element bin and set properties
    if (!create_dsexample_bin (&config->dsexample_config,
            &pipeline->dsexample_bin)) {
      goto done;
    // Add dsexample bin to instance bin
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->dsexample_bin.bin);
    // Link this bin to the last element in the bin
    NVGSTDS_LINK_ELEMENT (pipeline->dsexample_bin.bin, last_elem);
    // Set this bin as the last element
    last_elem = pipeline->dsexample_bin.bin;
  // create and add common components to pipeline.
  if (!create_common_elements (config, pipeline, &tmp_elem1, &tmp_elem2,
          bbox_generated_post_analytics_cb)) {
    goto done;
  if(!add_and_link_broker_sink(appCtx)) {
    goto done;
  if (tmp_elem2) {
    NVGSTDS_LINK_ELEMENT (tmp_elem2, last_elem);
    last_elem = tmp_elem1;
  NVGSTDS_LINK_ELEMENT (pipeline->multi_src_bin.bin, last_elem);
  // enable performance measurement and add call back function to receive
  // performance data.
  if (config->enable_perf_measurement) {
    appCtx->perf_struct.context = appCtx;
    enable_perf_measurement (&appCtx->perf_struct, fps_pad,
        pipeline->multi_src_bin.num_bins,
        config->perf_measurement_interval_sec, perf_cb);
  //gst_object_unref (fps_pad);
  NVGSTDS_ELEM_ADD_PROBE (latency_probe_id,
      pipeline->instance_bins->sink_bin.sub_bins[0].sink, "sink",
      latency_measurement_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
      appCtx);
  latency_probe_id = latency_probe_id;
  GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->pipeline.pipeline),
      GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-null");
  g_mutex_init (&appCtx->app_lock);
  g_cond_init (&appCtx->app_cond);
  g_mutex_init (&appCtx->latency_lock);
  ret = TRUE;
done:
  if (!ret) {
  return ret;
 * Function to destroy pipeline and release the resources, probes etc.
void
destroy_pipeline (AppCtx * appCtx)
  gint64 end_time;
  guint i;
  GstBus *bus = NULL;
  end_time = g_get_monotonic_time () + G_TIME_SPAN_SECOND;
  if (!appCtx)
    return;
  if (appCtx->pipeline.demuxer) {
    gst_pad_send_event (gst_element_get_static_pad (appCtx->pipeline.demuxer,
            "sink"), gst_event_new_eos ());
  } else if (appCtx->pipeline.instance_bins[0].sink_bin.bin) {
            pipeline.instance_bins[0].sink_bin.bin, "sink"),
  g_usleep (100000);
  if (appCtx->pipeline.pipeline) {
    bus = gst_pipeline_get_bus (GST_PIPELINE (appCtx->pipeline.pipeline));
    while (TRUE) {
      GstMessage *message = gst_bus_pop (bus);
      if (message == NULL)
        break;
      else if (GST_MESSAGE_TYPE (message) == GST_MESSAGE_ERROR)
        bus_callback (bus, message, appCtx);
      else
        gst_message_unref (message);
    gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_NULL);
  g_cond_wait_until (&appCtx->app_cond, &appCtx->app_lock, end_time);
  for (i = 0; i < appCtx->config.num_source_sub_bins; i++) {
    NvDsInstanceBin *bin = &appCtx->pipeline.instance_bins[i];
      NVGSTDS_ELEM_REMOVE_PROBE (bin->all_bbox_buffer_probe_id,
          bin->osd_bin.nvosd, "sink");
    } else {
          bin->sink_bin.bin, "sink");
      NVGSTDS_ELEM_REMOVE_PROBE (bin->primary_bbox_buffer_probe_id,
          bin->primary_gie_bin.bin, "src");
    free(appCtx->latency_info);
    appCtx->latency_info = NULL;
  g_mutex_clear(&appCtx->latency_lock);
    gst_bus_remove_watch (bus);
    gst_object_unref (appCtx->pipeline.pipeline);
gboolean
pause_pipeline (AppCtx * appCtx)
  GstState cur;
  GstState pending;
  GstStateChangeReturn ret;
  GstClockTime timeout = 5 * GST_SECOND / 1000;
  ret =
      gst_element_get_state (appCtx->pipeline.pipeline, &cur, &pending,
      timeout);
  if (ret == GST_STATE_CHANGE_ASYNC) {
    return FALSE;
  if (cur == GST_STATE_PAUSED) {
    return TRUE;
  } else if (cur == GST_STATE_PLAYING) {
    gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_PAUSED);
        GST_CLOCK_TIME_NONE);
    pause_perf_measurement (&appCtx->perf_struct);
    return TRUE;
  } else {
    return FALSE;
gboolean
resume_pipeline (AppCtx * appCtx)
  GstState cur;
  GstState pending;
  ret =
      timeout);
    return FALSE;
    return TRUE;
  } else if (cur == GST_STATE_PAUSED) {
    gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_PLAYING);
    resume_perf_measurement (&appCtx->perf_struct);
    return TRUE;
  } else {
    return FALSE;
Here is my deepstream_app_config_parser.c file:
#include <string.h>
#include "deepstream_config_file_parser.h"
#define CONFIG_GROUP_APP "application"
#define CONFIG_GROUP_APP_ENABLE_PERF_MEASUREMENT "enable-perf-measurement"
#define CONFIG_GROUP_APP_PERF_MEASUREMENT_INTERVAL "perf-measurement-interval-sec"
#define CONFIG_GROUP_APP_GIE_OUTPUT_DIR "gie-kitti-output-dir"
#define CONFIG_GROUP_APP_GIE_TRACK_OUTPUT_DIR "kitti-track-output-dir"
#define CONFIG_GROUP_TESTS "tests"
#define CONFIG_GROUP_TESTS_FILE_LOOP "file-loop"
GST_DEBUG_CATEGORY_EXTERN (APP_CFG_PARSER_CAT);
#define CHECK_ERROR(error) \
    if (error) { \
        GST_CAT_ERROR (APP_CFG_PARSER_CAT, "%s", error->message); \
        goto done; \
static gboolean
parse_tests (NvDsConfig *config, GKeyFile *key_file)
  gchar **keys = NULL;
  gchar **key = NULL;
  keys = g_key_file_get_keys (key_file, CONFIG_GROUP_TESTS, NULL, &error);
  CHECK_ERROR (error);
  for (key = keys; *key; key++) {
    if (!g_strcmp0 (*key, CONFIG_GROUP_TESTS_FILE_LOOP)) {
      config->file_loop =
          g_key_file_get_integer (key_file, CONFIG_GROUP_TESTS,
          CONFIG_GROUP_TESTS_FILE_LOOP, &error);
    } else {
      NVGSTDS_WARN_MSG_V ("Unknown key '%s' for group [%s]", *key,
          CONFIG_GROUP_TESTS);
  ret = TRUE;
done:
  if (error) {
  if (keys) {
    g_strfreev (keys);
  if (!ret) {
  return ret;
static gboolean
parse_app (NvDsConfig *config, GKeyFile *key_file, gchar *cfg_file_path)
  gchar **key = NULL;
  keys = g_key_file_get_keys (key_file, CONFIG_GROUP_APP, NULL, &error);
    if (!g_strcmp0 (*key, CONFIG_GROUP_APP_ENABLE_PERF_MEASUREMENT)) {
      config->enable_perf_measurement =
          g_key_file_get_integer (key_file, CONFIG_GROUP_APP,
          CONFIG_GROUP_APP_ENABLE_PERF_MEASUREMENT, &error);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_APP_PERF_MEASUREMENT_INTERVAL)) {
      config->perf_measurement_interval_sec =
          CONFIG_GROUP_APP_PERF_MEASUREMENT_INTERVAL, &error);
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_APP_GIE_OUTPUT_DIR)) {
      config->bbox_dir_path = get_absolute_file_path (cfg_file_path,
          g_key_file_get_string (key_file, CONFIG_GROUP_APP,
          CONFIG_GROUP_APP_GIE_OUTPUT_DIR, &error));
    } else if (!g_strcmp0 (*key, CONFIG_GROUP_APP_GIE_TRACK_OUTPUT_DIR)) {
      config->kitti_track_dir_path = get_absolute_file_path (cfg_file_path,
          CONFIG_GROUP_APP_GIE_TRACK_OUTPUT_DIR, &error));
    } else {
                          CONFIG_GROUP_APP);
  ret = TRUE;
done:
  if (error) {
  if (keys) {
    g_strfreev (keys);
  if (!ret) {
  return ret;
gboolean
parse_config_file (NvDsConfig *config, gchar *cfg_file_path)
  GKeyFile *cfg_file = g_key_file_new ();
  gchar **groups = NULL;
  gchar **group;
  guint i, j;
  if (!APP_CFG_PARSER_CAT) {
    GST_DEBUG_CATEGORY_INIT (APP_CFG_PARSER_CAT, "NVDS_CFG_PARSER", 0, NULL);
  if (!g_key_file_load_from_file (cfg_file, cfg_file_path, G_KEY_FILE_NONE,
          &error)) {
    GST_CAT_ERROR (APP_CFG_PARSER_CAT, "Failed to load uri file: %s",
        error->message);
    goto done;
  groups = g_key_file_get_groups (cfg_file, NULL);
  for (group = groups; *group; group++) {
    gboolean parse_err = FALSE;
    GST_CAT_DEBUG (APP_CFG_PARSER_CAT, "Parsing group: %s", *group);
    if (!g_strcmp0 (*group, CONFIG_GROUP_APP)) {
      parse_err = !parse_app (config, cfg_file, cfg_file_path);
    if (!strncmp (*group, CONFIG_GROUP_SOURCE, sizeof (CONFIG_GROUP_SOURCE) - 1)) {
      if (config->num_source_sub_bins == MAX_SOURCE_BINS) {
        NVGSTDS_ERR_MSG_V ("App supports max %d sources", MAX_SOURCE_BINS);
        ret = FALSE;
        goto done;
      parse_err = !parse_source (&config->multi_source_config[config->num_source_sub_bins],
                                 cfg_file, *group, cfg_file_path);
      if (config->multi_source_config[config->num_source_sub_bins].enable) {
        config->num_source_sub_bins++;
    if (!g_strcmp0 (*group, CONFIG_GROUP_STREAMMUX)) {
      parse_err = !parse_streammux (&config->streammux_config, cfg_file);
    if (!g_strcmp0 (*group, CONFIG_GROUP_OSD)) {
      parse_err = !parse_osd (&config->osd_config, cfg_file);
    if (!g_strcmp0 (*group, CONFIG_GROUP_PRIMARY_GIE)) {
      parse_err =
          !parse_gie (&config->primary_gie_config, cfg_file,
          CONFIG_GROUP_PRIMARY_GIE, cfg_file_path);
    if (!g_strcmp0 (*group, CONFIG_GROUP_TRACKER)) {
      parse_err = !parse_tracker (&config->tracker_config, cfg_file, cfg_file_path);
    if (!strncmp (*group, CONFIG_GROUP_SECONDARY_GIE,
                  sizeof (CONFIG_GROUP_SECONDARY_GIE) - 1)) {
      if (config->num_secondary_gie_sub_bins == MAX_SECONDARY_GIE_BINS) {
        NVGSTDS_ERR_MSG_V ("App supports max %d secondary GIEs", MAX_SECONDARY_GIE_BINS);
        ret = FALSE;
        goto done;
      parse_err =
          !parse_gie (&config->secondary_gie_sub_bin_config[config->
                                  num_secondary_gie_sub_bins],
      if (config->secondary_gie_sub_bin_config[config->num_secondary_gie_sub_bins].enable){
        config->num_secondary_gie_sub_bins++;
    if (!strncmp (*group, CONFIG_GROUP_SINK, sizeof (CONFIG_GROUP_SINK) - 1)) {
      if (config->num_sink_sub_bins == MAX_SINK_BINS) {
        NVGSTDS_ERR_MSG_V ("App supports max %d sinks", MAX_SINK_BINS);
        ret = FALSE;
        goto done;
      parse_err =
          !parse_sink (&config->
          sink_bin_sub_bin_config[config->num_sink_sub_bins], cfg_file, *group,
          cfg_file_path);
      if (config->
          sink_bin_sub_bin_config[config->num_sink_sub_bins].enable){
        config->num_sink_sub_bins++;
    if (!g_strcmp0 (*group, CONFIG_GROUP_TILED_DISPLAY)) {
      parse_err = !parse_tiled_display (&config->tiled_display_config, cfg_file);
    if (!g_strcmp0 (*group, CONFIG_GROUP_DSEXAMPLE)) {
      parse_err = !parse_dsexample (&config->dsexample_config, cfg_file);
    if (!g_strcmp0 (*group, CONFIG_GROUP_TESTS)) {
      parse_err = !parse_tests (config, cfg_file);
    if (parse_err) {
      GST_CAT_ERROR (APP_CFG_PARSER_CAT, "Failed to parse '%s' group", *group);
      goto done;
  for (i = 0; i < config->num_secondary_gie_sub_bins; i++) {
    if (config->secondary_gie_sub_bin_config[i].unique_id ==
        config->primary_gie_config.unique_id) {
      NVGSTDS_ERR_MSG_V ("Non unique gie ids found");
      ret = FALSE;
      goto done;
    for (j = i + 1; j < config->num_secondary_gie_sub_bins; j++) {
          config->secondary_gie_sub_bin_config[j].unique_id) {
        NVGSTDS_ERR_MSG_V ("Non unique gie id %d found",
                            config->secondary_gie_sub_bin_config[i].unique_id);
        ret = FALSE;
        goto done;
    if (config->multi_source_config[i].type == NV_DS_SOURCE_URI_MULTIPLE) {
      if (config->multi_source_config[i].num_sources < 1) {
        config->multi_source_config[i].num_sources = 1;
      for (j = 1; j < config->multi_source_config[i].num_sources; j++) {
          ret = FALSE;
          goto done;
        memcpy (&config->multi_source_config[config->num_source_sub_bins],
            &config->multi_source_config[i],
            sizeof (config->multi_source_config[i]));
        config->multi_source_config[config->num_source_sub_bins].type = NV_DS_SOURCE_URI;
        config->multi_source_config[config->num_source_sub_bins].uri =
          g_strdup_printf (config->multi_source_config[config->num_source_sub_bins].uri, j);
      config->multi_source_config[i].type = NV_DS_SOURCE_URI;
      config->multi_source_config[i].uri =
        g_strdup_printf (config->multi_source_config[i].uri, 0);
  ret = TRUE;
done:
  if (cfg_file) {
    g_key_file_free (cfg_file);
  if (groups) {
    g_strfreev (groups);
  if (error) {
  if (!ret) {
  return ret;
Here is my deepstream_app_main.c file:
#include "nvds_version.h"
#include <string.h>
#include <unistd.h>
#include <termios.h>
#include <X11/Xlib.h>
#include <X11/Xutil.h>
#define MAX_INSTANCES 128
#define APP_TITLE "DeepStream"
#define DEFAULT_X_WINDOW_WIDTH 1920
#define DEFAULT_X_WINDOW_HEIGHT 1080
AppCtx *appCtx[MAX_INSTANCES];
static guint cintr = FALSE;
static GMainLoop *main_loop = NULL;
static gchar **cfg_files = NULL;
static gchar **input_files = NULL;
static gboolean print_version = FALSE;
static gboolean show_bbox_text = FALSE;
static gboolean print_dependencies_version = FALSE;
static gboolean quit = FALSE;
static gint return_value = 0;
static guint num_instances;
static guint num_input_files;
static GMutex fps_lock;
static gdouble fps[MAX_SOURCE_BINS];
static gdouble fps_avg[MAX_SOURCE_BINS];
static guint num_fps_inst = 0;
static Display *display = NULL;
static Window windows[MAX_INSTANCES] = { 0 };
static gint source_ids[MAX_INSTANCES];
static GThread *x_event_thread = NULL;
static GMutex disp_lock;
GST_DEBUG_CATEGORY (NVDS_APP);
GOptionEntry entries[] = {
  {"version", 'v', 0, G_OPTION_ARG_NONE, &print_version,
      "Print DeepStreamSDK version", NULL}
  {"tiledtext", 't', 0, G_OPTION_ARG_NONE, &show_bbox_text,
      "Display Bounding box labels in tiled mode", NULL}
  {"version-all", 0, 0, G_OPTION_ARG_NONE, &print_dependencies_version,
      "Print DeepStreamSDK and dependencies version", NULL}
  {"cfg-file", 'c', 0, G_OPTION_ARG_FILENAME_ARRAY, &cfg_files,
      "Set the config file", NULL}
  {"input-file", 'i', 0, G_OPTION_ARG_FILENAME_ARRAY, &input_files,
      "Set the input file", NULL}
  {NULL}
 * Callback function to be called once all inferences (Primary + Secondary)
 * are done. This is opportunity to modify content of the metadata.
 * e.g. Here Person is being replaced with Man/Woman and corresponding counts
 * are being maintained. It should be modified according to network classes
 * or can be removed altogether if not required.
static void
all_bbox_generated (AppCtx * appCtx, GstBuffer * buf,
    NvDsBatchMeta * batch_meta, guint index)
  guint num_male = 0;
  guint num_female = 0;
  guint num_objects[128];
  memset (num_objects, 0, sizeof (num_objects));
        if (obj->class_id >= 0 && obj->class_id < 128) {
          num_objects[obj->class_id]++;
        if (appCtx->person_class_id > -1
            && obj->class_id == appCtx->person_class_id) {
          if (strstr (obj->text_params.display_text, "Man")) {
            str_replace (obj->text_params.display_text, "Man", "");
            str_replace (obj->text_params.display_text, "Person", "Man");
            num_male++;
          } else if (strstr (obj->text_params.display_text, "Woman")) {
            str_replace (obj->text_params.display_text, "Woman", "");
            str_replace (obj->text_params.display_text, "Person", "Woman");
            num_female++;
 * Function to handle program interrupt signal.
 * It installs default handler after handling the interrupt.
static void
_intr_handler (int signum)
  struct sigaction action;
  NVGSTDS_ERR_MSG_V ("User Interrupted.. \n");
  memset (&action, 0, sizeof (action));
  action.sa_handler = SIG_DFL;
  sigaction (SIGINT, &action, NULL);
  cintr = TRUE;
 * callback function to print the performance numbers of each stream.
static void
perf_cb (gpointer context, NvDsAppPerfStruct * str)
  static guint header_print_cnt = 0;
  guint i;
  AppCtx *appCtx = (AppCtx *) context;
  guint numf = (num_instances == 1) ? str->num_instances : num_instances;
  g_mutex_lock (&fps_lock);
  if (num_instances > 1) {
    fps[appCtx->index] = str->fps[0];
    fps_avg[appCtx->index] = str->fps_avg[0];
  } else {
    for (i = 0; i < numf; i++) {
      fps[i] = str->fps[i];
      fps_avg[i] = str->fps_avg[i];
  num_fps_inst++;
  if (num_fps_inst < num_instances) {
    g_mutex_unlock (&fps_lock);
    return;
  num_fps_inst = 0;
  if (header_print_cnt % 20 == 0) {
    g_print ("\n**PERF: ");
      g_print ("FPS %d (Avg)\t", i);
    g_print ("\n");
  header_print_cnt++;
  g_print ("**PERF: ");
    g_print ("%.2f (%.2f)\t", fps[i], fps_avg[i]);
  g_print ("\n");
 * Loop function to check the status of interrupts.
 * It comes out of loop if application got interrupted.
static gboolean
check_for_interrupt (gpointer data)
  if (quit) {
    return FALSE;
  if (cintr) {
    cintr = FALSE;
    quit = TRUE;
    g_main_loop_quit (main_loop);
    return FALSE;
  return TRUE;
 * Function to install custom handler for program interrupt signal.
static void
_intr_setup (void)
  action.sa_handler = _intr_handler;
static gboolean
kbhit (void)
  struct timeval tv;
  fd_set rdfs;
  tv.tv_sec = 0;
  tv.tv_usec = 0;
  FD_ZERO (&rdfs);
  FD_SET (STDIN_FILENO, &rdfs);
  select (STDIN_FILENO + 1, &rdfs, NULL, NULL, &tv);
  return FD_ISSET (STDIN_FILENO, &rdfs);
 * Function to enable / disable the canonical mode of terminal.
 * In non canonical mode input is available immediately (without the user
 * having to type a line-delimiter character).
static void
changemode (int dir)
  static struct termios oldt, newt;
  if (dir == 1) {
    tcgetattr (STDIN_FILENO, &oldt);
    newt = oldt;
    newt.c_lflag &= ~(ICANON);
    tcsetattr (STDIN_FILENO, TCSANOW, &newt);
  } else
    tcsetattr (STDIN_FILENO, TCSANOW, &oldt);
static void
print_runtime_commands (void)
  g_print ("\nRuntime commands:\n"
      "\th: Print this help\n"
      "\tq: Quit\n\n" "\tp: Pause\n" "\tr: Resume\n\n");
  if (appCtx[0]->config.tiled_display_config.enable) {
    g_print
        ("NOTE: To expand a source in the 2D tiled display and view object details,"
        " left-click on the source.\n"
        "      To go back to the tiled display, right-click anywhere on the window.\n\n");
static guint rrow, rcol;
static gboolean rrowsel = FALSE, selecting = FALSE;
 * Loop function to check keyboard inputs and status of each pipeline.
static gboolean
event_thread_func (gpointer arg)
  guint i;
  gboolean ret = TRUE;
  // Check if all instances have quit
  for (i = 0; i < num_instances; i++) {
    if (!appCtx[i]->quit)
      break;
  if (i == num_instances) {
    quit = TRUE;
    return FALSE;
  // Check for keyboard input
  if (!kbhit ()) {
    //continue;
    return TRUE;
  int c = fgetc (stdin);
  g_print ("\n");
  gint source_id;
  GstElement *tiler = appCtx[0]->pipeline.tiled_display_bin.tiler;
  g_object_get (G_OBJECT (tiler), "show-source", &source_id, NULL);
  if (selecting) {
    if (rrowsel == FALSE) {
      if (c >= '0' && c <= '9') {
        rrow = c - '0';
        if (rrow < appCtx[0]->config.tiled_display_config.rows){
          g_print ("--selecting source  row %d--\n", rrow);
          rrowsel = TRUE;
        }else{
          g_print ("--selected source  row %d out of bound, reenter\n", rrow);
    } else {
        unsigned int tile_num_columns = appCtx[0]->config.tiled_display_config.columns;
        rcol = c - '0';
        if (rcol < tile_num_columns){
          selecting = FALSE;
          rrowsel = FALSE;
          source_id = tile_num_columns * rrow + rcol;
          g_print ("--selecting source  col %d sou=%d--\n", rcol, source_id);
          if (source_id >= (gint) appCtx[0]->config.num_source_sub_bins) {
            source_id = -1;
          } else {
            source_ids[0] = source_id;
            appCtx[0]->show_bbox_text = TRUE;
            g_object_set (G_OBJECT (tiler), "show-source", source_id
Please zip all c files and attach it so that we can simply replace the original c files and rebuild deepstream-app. Please also share which config file you run. Thanks.
Thanks DaneLLL for replay.
Actually I’ve installed jetson_clock.sh, and also open my terminal and put on this command
sudo nvpmodel -m 0
sudo jetson_clocks
There have no improve of my system.
Here is my zip file from google drive link which is contain my all c file and config file.
https://drive.google.com/open?id=1lMsLmvMD4C7TOMpHeiAhakTz10UJ37Wi
Thank you.
Tried to replaced your all files and rebuild the deepstream-app, we can’t reproduce system hang and RAM get high issue.
Below is our test FPS, result looks good.
**PERF: FPS 0 (Avg)	FPS 1 (Avg)	FPS 2 (Avg)	FPS 3 (Avg)	FPS 4 (Avg)	FPS 5 (Avg)	FPS 6 (Avg)	FPS 7 (Avg)
**PERF: 34.92 (34.92)	34.93 (34.93)	34.92 (34.92)	34.60 (34.60)	34.31 (34.31)	35.27 (35.27)	34.93 (34.93)	35.27 (35.27)
**PERF: 35.28 (35.24)	35.28 (35.24)	35.28 (35.24)	35.28 (35.20)	35.28 (35.16)	35.28 (35.27)	35.28 (35.24)	35.28 (35.27)
**PERF: 35.28 (35.25)	35.28 (35.25)	35.28 (35.25)	35.28 (35.24)	35.28 (35.22)	35.28 (35.28)	35.28 (35.25)	35.28 (35.28)
**PERF: 35.38 (35.30)	35.38 (35.30)	35.38 (35.30)	35.38 (35.28)	35.38 (35.27)	35.38 (35.31)	35.38 (35.30)	35.38 (35.31)
**PERF: 35.44 (35.33)	35.44 (35.33)	35.44 (35.33)	35.44 (35.32)	35.44 (35.31)	35.44 (35.34)	35.44 (35.33)	35.44 (35.34)
**PERF: 35.49 (35.36)	35.49 (35.36)	35.49 (35.36)	35.49 (35.36)	35.49 (35.35)	35.49 (35.37)	35.49 (35.36)	35.49 (35.37)
**PERF: 35.29 (35.35)	35.29 (35.35)	35.29 (35.35)	35.29 (35.35)	35.29 (35.34)	35.29 (35.36)	35.29 (35.35)	35.29 (35.36)
**PERF: 35.58 (35.38)	35.58 (35.38)	35.58 (35.38)	35.58 (35.38)	35.58 (35.37)	35.58 (35.39)	35.58 (35.38)	35.58 (35.39)
**PERF: 35.61 (35.41)	35.61 (35.41)	35.61 (35.41)	35.61 (35.41)	35.61 (35.40)	35.61 (35.42)	35.61 (35.41)	35.61 (35.42)
Test with JetPack-4.2.2 + DS-4.0.1 on Jetson-Nano A02.
Thanks DaneLLL and carolyuu,
After reinstall deepstream app (.Deb) file on my jetson nano, the problem is solved.
