Hardware Specifications :
Deepstream Version - 5.1
I’m trying to run a deepstream config file using deepstream-app with Face detector as primary model and some custom secondary models along with NVDCF tracker.
I have attached my deepstream_app.c and the config used to run below:
deepstream_app.c
* Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <string.h>
#include <math.h>
#include <stdlib.h>
#include <cuda_runtime_api.h>
#include <time.h>
#include <unistd.h>
#include <stdio.h>
#include <glib.h>
#include <sys/time.h>
#include "deepstream_app.h"
// For JSON Header
#include "parson.h"
//Redis
#include <hiredis/hiredis.h>
#define MAX 100
#include "gstnvdsmeta.h"
#define PGIE_CLASS_ID_FACE 0
#define MAX_DISPLAY_LEN 64
static guint batch_num = 0;
static guint demux_batch_num = 0;
GST_DEBUG_CATEGORY_EXTERN (NVDS_APP);
GQuark _dsmeta_quark;
#define CEIL(a,b) ((a + b - 1) / b)
* @brief Add the (nvmsgconv->nvmsgbroker) sink-bin to the
* overall DS pipeline (if any configured) and link the same to
* common_elements.tee (This tee connects
* the common analytics path to Tiler/display-sink and
* to configured broker sink if any)
* NOTE: This API shall return TRUE if there are no
* broker sinks to add to pipeline
* @param appCtx [IN]
* @return TRUE if succussful; FALSE otherwise
static gboolean add_and_link_broker_sink (AppCtx * appCtx);
* @brief Checks if there are any [sink] groups
* configured for source_id=provided source_id
* NOTE: source_id key and this API is valid only when we
* disable [tiler] and thus use demuxer for individual
* stream out
* @param config [IN] The DS Pipeline configuration struct
* @param source_id [IN] Source ID for which a specific [sink]
* group is searched for
static gboolean is_sink_available_for_source_id(NvDsConfig *config, guint source_id);
* callback function to receive messages from components
* in the pipeline.
char* camID = "FaceCam";
char* EBDID = "GLUECKBOX001";
char *trackID;
char *timestamp;
char uniqueTrackID[1000];
gint frame_number = 0;
//Object Structure
struct ObjectList
struct timeval start_time;
struct timeval end_time;
int meta;
char UID[1000]; //Change the buffer size accoring to the machine
char age_group_label[50];
char gender_label[50];
char emotion_label[50];
struct ObjectList *next;
struct ObjectList *current_objects = NULL;
struct ObjectList *current_objects_current = NULL;
struct ObjectList * get_object(struct ObjectList *current_objects, int new_id) {
for(struct ObjectList* tmp=current_objects; tmp != NULL; tmp=tmp->next) {
if(tmp->meta == new_id) {
return tmp;
return NULL;
// //Check and set end_time
void set_data_for_objects_no_longer_in_current_frame(int current_frame_obj_ids[], struct ObjectList *current_objects, int n, struct timeval ct) {
int curr_id = tmp->meta;
bool found = false;
for(int i=0; i < n; i++) {
if(current_frame_obj_ids[i] == curr_id) {
found = true;
// printf("Found:%d\n", found);
//FaceLoss
if(!found ) {
// tmp->has_set_end_time = true;
// printf("Loss Id: %d\n",tmp->meta);
// Unique TrackID
// if (asprintf(&trackID, "%d", tmp->meta ) == -1) {
// perror("asprintf");
// else if(asprintf(×tamp, "%d", tmp->start_time.tv_sec ) == -1){
// else {
// strcat(strcpy(uniqueTrackID, timestamp),"_");
// strcat(uniqueTrackID,camID);
// strcat(uniqueTrackID,"_");
// strcat(uniqueTrackID,EBDID);
// strcat(uniqueTrackID, trackID);
// printf("TRACKID : %s\n", uniqueTrackID);
// free(trackID);
// free(timestamp);
// JSON Value after Face Loss
JSON_Value *root_value = json_value_init_object();
JSON_Object *root_object = json_value_get_object(root_value);
char *obj_json = NULL;
json_object_set_string(root_object, "EBDID", EBDID);
json_object_set_number(root_object, "FID", tmp->meta);
json_object_set_string(root_object, "Gender", tmp->gender_label);
json_object_set_string(root_object, "Age", tmp->age_group_label);
json_object_set_string(root_object, "Emotion", tmp->emotion_label);
json_object_set_number(root_object, "Atttime", tmp->end_time.tv_sec - tmp->start_time.tv_sec);
json_object_set_string(root_object, "CamID", camID);
json_object_set_number(root_object, "Start_Time", tmp->start_time.tv_sec);
json_object_set_number(root_object, "End_Time", tmp->end_time.tv_sec);
// json_object_set_string(root_object, "TrackID", uniqueTrackID);
json_object_set_string(root_object, "TrackID", tmp->UID);
obj_json = json_serialize_to_string_pretty(root_value);
// puts(obj_json);
// printf("JSON:%s\n", obj_json);
// Sending Json to Redis
redisContext *context;
redisReply *reply;
context = redisConnect("127.0.0.1", 6379);
// if (!context) {
// fprintf(stderr, "Error: Can't connect to Redis after face loss\n");
// else{
// fprintf(stdout, "Success: Redis Connected after face loss\n");
char key[MAX];
// sprintf(key, "glueck-DS-v1-analytics_%s",uniqueTrackID);
sprintf(key, "glueck-DS-v1-analytics_%s",tmp->UID);
reply = redisCommand(context, "SET %s %s", key, obj_json);
json_free_serialized_string(obj_json);
json_value_free(root_value);
void print_current_objects(struct ObjectList *current_objects) {
printf("Object id: %d\n", tmp->meta);
printf("UniqueTrackID: %s\n",tmp->UID);
printf("Start time: %lu\n", tmp->start_time.tv_sec);
printf("End time: %lu\n", tmp->end_time.tv_sec);
printf("Age : %s\n",tmp->age_group_label);
printf("Emotion : %s\n",tmp->emotion_label);
printf("Gender : %s\n",tmp->gender_label);
int Atttime = tmp->end_time.tv_sec - tmp->start_time.tv_sec;
printf("Attention Time : %u\n\n",Atttime);
static gboolean
bus_callback (GstBus * bus, GstMessage * message, gpointer data)
AppCtx *appCtx = (AppCtx *) data;
GST_CAT_DEBUG (NVDS_APP,
"Received message on bus: source %s, msg_type %s",
GST_MESSAGE_SRC_NAME (message), GST_MESSAGE_TYPE_NAME (message));
switch (GST_MESSAGE_TYPE (message)) {
case GST_MESSAGE_INFO:{
GError *error = NULL;
gchar *debuginfo = NULL;
gst_message_parse_info (message, &error, &debuginfo);
g_printerr ("INFO from %s: %s\n",
GST_OBJECT_NAME (message->src), error->message);
if (debuginfo) {
g_printerr ("Debug info: %s\n", debuginfo);
g_error_free (error);
g_free (debuginfo);
break;
case GST_MESSAGE_WARNING:{
gst_message_parse_warning (message, &error, &debuginfo);
g_printerr ("WARNING from %s: %s\n",
if (debuginfo) {
g_free (debuginfo);
break;
case GST_MESSAGE_ERROR:{
guint i = 0;
gst_message_parse_error (message, &error, &debuginfo);
g_printerr ("ERROR from %s: %s\n",
if (debuginfo) {
NvDsSrcParentBin *bin = &appCtx->pipeline.multi_src_bin;
GstElement *msg_src_elem = (GstElement *) GST_MESSAGE_SRC (message);
gboolean bin_found = FALSE;
/* Find the source bin which generated the error. */
while (msg_src_elem && !bin_found) {
for (i = 0; i < bin->num_bins && !bin_found; i++) {
if (bin->sub_bins[i].src_elem == msg_src_elem ||
bin->sub_bins[i].bin == msg_src_elem) {
bin_found = TRUE;
break;
msg_src_elem = GST_ELEMENT_PARENT (msg_src_elem);
if ((i != bin->num_bins) &&
(appCtx->config.multi_source_config[0].type == NV_DS_SOURCE_RTSP)) {
// Error from one of RTSP source.
NvDsSrcBin *subBin = &bin->sub_bins[i];
if (!subBin->reconfiguring ||
g_strrstr(debuginfo, "500 (Internal Server Error)")) {
subBin->reconfiguring = TRUE;
g_timeout_add (0, reset_source_pipeline, subBin);
g_free (debuginfo);
return TRUE;
if (appCtx->config.multi_source_config[0].type == NV_DS_SOURCE_CAMERA_V4L2) {
if (g_strrstr(debuginfo, "reason not-negotiated (-4)")) {
NVGSTDS_INFO_MSG_V ("incorrect camera parameters provided, please provide supported resolution and frame rate\n");
if (g_strrstr(debuginfo, "Buffer pool activation failed")) {
NVGSTDS_INFO_MSG_V ("usb bandwidth might be saturated\n");
g_free (debuginfo);
appCtx->return_value = -1;
appCtx->quit = TRUE;
break;
case GST_MESSAGE_STATE_CHANGED:{
GstState oldstate, newstate;
gst_message_parse_state_changed (message, &oldstate, &newstate, NULL);
if (GST_ELEMENT (GST_MESSAGE_SRC (message)) == appCtx->pipeline.pipeline) {
switch (newstate) {
case GST_STATE_PLAYING:
NVGSTDS_INFO_MSG_V ("Pipeline running\n");
GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->
pipeline.pipeline), GST_DEBUG_GRAPH_SHOW_ALL,
"ds-app-playing");
break;
case GST_STATE_PAUSED:
if (oldstate == GST_STATE_PLAYING) {
NVGSTDS_INFO_MSG_V ("Pipeline paused\n");
break;
case GST_STATE_READY:
GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->pipeline.
pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-ready");
if (oldstate == GST_STATE_NULL) {
NVGSTDS_INFO_MSG_V ("Pipeline ready\n");
} else {
NVGSTDS_INFO_MSG_V ("Pipeline stopped\n");
break;
case GST_STATE_NULL:
g_mutex_lock (&appCtx->app_lock);
g_cond_broadcast (&appCtx->app_cond);
g_mutex_unlock (&appCtx->app_lock);
break;
default:
break;
break;
case GST_MESSAGE_EOS:{
* In normal scenario, this would use g_main_loop_quit() to exit the
* loop and release the resources. Since this application might be
* running multiple pipelines through configuration files, it should wait
* till all pipelines are done.
NVGSTDS_INFO_MSG_V ("Received EOS. Exiting ...\n");
return FALSE;
break;
default:
break;
return TRUE;
* Function to dump bounding box data in kitti format. For this to work,
* property "gie-kitti-output-dir" must be set in configuration file.
* Data of different sources and frames is dumped in separate file.
static void
write_kitti_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
gchar bbox_file[1024] = { 0 };
FILE *bbox_params_dump_file = NULL;
if (!appCtx->config.bbox_dir_path)
return;
for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = l_frame->data;
guint stream_id = frame_meta->pad_index;
g_snprintf (bbox_file, sizeof (bbox_file) - 1,
"%s/%02u_%03u_%06lu.txt", appCtx->config.bbox_dir_path,
appCtx->index, stream_id, (gulong) frame_meta->frame_num);
bbox_params_dump_file = fopen (bbox_file, "w");
if (!bbox_params_dump_file)
continue;
for (NvDsMetaList * l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
NvDsObjectMeta *obj = (NvDsObjectMeta *) l_obj->data;
float left = obj->rect_params.left;
float top = obj->rect_params.top;
float right = left + obj->rect_params.width;
float bottom = top + obj->rect_params.height;
// Here confidence stores detection confidence, since dump gie output
// is before tracker plugin
float confidence = obj->confidence;
fprintf (bbox_params_dump_file,
"%s 0.0 0 0.0 %f %f %f %f 0.0 0.0 0.0 0.0 0.0 0.0 0.0 %f\n",
obj->obj_label, left, top, right, bottom, confidence);
fclose (bbox_params_dump_file);
* Function to dump past frame objs in kitti format.
static void
write_kitti_past_track_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
if (!appCtx->config.kitti_track_dir_path)
return;
// dump past frame tracked objects appending current frame objects
NvDsPastFrameObjBatch *pPastFrameObjBatch = NULL;
NvDsUserMetaList *bmeta_list = NULL;
NvDsUserMeta *user_meta = NULL;
for(bmeta_list=batch_meta->batch_user_meta_list; bmeta_list!=NULL; bmeta_list=bmeta_list->next){
user_meta = (NvDsUserMeta *)bmeta_list->data;
if(user_meta && user_meta->base_meta.meta_type==NVDS_TRACKER_PAST_FRAME_META){
pPastFrameObjBatch = (NvDsPastFrameObjBatch *) (user_meta->user_meta_data);
for (uint si=0; si < pPastFrameObjBatch->numFilled; si++){
NvDsPastFrameObjStream *objStream = (pPastFrameObjBatch->list) + si;
guint stream_id = (guint)(objStream->streamID);
for (uint li=0; li<objStream->numFilled; li++){
NvDsPastFrameObjList *objList = (objStream->list) + li;
for (uint oi=0; oi<objList->numObj; oi++) {
NvDsPastFrameObj *obj = (objList->list) + oi;
"%s/%02u_%03u_%06lu.txt", appCtx->config.kitti_track_dir_path,
appCtx->index, stream_id, (gulong) obj->frameNum);
float left = obj->tBbox.left;
float right = left + obj->tBbox.width;
float top = obj->tBbox.top;
float bottom = top + obj->tBbox.height;
// Past frame object confidence given by tracker
bbox_params_dump_file = fopen (bbox_file, "a");
if (!bbox_params_dump_file){
continue;
fprintf(bbox_params_dump_file,
"%s %lu 0.0 0 0.0 %f %f %f %f 0.0 0.0 0.0 0.0 0.0 0.0 0.0 %f\n",
objList->objLabel, objList->uniqueId, left, top, right, bottom, confidence);
* Function to dump bounding box data in kitti format with tracking ID added.
* For this to work, property "kitti-track-output-dir" must be set in configuration file.
static void
write_kitti_track_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
return;
continue;
float left = obj->tracker_bbox_info.org_bbox_coords.left;
float top = obj->tracker_bbox_info.org_bbox_coords.top;
float right = left + obj->tracker_bbox_info.org_bbox_coords.width;
float bottom = top + obj->tracker_bbox_info.org_bbox_coords.height;
// Here confidence stores tracker confidence value for tracker output
float confidence = obj->tracker_confidence;
guint64 id = obj->object_id;
obj->obj_label, id, left, top, right, bottom, confidence);
static gint
component_id_compare_func (gconstpointer a, gconstpointer b)
NvDsClassifierMeta *cmetaa = (NvDsClassifierMeta *) a;
NvDsClassifierMeta *cmetab = (NvDsClassifierMeta *) b;
if (cmetaa->unique_component_id < cmetab->unique_component_id)
return -1;
if (cmetaa->unique_component_id > cmetab->unique_component_id)
return 1;
return 0;
* Function to process the attached metadata. This is just for demonstration
* and can be removed if not required.
* Here it demonstrates to use bounding boxes of different color and size for
* different type / class of objects.
* It also demonstrates how to join the different labels(PGIE + SGIEs)
* of an object to form a single string.
static void
process_meta (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
// For single source always display text either with demuxer or with tiler
if (!appCtx->config.tiled_display_config.enable ||
appCtx->config.num_source_sub_bins == 1) {
appCtx->show_bbox_text = 1;
gint class_index = obj->class_id;
NvDsGieConfig *gie_config = NULL;
gchar *str_ins_pos = NULL;
if (obj->unique_component_id ==
(gint) appCtx->config.primary_gie_config.unique_id) {
gie_config = &appCtx->config.primary_gie_config;
} else {
for (gint i = 0; i < (gint) appCtx->config.num_secondary_gie_sub_bins;
i++) {
gie_config = &appCtx->config.secondary_gie_sub_bin_config[i];
if (obj->unique_component_id == (gint) gie_config->unique_id) {
break;
gie_config = NULL;
g_free (obj->text_params.display_text);
obj->text_params.display_text = NULL;
if (gie_config != NULL) {
if (g_hash_table_contains (gie_config->bbox_border_color_table,
class_index + (gchar *) NULL)) {
obj->rect_params.border_color =
*((NvOSD_ColorParams *)
g_hash_table_lookup (gie_config->bbox_border_color_table,
class_index + (gchar *) NULL));
} else {
obj->rect_params.border_color = gie_config->bbox_border_color;
obj->rect_params.border_width = appCtx->config.osd_config.border_width;
if (g_hash_table_contains (gie_config->bbox_bg_color_table,
obj->rect_params.has_bg_color = 1;
obj->rect_params.bg_color =
g_hash_table_lookup (gie_config->bbox_bg_color_table,
} else {
obj->rect_params.has_bg_color = 0;
if (!appCtx->show_bbox_text)
continue;
obj->text_params.x_offset = obj->rect_params.left;
obj->text_params.y_offset = obj->rect_params.top - 30;
obj->text_params.font_params.font_color =
appCtx->config.osd_config.text_color;
obj->text_params.font_params.font_size =
appCtx->config.osd_config.text_size;
obj->text_params.font_params.font_name = appCtx->config.osd_config.font;
if (appCtx->config.osd_config.text_has_bg) {
obj->text_params.set_bg_clr = 1;
obj->text_params.text_bg_clr = appCtx->config.osd_config.text_bg_color;
obj->text_params.display_text = g_malloc (128);
obj->text_params.display_text[0] = '\0';
str_ins_pos = obj->text_params.display_text;
if (obj->obj_label[0] != '\0')
sprintf (str_ins_pos, "%s", obj->obj_label);
str_ins_pos += strlen (str_ins_pos);
if (obj->object_id != UNTRACKED_OBJECT_ID) {
/** object_id is a 64-bit sequential value;
* but considering the display aesthetic,
* trimming to lower 32-bits */
if (appCtx->config.tracker_config.display_tracking_id) {
guint64 const LOW_32_MASK = 0x00000000FFFFFFFF;
sprintf (str_ins_pos, " %lu", (obj->object_id & LOW_32_MASK));
obj->classifier_meta_list =
g_list_sort (obj->classifier_meta_list, component_id_compare_func);
for (NvDsMetaList * l_class = obj->classifier_meta_list; l_class != NULL;
l_class = l_class->next) {
NvDsClassifierMeta *cmeta = (NvDsClassifierMeta *) l_class->data;
for (NvDsMetaList * l_label = cmeta->label_info_list; l_label != NULL;
l_label = l_label->next) {
NvDsLabelInfo *label = (NvDsLabelInfo *) l_label->data;
if (label->pResult_label) {
sprintf (str_ins_pos, " %s", label->pResult_label);
} else if (label->result_label[0] != '\0') {
sprintf (str_ins_pos, " %s", label->result_label);
* Function which processes the inferred buffer and its metadata.
* It also gives opportunity to attach application specific
* metadata (e.g. clock, analytics output etc.).
static void
process_buffer (GstBuffer * buf, AppCtx * appCtx, guint index)
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
if (!batch_meta) {
NVGSTDS_WARN_MSG_V ("Batch meta not found for buffer %p", buf);
return;
process_meta (appCtx, batch_meta);
//NvDsInstanceData *data = &appCtx->instance_data[index];
//guint i;
// data->frame_num++;
/* Opportunity to modify the processed metadata or do analytics based on
* type of object e.g. maintaining count of particular type of car.
if (appCtx->all_bbox_generated_cb) {
appCtx->all_bbox_generated_cb (appCtx, buf, batch_meta, index);
//data->bbox_list_size = 0;
* callback to attach application specific additional metadata.
if (appCtx->overlay_graphics_cb) {
appCtx->overlay_graphics_cb (appCtx, buf, batch_meta, index);
* Buffer probe function to get the results of primary infer.
* Here it demonstrates the use by dumping bounding box coordinates in
* kitti format.
static GstPadProbeReturn
gie_primary_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
AppCtx *appCtx = (AppCtx *) u_data;
if (!batch_meta) {
return GST_PAD_PROBE_OK;
write_kitti_output (appCtx, batch_meta);
* Probe function to get results after all inferences(Primary + Secondary)
* are done. This will be just before OSD or sink (in case OSD is disabled).
gie_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
NvDsInstanceBin *bin = (NvDsInstanceBin *) u_data;
guint index = bin->index;
AppCtx *appCtx = bin->appCtx;
if (gst_buffer_is_writable (buf))
process_buffer (buf, appCtx, index);
* Buffer probe function after tracker.
analytics_done_buf_prob (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
guint num_rects = 0;
NvDsObjectMeta *obj_meta = NULL;
guint face_count = 0;
guint id;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsDisplayMeta *display_meta = NULL;
NvDsClassifierMetaList *l_classifier = NULL;
NvDsClassifierMeta *class_meta = NULL;
NvDsLabelInfoList *l_label = NULL;
NvDsLabelInfo *label_info = NULL;
int current_device = -1;
cudaGetDevice(¤t_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device);
struct timeval current_time;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
int offset = 0;
int obj_ids[50];
int current_pos = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == PGIE_CLASS_ID_FACE) {
face_count++;
num_rects++;
// *** GCE-DS-BLOCK ***
id = obj_meta->object_id;
obj_ids[current_pos] = id;
current_pos++;
// int cc = 0;
char age_group[50]={""};
char gender[50]={""};
char emotion[50]={""};
for(l_classifier = obj_meta->classifier_meta_list; l_classifier != NULL;
l_classifier = l_classifier->next) {
class_meta = (NvDsClassifierMeta *)(l_classifier->data);
//UID for Age,Gender,Emotion
int uniqueClassID = class_meta->unique_component_id;
for(l_label = class_meta->label_info_list; l_label != NULL;
label_info = (NvDsLabelInfo *) (l_label->data);
// g_print ("******************FRAME START********************************* \n");
// g_print ("FrameNo:%d \n",frame_number);
// g_print("%d", id);
// g_print("-------");
// g_print ("%s\n", label_info->result_label);
if (uniqueClassID==3)
strcpy(age_group,label_info->result_label);
else if (uniqueClassID==4)
strcpy(emotion,label_info->result_label);
else if (uniqueClassID==2)
strcpy(gender,label_info->result_label);
// cc ++;
struct ObjectList * res = get_object(current_objects, id);
gettimeofday(¤t_time, NULL);
if(!res) {
// Object doesn't exist
struct ObjectList *new_node = (struct ObjectList *) malloc(sizeof(struct ObjectList));
//StartTime and EndTime for frames
new_node->start_time = current_time;
new_node->end_time = current_time;
// new_node->has_set_end_time = false;
new_node->meta = id;
// Unique TrackID
if (asprintf(&trackID, "%d", obj_meta->object_id ) == -1) {
perror("asprintf");
else if(asprintf(×tamp, "%d", new_node->start_time) == -1){
perror("asprintf");
else {
strcpy(new_node->UID, uniqueTrackID);
free(trackID);
free(timestamp);
strcpy(new_node->age_group_label, age_group);
strcpy(new_node->emotion_label, emotion);
strcpy(new_node->gender_label, gender);
if(current_objects_current == NULL) {
current_objects_current = new_node;
current_objects = current_objects_current;
} else {
current_objects_current->next = new_node;
current_objects_current = current_objects_current->next;
} else {
res->end_time= current_time;
strcpy(res->age_group_label, age_group);
strcpy(res->emotion_label, emotion);
strcpy(res->gender_label, gender);
struct timeval ct = current_time;
set_data_for_objects_no_longer_in_current_frame(obj_ids, current_objects, current_pos, ct);
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params[0];
display_meta->num_labels = 1;
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Face = %d \n", face_count);
offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "FrameNumber = %d ", frame_number);
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Serif";
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
if (!batch_meta) {
* Output KITTI labels with tracking ID if configured to do so.
write_kitti_track_output(appCtx, batch_meta);
if (appCtx->config.tracker_config.enable_past_frame)
write_kitti_past_track_output (appCtx, batch_meta);
if (appCtx->bbox_generated_post_analytics_cb)
appCtx->bbox_generated_post_analytics_cb (appCtx, buf, batch_meta, index);
// print_current_objects(current_objects);
// g_print ("Frame Number = %d Number of objects = %d "
// "Face Count = %d Timestamp = %d \n",
// frame_number, num_rects, face_count, (int)time(NULL));
// g_print ("**********************FRAME END***************************** \n");
frame_number++;
latency_measurement_buf_prob(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
guint i = 0, num_sources_in_batch = 0;
if(nvds_enable_latency_measurement)
NvDsFrameLatencyInfo *latency_info = NULL;
g_mutex_lock (&appCtx->latency_lock);
latency_info = appCtx->latency_info;
g_print("\n************BATCH-NUM = %d**************\n",batch_num);
num_sources_in_batch = nvds_measure_buffer_latency(buf, latency_info);
for(i = 0; i < num_sources_in_batch; i++)
g_print("Source id = %d Frame_num = %d Frame latency = %lf (ms) \n",
latency_info[i].source_id,
latency_info[i].frame_num,
latency_info[i].latency);
g_mutex_unlock (&appCtx->latency_lock);
batch_num++;
demux_latency_measurement_buf_prob(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
g_print("\n************DEMUX BATCH-NUM = %d**************\n",demux_batch_num);
demux_batch_num++;
static gboolean
NvDsConfig *config = &appCtx->config;
/** Only first instance_bin broker sink
* employed as there's only one analytics path for N sources
* NOTE: There shall be only one [sink] group
* with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
* a) Multiple of them does not make sense as we have only
* one analytics pipe generating the data for broker sink
* b) If Multiple broker sinks are configured by the user
* in config file, only the first in the order of
* appearance will be considered
* and others shall be ignored
* c) Ideally it should be documented (or obvious) that:
* multiple [sink] groups with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
* is invalid
NvDsInstanceBin *instance_bin = &appCtx->pipeline.instance_bins[0];
NvDsPipeline *pipeline = &appCtx->pipeline;
for (guint i = 0; i < config->num_sink_sub_bins; i++) {
if(config->sink_bin_sub_bin_config[i].type == NV_DS_SINK_MSG_CONV_BROKER)
if(!pipeline->common_elements.tee) {
NVGSTDS_ERR_MSG_V ("%s failed; broker added without analytics; check config file\n", __func__);
return FALSE;
/** add the broker sink bin to pipeline */
if(!gst_bin_add (GST_BIN (pipeline->pipeline), instance_bin->sink_bin.sub_bins[i].bin)) {
return FALSE;
/** link the broker sink bin to the common_elements tee
* (The tee after nvinfer -> tracker (optional) -> sgies (optional) block) */
if (!link_element_to_tee_src_pad (pipeline->common_elements.tee, instance_bin->sink_bin.sub_bins[i].bin)) {
return FALSE;
return TRUE;
static gboolean
create_demux_pipeline (AppCtx * appCtx, guint index)
gboolean ret = FALSE;
NvDsInstanceBin *instance_bin = &appCtx->pipeline.demux_instance_bins[index];
GstElement *last_elem;
gchar elem_name[32];
instance_bin->index = index;
instance_bin->appCtx = appCtx;
g_snprintf (elem_name, 32, "processing_demux_bin_%d", index);
instance_bin->bin = gst_bin_new (elem_name);
if (!create_demux_sink_bin (config->num_sink_sub_bins,
config->sink_bin_sub_bin_config, &instance_bin->demux_sink_bin,
config->sink_bin_sub_bin_config[index].source_id)) {
goto done;
gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->demux_sink_bin.bin);
last_elem = instance_bin->demux_sink_bin.bin;
if (config->osd_config.enable) {
if (!create_osd_bin (&config->osd_config, &instance_bin->osd_bin)) {
goto done;
gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->osd_bin.bin);
NVGSTDS_LINK_ELEMENT (instance_bin->osd_bin.bin, last_elem);
last_elem = instance_bin->osd_bin.bin;
NVGSTDS_BIN_ADD_GHOST_PAD (instance_bin->bin, last_elem, "sink");
NVGSTDS_ELEM_ADD_PROBE (instance_bin->all_bbox_buffer_probe_id,
instance_bin->osd_bin.nvosd, "sink",
gie_processing_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER, instance_bin);
} else {
instance_bin->demux_sink_bin.bin, "sink",
ret = TRUE;
done:
if (!ret) {
NVGSTDS_ERR_MSG_V ("%s failed", __func__);
return ret;
* Function to add components to pipeline which are dependent on number
* of streams. These components work on single buffer. If tiling is being
* used then single instance will be created otherwise < N > such instances
* will be created for < N > streams
static gboolean
create_processing_instance (AppCtx * appCtx, guint index)
NvDsInstanceBin *instance_bin = &appCtx->pipeline.instance_bins[index];
g_snprintf (elem_name, 32, "processing_bin_%d", index);
if (!create_sink_bin (config->num_sink_sub_bins,
config->sink_bin_sub_bin_config, &instance_bin->sink_bin, index)) {
goto done;
gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->sink_bin.bin);
last_elem = instance_bin->sink_bin.bin;
goto done;
} else {
instance_bin->sink_bin.bin, "sink",
ret = TRUE;
done:
if (!ret) {
return ret;
* Function to create common elements(Primary infer, tracker, secondary infer)
* of the pipeline. These components operate on muxed data from all the
* streams. So they are independent of number of streams in the pipeline.
static gboolean
create_common_elements (NvDsConfig * config, NvDsPipeline * pipeline,
GstElement ** sink_elem, GstElement ** src_elem,
bbox_generated_callback bbox_generated_post_analytics_cb)
*sink_elem = *src_elem = NULL;
if (config->primary_gie_config.enable) {
if (config->num_secondary_gie_sub_bins > 0) {
if (!create_secondary_gie_bin (config->num_secondary_gie_sub_bins,
config->primary_gie_config.unique_id,
config->secondary_gie_sub_bin_config,
&pipeline->common_elements.secondary_gie_bin)) {
goto done;
pipeline->common_elements.secondary_gie_bin.bin);
if (!*src_elem) {
*src_elem = pipeline->common_elements.secondary_gie_bin.bin;
if (*sink_elem) {
NVGSTDS_LINK_ELEMENT (pipeline->common_elements.secondary_gie_bin.bin,
*sink_elem);
*sink_elem = pipeline->common_elements.secondary_gie_bin.bin;
if (config->dsanalytics_config.enable) {
// Create dsanalytics element bin and set properties
if (!create_dsanalytics_bin (&config->dsanalytics_config,
&pipeline->common_elements.dsanalytics_bin)) {
g_print ("creating dsanalytics bin failed\n");
goto done;
// Add dsanalytics bin to instance bin
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->common_elements.dsanalytics_bin.bin);
if (!*src_elem) {
*src_elem = pipeline->common_elements.dsanalytics_bin.bin;
if (*sink_elem) {
NVGSTDS_LINK_ELEMENT (pipeline->common_elements.dsanalytics_bin.bin,
*sink_elem);
// Set this bin as the last element
*sink_elem = pipeline->common_elements.dsanalytics_bin.bin;
if (config->tracker_config.enable) {
if (!create_tracking_bin (&config->tracker_config,
&pipeline->common_elements.tracker_bin)) {
g_print ("creating tracker bin failed\n");
goto done;
pipeline->common_elements.tracker_bin.bin);
if (!*src_elem) {
*src_elem = pipeline->common_elements.tracker_bin.bin;
if (*sink_elem) {
NVGSTDS_LINK_ELEMENT (pipeline->common_elements.tracker_bin.bin,
*sink_elem);
*sink_elem = pipeline->common_elements.tracker_bin.bin;
if (!create_primary_gie_bin (&config->primary_gie_config,
&pipeline->common_elements.primary_gie_bin)) {
goto done;
pipeline->common_elements.primary_gie_bin.bin);
if (*sink_elem) {
NVGSTDS_LINK_ELEMENT (pipeline->common_elements.primary_gie_bin.bin,
*sink_elem);
*sink_elem = pipeline->common_elements.primary_gie_bin.bin;
if (!*src_elem) {
*src_elem = pipeline->common_elements.primary_gie_bin.bin;
NVGSTDS_ELEM_ADD_PROBE (pipeline->common_elements.
primary_bbox_buffer_probe_id,
pipeline->common_elements.primary_gie_bin.bin, "src",
gie_primary_processing_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
pipeline->common_elements.appCtx);
if(*src_elem) {
*src_elem, "src",
analytics_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
&pipeline->common_elements);
/* Add common message converter */
if (config->msg_conv_config.enable) {
NvDsSinkMsgConvBrokerConfig *convConfig = &config->msg_conv_config;
pipeline->common_elements.msg_conv = gst_element_factory_make (NVDS_ELEM_MSG_CONV, "common_msg_conv");
if (!pipeline->common_elements.msg_conv) {
NVGSTDS_ERR_MSG_V ("Failed to create element 'common_msg_conv'");
goto done;
g_object_set (G_OBJECT (pipeline->common_elements.msg_conv),
"config", convConfig->config_file_path,
"msg2p-lib", (convConfig->conv_msg2p_lib ? convConfig->conv_msg2p_lib : "null"),
"payload-type", convConfig->conv_payload_type,
"comp-id", convConfig->conv_comp_id,
"debug-payload-dir", convConfig->debug_payload_dir,
"multiple-payloads", convConfig->multiple_payloads, NULL);
pipeline->common_elements.msg_conv);
NVGSTDS_LINK_ELEMENT (*src_elem, pipeline->common_elements.msg_conv);
*src_elem = pipeline->common_elements.msg_conv;
pipeline->common_elements.tee = gst_element_factory_make (NVDS_ELEM_TEE, "common_analytics_tee");
if (!pipeline->common_elements.tee) {
NVGSTDS_ERR_MSG_V ("Failed to create element 'common_analytics_tee'");
goto done;
pipeline->common_elements.tee);
NVGSTDS_LINK_ELEMENT (*src_elem, pipeline->common_elements.tee);
*src_elem = pipeline->common_elements.tee;
ret = TRUE;
done:
return ret;
static gboolean is_sink_available_for_source_id(NvDsConfig *config, guint source_id) {
for (guint j = 0; j < config->num_sink_sub_bins; j++) {
if (config->sink_bin_sub_bin_config[j].enable &&
config->sink_bin_sub_bin_config[j].source_id == source_id &&
config->sink_bin_sub_bin_config[j].link_to_demux == FALSE) {
return TRUE;
return FALSE;
* Main function to create the pipeline.
gboolean
create_pipeline (AppCtx * appCtx,
bbox_generated_callback bbox_generated_post_analytics_cb,
bbox_generated_callback all_bbox_generated_cb, perf_callback perf_cb,
overlay_graphics_callback overlay_graphics_cb)
GstBus *bus;
GstElement *tmp_elem1;
GstElement *tmp_elem2;
guint i;
GstPad *fps_pad;
gulong latency_probe_id;
_dsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
appCtx->all_bbox_generated_cb = all_bbox_generated_cb;
appCtx->bbox_generated_post_analytics_cb = bbox_generated_post_analytics_cb;
appCtx->overlay_graphics_cb = overlay_graphics_cb;
if (config->osd_config.num_out_buffers < 8) {
config->osd_config.num_out_buffers = 8;
pipeline->pipeline = gst_pipeline_new ("pipeline");
if (!pipeline->pipeline) {
NVGSTDS_ERR_MSG_V ("Failed to create pipeline");
goto done;
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline->pipeline));
pipeline->bus_id = gst_bus_add_watch (bus, bus_callback, appCtx);
gst_object_unref (bus);
if (config->file_loop) {
/* Let each source bin know it needs to loop. */
guint i;
for (i = 0; i < config->num_source_sub_bins; i++)
config->multi_source_config[i].loop = TRUE;
NvDsSinkSubBinConfig *sink_config = &config->sink_bin_sub_bin_config[i];
switch (sink_config->type) {
case NV_DS_SINK_FAKE:
case NV_DS_SINK_RENDER_EGL:
case NV_DS_SINK_RENDER_OVERLAY:
/* Set the "qos" property of sink, if not explicitly specified in the
config. */
if (!sink_config->render_config.qos_value_specified) {
sink_config->render_config.qos = FALSE;
default:
break;
* Add muxer and < N > source components to the pipeline based
* on the settings in configuration file.
if (!create_multi_source_bin (config->num_source_sub_bins,
config->multi_source_config, &pipeline->multi_src_bin))
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->multi_src_bin.bin);
if (config->streammux_config.is_parsed){
if(!set_streammux_properties (&config->streammux_config,
pipeline->multi_src_bin.streammux)){
NVGSTDS_WARN_MSG_V("Failed to set streammux properties");
if(appCtx->latency_info == NULL)
appCtx->latency_info = (NvDsFrameLatencyInfo *)
calloc(1, config->streammux_config.batch_size *
sizeof(NvDsFrameLatencyInfo));
/** a tee after the tiler which shall be connected to sink(s) */
pipeline->tiler_tee = gst_element_factory_make (NVDS_ELEM_TEE, "tiler_tee");
if (!pipeline->tiler_tee) {
NVGSTDS_ERR_MSG_V ("Failed to create element 'tiler_tee'");
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiler_tee);
/** Tiler + Demux in Parallel Use-Case */
if (config->tiled_display_config.enable == NV_DS_TILED_DISPLAY_ENABLE_WITH_PARALLEL_DEMUX)
pipeline->demuxer =
gst_element_factory_make (NVDS_ELEM_STREAM_DEMUX, "demuxer");
if (!pipeline->demuxer) {
NVGSTDS_ERR_MSG_V ("Failed to create element 'demuxer'");
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->demuxer);
/** NOTE:
* demux output is supported for only one source
* If multiple [sink] groups are configured with
* link_to_demux=1, only the first [sink]
* shall be constructed for all occurences of
* [sink] groups with link_to_demux=1
gchar pad_name[16];
GstPad *demux_src_pad;
i = 0;
if (!create_demux_pipeline (appCtx, i)) {
goto done;
for (i=0; i < config->num_sink_sub_bins; i++)
if (config->sink_bin_sub_bin_config[i].link_to_demux == TRUE)
g_snprintf (pad_name, 16, "src_%02d", config->sink_bin_sub_bin_config[i].source_id);
break;
if (i >= config->num_sink_sub_bins)
g_print ("\n\nError : sink for demux (use link-to-demux-only property) is not provided in the config file\n\n");
goto done;
i = 0;
pipeline->demux_instance_bins[i].bin);
demux_src_pad = gst_element_get_request_pad (pipeline->demuxer, pad_name);
NVGSTDS_LINK_ELEMENT_FULL (pipeline->demuxer, pad_name,
pipeline->demux_instance_bins[i].bin, "sink");
gst_object_unref (demux_src_pad);
NVGSTDS_ELEM_ADD_PROBE(latency_probe_id,
appCtx->pipeline.demux_instance_bins[i].demux_sink_bin.bin,
"sink",
demux_latency_measurement_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
appCtx);
latency_probe_id = latency_probe_id;
last_elem = pipeline->demuxer;
link_element_to_tee_src_pad (pipeline->tiler_tee, last_elem);
last_elem = pipeline->tiler_tee;
if (config->tiled_display_config.enable) {
/* Tiler will generate a single composited buffer for all sources. So need
* to create only one processing instance. */
if (!create_processing_instance (appCtx, 0)) {
goto done;
// create and add tiling component to pipeline.
if (config->tiled_display_config.columns *
config->tiled_display_config.rows < config->num_source_sub_bins) {
if (config->tiled_display_config.columns == 0) {
(guint) (sqrt (config->num_source_sub_bins) + 0.5);
config->tiled_display_config.rows =
(guint) ceil (1.0 * config->num_source_sub_bins /
config->tiled_display_config.columns);
NVGSTDS_WARN_MSG_V
("Num of Tiles less than number of sources, readjusting to "
"%u rows, %u columns", config->tiled_display_config.rows,
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->instance_bins[0].bin);
last_elem = pipeline->instance_bins[0].bin;
if (!create_tiled_display_bin (&config->tiled_display_config,
&pipeline->tiled_display_bin)) {
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiled_display_bin.bin);
NVGSTDS_LINK_ELEMENT (pipeline->tiled_display_bin.bin, last_elem);
last_elem = pipeline->tiled_display_bin.bin;
link_element_to_tee_src_pad (pipeline->tiler_tee, pipeline->tiled_display_bin.bin);
NVGSTDS_ELEM_ADD_PROBE (latency_probe_id,
pipeline->instance_bins->sink_bin.sub_bins[0].sink, "sink",
appCtx);
else
* Create demuxer only if tiled display is disabled.
pipeline->demuxer =
goto done;
gchar pad_name[16];
/* Check if any sink has been configured to render/encode output for
* source index `i`. The processing instance for that source will be
* created only if atleast one sink has been configured as such.
if (!is_sink_available_for_source_id(config, i))
continue;
if (!create_processing_instance(appCtx, i))
goto done;
gst_bin_add(GST_BIN(pipeline->pipeline),
pipeline->instance_bins[i].bin);
g_snprintf(pad_name, 16, "src_%02d", i);
demux_src_pad = gst_element_get_request_pad(pipeline->demuxer, pad_name);
NVGSTDS_LINK_ELEMENT_FULL(pipeline->demuxer, pad_name,
pipeline->instance_bins[i].bin, "sink");
gst_object_unref(demux_src_pad);
for (int k = 0; k < MAX_SINK_BINS;k++) {
if(pipeline->instance_bins[i].sink_bin.sub_bins[k].sink){
pipeline->instance_bins[i].sink_bin.sub_bins[k].sink, "sink",
appCtx);
break;
if (config->tiled_display_config.enable == NV_DS_TILED_DISPLAY_DISABLE) {
fps_pad = gst_element_get_static_pad (pipeline->demuxer, "sink");
else {
fps_pad = gst_element_get_static_pad (pipeline->tiled_display_bin.bin, "sink");
pipeline->common_elements.appCtx = appCtx;
// Decide where in the pipeline the element should be added and add only if
// enabled
if (config->dsexample_config.enable) {
// Create dsexample element bin and set properties
if (!create_dsexample_bin (&config->dsexample_config,
&pipeline->dsexample_bin)) {
goto done;
// Add dsexample bin to instance bin
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->dsexample_bin.bin);
// Link this bin to the last element in the bin
NVGSTDS_LINK_ELEMENT (pipeline->dsexample_bin.bin, last_elem);
last_elem = pipeline->dsexample_bin.bin;
// create and add common components to pipeline.
if (!create_common_elements (config, pipeline, &tmp_elem1, &tmp_elem2,
bbox_generated_post_analytics_cb)) {
goto done;
if(!add_and_link_broker_sink(appCtx)) {
goto done;
if (tmp_elem2) {
NVGSTDS_LINK_ELEMENT (tmp_elem2, last_elem);
last_elem = tmp_elem1;
NVGSTDS_LINK_ELEMENT (pipeline->multi_src_bin.bin, last_elem);
// enable performance measurement and add call back function to receive
// performance data.
if (config->enable_perf_measurement) {
appCtx->perf_struct.context = appCtx;
enable_perf_measurement (&appCtx->perf_struct, fps_pad,
pipeline->multi_src_bin.num_bins,
config->perf_measurement_interval_sec,
config->multi_source_config[0].dewarper_config.num_surfaces_per_frame,
perf_cb);
if (config->num_message_consumers) {
for (i = 0; i < config->num_message_consumers; i++) {
appCtx->c2d_ctx[i] = start_cloud_to_device_messaging (
&config->message_consumer_config[i], NULL,
&appCtx->pipeline.multi_src_bin);
if (appCtx->c2d_ctx[i] == NULL) {
NVGSTDS_ERR_MSG_V ("Failed to create message consumer");
goto done;
GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->pipeline.pipeline),
GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-null");
g_mutex_init (&appCtx->app_lock);
g_cond_init (&appCtx->app_cond);
g_mutex_init (&appCtx->latency_lock);
ret = TRUE;
done:
if (!ret) {
return ret;
* Function to destroy pipeline and release the resources, probes etc.
void
destroy_pipeline (AppCtx * appCtx)
gint64 end_time;
guint i;
GstBus *bus = NULL;
end_time = g_get_monotonic_time () + G_TIME_SPAN_SECOND;
if (!appCtx)
return;
if (appCtx->pipeline.demuxer) {
gst_pad_send_event (gst_element_get_static_pad (appCtx->pipeline.demuxer,
"sink"), gst_event_new_eos ());
} else if (appCtx->pipeline.instance_bins[0].sink_bin.bin) {
pipeline.instance_bins[0].sink_bin.bin, "sink"),
g_usleep (100000);
if (appCtx->pipeline.pipeline) {
destroy_smart_record_bin (&appCtx->pipeline.multi_src_bin);
bus = gst_pipeline_get_bus (GST_PIPELINE (appCtx->pipeline.pipeline));
while (TRUE) {
GstMessage *message = gst_bus_pop (bus);
if (message == NULL)
break;
else if (GST_MESSAGE_TYPE (message) == GST_MESSAGE_ERROR)
bus_callback (bus, message, appCtx);
else
gst_message_unref (message);
gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_NULL);
g_cond_wait_until (&appCtx->app_cond, &appCtx->app_lock, end_time);
for (i = 0; i < appCtx->config.num_source_sub_bins; i++) {
NvDsInstanceBin *bin = &appCtx->pipeline.instance_bins[i];
NVGSTDS_ELEM_REMOVE_PROBE (bin->all_bbox_buffer_probe_id,
bin->osd_bin.nvosd, "sink");
} else {
bin->sink_bin.bin, "sink");
NVGSTDS_ELEM_REMOVE_PROBE (bin->primary_bbox_buffer_probe_id,
bin->primary_gie_bin.bin, "src");
free(appCtx->latency_info);
appCtx->latency_info = NULL;
destroy_sink_bin ();
g_mutex_clear(&appCtx->latency_lock);
gst_bus_remove_watch (bus);
gst_object_unref (appCtx->pipeline.pipeline);
if (appCtx->c2d_ctx[i])
stop_cloud_to_device_messaging (appCtx->c2d_ctx[i]);
gboolean
pause_pipeline (AppCtx * appCtx)
GstState cur;
GstState pending;
GstStateChangeReturn ret;
GstClockTime timeout = 5 * GST_SECOND / 1000;
ret =
gst_element_get_state (appCtx->pipeline.pipeline, &cur, &pending,
timeout);
if (ret == GST_STATE_CHANGE_ASYNC) {
return FALSE;
if (cur == GST_STATE_PAUSED) {
return TRUE;
} else if (cur == GST_STATE_PLAYING) {
gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_PAUSED);
GST_CLOCK_TIME_NONE);
pause_perf_measurement (&appCtx->perf_struct);
return TRUE;
} else {
return FALSE;
gboolean
resume_pipeline (AppCtx * appCtx)
GstState cur;
GstState pending;
ret =
timeout);
return FALSE;
return TRUE;
} else if (cur == GST_STATE_PAUSED) {
gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_PLAYING);
resume_perf_measurement (&appCtx->perf_struct);
return TRUE;
} else {
return FALSE;
deepstream_config.txt
# Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=2
num-sources=1
#uri=file://../../streams/sample_1080p_h265.mp4
#uri=file://../../streams/test/what is a chindian.264
uri=rtsp://root:Glueck321@192.168.1.18/axis-media/media.amp?streamprofile=H264
#drop-frame-interval=2
gpu-id=0
camera-width=1280
camera-height=720
camera-fps-n=10
camera-fps-d=1
camera-v4l2-dev-node=0
[streammux]
gpu-id=0
batch-size=1
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
[osd]
enable=1
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
[primary-gie]
enable=1
gpu-id=0
# Modify as necessary
model-engine-file=../../models/Primary_FaceDetector/resnet18_detector.etlt_b1_gpu0_fp16.engine
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
gie-unique-id=1
config-file=config_infer_primary_facedetectir.txt
[secondary-gie0]
enable=0
model-engine-file=../../models/Secondary_Gender/gender11.caffemodel_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_gender_classifier.txt
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[tracker]
enable=0
tracker-width=640
tracker-height=384
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
ll-config-file=../deepstream-app/tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
[secondary-gie1]
enable=0
model-engine-file=../../models/Secondary_Age/age.model_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=3
operate-on-gie-id=1
config-file=config_infer_age_classifier.txt
[secondary-gie2]
enable=0
model-engine-file=../../models/Secondary_Emotion/emotion_2convs_iter_3000.caffemodel_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=4
operate-on-gie-id=1
config-file=config_infer_emotion_classifier.txt
[secondary-gie3]
enable=0
model-engine-file=../../models/Secondary_Ethnicity/ethnicity_generic.caffemodel_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_ethnicity_classifier.txt
[tests]
file-loop=1
The application runs for some time and crashes along with the error while using rtsp,webcam and mp4 as inputs.
Errors:
- RTSP
nvdc: open: Too many open files
nvdc: failed to open ‘/dev/fb1’.
nvdc: failed to open ‘/dev/tegra_dc_1’.
nvdc: failed to open ‘/dev/fb0’.
SYNC_IOC_FENCE_INFO ioctl failed with 9
[NvTiler::Composite] ERROR: 352; NvBufSurfTransformComposite failed(-2)
0:03:15.066842213 9549 0x559e24b400 WARN nvinfer gstnvinfer.cpp:1277:convert_batch_and_push_to_input_thread:<primary_gie> error: NvBufSurfTransform failed with error -2 while converting buffer
ERROR from primary_gie: NvBufSurfTransform failed with error -2 while converting buffer
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1277): convert_batch_and_push_to_input_thread (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie
ERROR from tiled_display_tiler: GstNvTiler: FATAL ERROR; NvTiler::Composite failed
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvtiler/gstnvtiler.cpp(662): gst_nvmultistreamtiler_transform (): /GstPipeline:pipeline/GstBin:tiled_display_bin/GstNvMultiStreamTiler:tiled_display_tiler
Quitting
App run failed
- Webcam
Quitting
0:06:23.263145399 8219 0x55b80dc720 ERROR nvvideoconvert gstnvvideoconvert.c:3387:gst_nvvideoconvert_transform: buffer transform failed
ERROR from src_elem: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem:
streaming stopped, reason error (-5)
ERROR from tiled_display_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:tiled_display_bin/GstQueue:tiled_display_queue:
App run failed
- MP4 Video file
error in Blit. Error: 6
0:05:32.717794608 4799 0x55c1aa7000 WARN nvinfer gstnvinfer.cpp:1277:convert_batch_and_push_to_input_thread:<primary_gie> error: NvBufSurfTransform failed with error -2 while converting buffer
Quitting
ERROR from render_queue1: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstQueue:render_queue1:
App run failed
I have tried running the model only with the face detector disabling all the secondary models and tracking but still the error pops up.
Please help on this issue.
