Add performance measurement in deepstream_parallel_inference_app
• Hardware Platform ( GPU: Nvidia GeForce RTX 3060)
• DeepStream Version: 6.3 docker container
• NVIDIA GPU Driver Version: 535.129.03
• Issue Type( questions)
Is there a patch i could add in to deepstream_parallel_infer_app.cpp for performance measurement? This patch seems to be for .c files and is not working https://forums.developer.nvidia.com/t/deepstream-sdk-faq/80236/
Even the patch is for the deepstream-test2 sample application DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums, you can port the code to deepstream_parallel_infer_app.cpp.
But deepstream-test2 file is in .c and deepstream_parallel_infer_app is in .cpp, i tried adding the patch to the cpp file and it did not work. Here is my file with the patch added in and the error
 * SPDX-FileCopyrightText: Copyright (c) <2022-2024> NVIDIA CORPORATION & AFFILIATES. All rights reserved.
 * SPDX-License-Identifier: MIT
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include "deepstream_parallel_infer.h"
#include "post_process/body_pose/post_process.cpp"
#include "nvds_version.h"
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include "gstnvdsmeta.h"
#include "nvdsgstutils.h"
#include "nvbufsurface.h"
#include "nvdsmeta_schema.h"
#include "/opt/nvidia/deepstream/deepstream-6.3/sources/apps/apps-common/includes/deepstream_perf.h"
#include <vector>
#include <array>
#include <queue>
#include <cmath>
#include <string>
#define EPS 1e-6
#define MAX_DISPLAY_LEN 64
#define MAX_TIME_STAMP_LEN 32
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
#define MAX_STR_LEN 2048
AppCtx *appCtx;
static guint cintr = FALSE;
static GMainLoop *main_loop = NULL;
static gchar **cfg_files = NULL;
static gboolean print_version = FALSE;
static gboolean show_bbox_text = FALSE;
static gboolean print_dependencies_version = FALSE;
static gboolean quit = FALSE;
static gint return_value = 0;
static guint num_input_uris;
static gint frame_interval = 30;
template <class T>
using Vec1D = std::vector<T>;
template <class T>
using Vec2D = std::vector<Vec1D<T>>;
template <class T>
using Vec3D = std::vector<Vec2D<T>>;
gint frame_number = 0;
GST_DEBUG_CATEGORY (NVDS_APP);
GOptionEntry entries[] = {
  {"version", 'v', 0, G_OPTION_ARG_NONE, &print_version,
      "Print DeepStreamSDK version", NULL}
  {"tiledtext", 't', 0, G_OPTION_ARG_NONE, &show_bbox_text,
      "Display Bounding box labels in tiled mode", NULL}
  {"version-all", 0, 0, G_OPTION_ARG_NONE, &print_dependencies_version,
      "Print DeepStreamSDK and dependencies version", NULL}
  {"cfg-file", 'c', 0, G_OPTION_ARG_FILENAME_ARRAY, &cfg_files,
      "Set the config file", NULL}
  {NULL}
#define MAX_STREAMS 64
typedef struct
    /** identifies the stream ID */
    guint32 stream_index;
    gdouble fps[MAX_STREAMS];
    gdouble fps_avg[MAX_STREAMS];
    guint32 num_instances;
    guint header_print_cnt;
    GMutex fps_lock;
    gpointer context;
    /** Test specific info */
    guint32 set_batch_size;
}DemoPerfCtx;
typedef struct {
  GMutex *lock;
  int num_sources;
}LatencyCtx;
static void
perf_cb (gpointer context, NvDsAppPerfStruct * str)
  DemoPerfCtx *thCtx = (DemoPerfCtx *) context;
  g_mutex_lock(&thCtx->fps_lock);
  /** str->num_instances is == num_sources */
  guint32 numf = str->num_instances;
  guint32 i;
  for (i = 0; i < numf; i++) {
    thCtx->fps[i] = str->fps[i];
    thCtx->fps_avg[i] = str->fps_avg[i];
  thCtx->context = thCtx;
  g_print ("**PERF: ");
    g_print ("%.2f (%.2f)\t", thCtx->fps[i], thCtx->fps_avg[i]);
  g_print ("\n");
  g_mutex_unlock(&thCtx->fps_lock);
static GstPadProbeReturn
latency_measurement_buf_prob(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  LatencyCtx *ctx = (LatencyCtx *) u_data;
  static int batch_num = 0;
  guint i = 0, num_sources_in_batch = 0;
  if(nvds_enable_latency_measurement)
    GstBuffer *buf = (GstBuffer *) info->data;
    NvDsFrameLatencyInfo *latency_info = NULL;
    g_mutex_lock (ctx->lock);
    latency_info = (NvDsFrameLatencyInfo *)
      calloc(1, ctx->num_sources * sizeof(NvDsFrameLatencyInfo));;
    g_print("\n************BATCH-NUM = %d**************\n",batch_num);
    num_sources_in_batch = nvds_measure_buffer_latency(buf, latency_info);
    for(i = 0; i < num_sources_in_batch; i++)
      g_print("Source id = %d Frame_num = %d Frame latency = %lf (ms) \n",
          latency_info[i].source_id,
          latency_info[i].frame_num,
          latency_info[i].latency);
    g_mutex_unlock (ctx->lock);
    batch_num++;
  return GST_PAD_PROBE_OK;
 * Buffer probe function on sink element.
sink_bin_buf_probe (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  NvDsAppPerfStructInt *str = (NvDsAppPerfStructInt *) u_data;
  NvDsBatchMeta *batch_meta =
      gst_buffer_get_nvds_batch_meta (GST_BUFFER (info->data));
  if (!batch_meta)
  if (!str->stop) {
    g_mutex_lock (&str->struct_lock);
    for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame;
        l_frame = l_frame->next) {
      NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) l_frame->data;
      NvDsInstancePerfStruct *str1 = &str->instance_str[frame_meta->pad_index];
      gettimeofday (&str1->last_fps_time, NULL);
      if (str1->start_fps_time.tv_sec == 0 && str1->start_fps_time.tv_usec == 0) {
        str1->start_fps_time = str1->last_fps_time;
      } else {
        str1->buffer_cnt++;
    g_mutex_unlock (&str->struct_lock);
/*Method to parse information returned from the model*/
std::tuple<Vec2D<int>, Vec3D<float>>
parse_objects_from_tensor_meta(NvDsInferTensorMeta *tensor_meta)
  Vec1D<int> counts;
  Vec3D<int> peaks;
  float threshold = 0.1;
  int window_size = 5;
  int max_num_parts = 20;
  int num_integral_samples = 7;
  float link_threshold = 0.1;
  int max_num_objects = 100;
  void *cmap_data = tensor_meta->out_buf_ptrs_host[0];
  NvDsInferDims &cmap_dims = tensor_meta->output_layers_info[0].inferDims;
  void *paf_data = tensor_meta->out_buf_ptrs_host[1];
  NvDsInferDims &paf_dims = tensor_meta->output_layers_info[1].inferDims;
  /* Finding peaks within a given window */
  find_peaks(counts, peaks, cmap_data, cmap_dims, threshold, window_size, max_num_parts);
  /* Non-Maximum Suppression */
  Vec3D<float> refined_peaks = refine_peaks(counts, peaks, cmap_data, cmap_dims, window_size);
  /* Create a Bipartite graph to assign detected body-parts to a unique person in the frame */
  Vec3D<float> score_graph = paf_score_graph(paf_data, paf_dims, topology, counts, refined_peaks, num_integral_samples);
  /* Assign weights to all edges in the bipartite graph generated */
  Vec3D<int> connections = assignment(score_graph, topology, counts, link_threshold, max_num_parts);
  /* Connecting all the Body Parts and Forming a Human Skeleton */
  Vec2D<int> objects = connect_parts(connections, topology, counts, max_num_objects);
  return {objects, refined_peaks};
/* MetaData to handle drawing onto the on-screen-display */
static void
create_display_meta(Vec2D<int> &objects, Vec3D<float> &normalized_peaks, NvDsFrameMeta *frame_meta, int frame_width, int frame_height)
  int K = topology.size();
  int count = objects.size();
  NvDsBatchMeta *bmeta = frame_meta->base_meta.batch_meta;
  NvDsDisplayMeta *dmeta = nvds_acquire_display_meta_from_pool(bmeta);
  nvds_add_display_meta_to_frame(frame_meta, dmeta);
  for (auto &object : objects)
    int C = object.size();
    for (int j = 0; j < C; j++)
      int k = object[j];
      if (k >= 0)
        auto &peak = normalized_peaks[j][k];
        int x = peak[1] * MUXER_OUTPUT_WIDTH;
        int y = peak[0] * MUXER_OUTPUT_HEIGHT;
        if (dmeta->num_circles == MAX_ELEMENTS_IN_DISPLAY_META)
        NvOSD_CircleParams &cparams = dmeta->circle_params[dmeta->num_circles];
        cparams.xc = x;
        cparams.yc = y;
        cparams.radius = 8;
        cparams.circle_color = NvOSD_ColorParams{244, 67, 54, 1};
        cparams.has_bg_color = 1;
        cparams.bg_color = NvOSD_ColorParams{0, 255, 0, 1};
        dmeta->num_circles++;
    for (int k = 0; k < K; k++)
      int c_a = topology[k][2];
      int c_b = topology[k][3];
      if (object[c_a] >= 0 && object[c_b] >= 0)
        auto &peak0 = normalized_peaks[c_a][object[c_a]];
        auto &peak1 = normalized_peaks[c_b][object[c_b]];
        int x0 = peak0[1] * MUXER_OUTPUT_WIDTH;
        int y0 = peak0[0] * MUXER_OUTPUT_HEIGHT;
        int x1 = peak1[1] * MUXER_OUTPUT_WIDTH;
        int y1 = peak1[0] * MUXER_OUTPUT_HEIGHT;
        if (dmeta->num_lines == MAX_ELEMENTS_IN_DISPLAY_META)
        NvOSD_LineParams &lparams = dmeta->line_params[dmeta->num_lines];
        lparams.x1 = x0;
        lparams.x2 = x1;
        lparams.y1 = y0;
        lparams.y2 = y1;
        lparams.line_width = 3;
        lparams.line_color = NvOSD_ColorParams{0, 255, 0, 1};
        dmeta->num_lines++;
/* body_pose_gie_src_pad_buffer_probe  will extract metadata received from pgie
 * and update params for drawing rectangle, object information etc. */
body_pose_gie_src_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
                          gpointer u_data)
  gchar *msg = NULL;
  GstBuffer *buf = (GstBuffer *)info->data;
  NvDsMetaList *l_frame = NULL;
  NvDsMetaList *l_obj = NULL;
  NvDsMetaList *l_user = NULL;
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
  for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
    NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
    if (frame_meta->batch_id == 0)
      g_print("Processing frame number = %d\t\n", frame_meta->frame_num);
    for (l_user = frame_meta->frame_user_meta_list; l_user != NULL;
         l_user = l_user->next)
      NvDsUserMeta *user_meta = (NvDsUserMeta *)l_user->data;
      if (user_meta->base_meta.meta_type == NVDSINFER_TENSOR_OUTPUT_META)
        NvDsInferTensorMeta *tensor_meta =
            (NvDsInferTensorMeta *)user_meta->user_meta_data;
        Vec2D<int> objects;
        Vec3D<float> normalized_peaks;
        tie(objects, normalized_peaks) = parse_objects_from_tensor_meta(tensor_meta);
        create_display_meta(objects, normalized_peaks, frame_meta, frame_meta->source_frame_width, frame_meta->source_frame_height);
    for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
         l_obj = l_obj->next)
      NvDsObjectMeta *obj_meta = (NvDsObjectMeta *)l_obj->data;
      for (l_user = obj_meta->obj_user_meta_list; l_user != NULL;
          Vec2D<int> objects;
yolov4_gie_src_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
                          gpointer u_data)
  gchar *msg = NULL;
static void
generate_ts_rfc3339 (char *buf, int buf_size)
  time_t tloc;
  struct tm tm_log;
  struct timespec ts;
  char strmsec[6];              //.nnnZ\0
  clock_gettime (CLOCK_REALTIME, &ts);
  memcpy (&tloc, (void *) (&ts.tv_sec), sizeof (time_t));
  gmtime_r (&tloc, &tm_log);
  strftime (buf, buf_size, "%Y-%m-%dT%H:%M:%S", &tm_log);
  int ms = ts.tv_nsec / 1000000;
  g_snprintf (strmsec, sizeof (strmsec), ".%.3dZ", ms);
  strncat (buf, strmsec, buf_size);
static gpointer
meta_copy_func (gpointer data, gpointer user_data)
  NvDsUserMeta *user_meta = (NvDsUserMeta *) data;
  NvDsEventMsgMeta *srcMeta = (NvDsEventMsgMeta *) user_meta->user_meta_data;
  NvDsEventMsgMeta *dstMeta = NULL;
  dstMeta = (NvDsEventMsgMeta *) g_memdup (srcMeta, sizeof (NvDsEventMsgMeta));
  if (srcMeta->ts)
    dstMeta->ts = g_strdup (srcMeta->ts);
  if (srcMeta->sensorStr)
    dstMeta->sensorStr = g_strdup (srcMeta->sensorStr);
  if (srcMeta->objSignature.size > 0) {
    dstMeta->objSignature.signature =  (gdouble *) g_memdup (srcMeta->objSignature.signature,
        srcMeta->objSignature.size);
    dstMeta->objSignature.size = srcMeta->objSignature.size;
  if (srcMeta->objectId) {
    dstMeta->objectId = g_strdup (srcMeta->objectId);
  if (srcMeta->extMsgSize > 0) {
    if (srcMeta->objType == NVDS_OBJECT_TYPE_VEHICLE) {
      NvDsVehicleObject *srcObj = (NvDsVehicleObject *) srcMeta->extMsg;
      NvDsVehicleObject *obj =
          (NvDsVehicleObject *) g_malloc0 (sizeof (NvDsVehicleObject));
      if (srcObj->type)
        obj->type = g_strdup (srcObj->type);
      if (srcObj->make)
        obj->make = g_strdup (srcObj->make);
      if (srcObj->model)
        obj->model = g_strdup (srcObj->model);
      if (srcObj->color)
        obj->color = g_strdup (srcObj->color);
      if (srcObj->license)
        obj->license = g_strdup (srcObj->license);
      if (srcObj->region)
        obj->region = g_strdup (srcObj->region);
      dstMeta->extMsg = obj;
      dstMeta->extMsgSize = sizeof (NvDsVehicleObject);
    } else if (srcMeta->objType == NVDS_OBJECT_TYPE_PERSON) {
      NvDsPersonObject *srcObj = (NvDsPersonObject *) srcMeta->extMsg;
      NvDsPersonObject *obj =
          (NvDsPersonObject *) g_malloc0 (sizeof (NvDsPersonObject));
      obj->age = srcObj->age;
      if (srcObj->gender)
        obj->gender = g_strdup (srcObj->gender);
      if (srcObj->cap)
        obj->cap = g_strdup (srcObj->cap);
      if (srcObj->hair)
        obj->hair = g_strdup (srcObj->hair);
      if (srcObj->apparel)
        obj->apparel = g_strdup (srcObj->apparel);
      dstMeta->extMsgSize = sizeof (NvDsPersonObject);
  return dstMeta;
static void
meta_free_func (gpointer data, gpointer user_data)
  g_free (srcMeta->ts);
  g_free (srcMeta->sensorStr);
    g_free (srcMeta->objSignature.signature);
    srcMeta->objSignature.size = 0;
    g_free (srcMeta->objectId);
      NvDsVehicleObject *obj = (NvDsVehicleObject *) srcMeta->extMsg;
      if (obj->type)
        g_free (obj->type);
      if (obj->color)
        g_free (obj->color);
      if (obj->make)
        g_free (obj->make);
      if (obj->model)
        g_free (obj->model);
      if (obj->license)
        g_free (obj->license);
      if (obj->region)
        g_free (obj->region);
      NvDsPersonObject *obj = (NvDsPersonObject *) srcMeta->extMsg;
      if (obj->gender)
        g_free (obj->gender);
      if (obj->cap)
        g_free (obj->cap);
      if (obj->hair)
        g_free (obj->hair);
      if (obj->apparel)
        g_free (obj->apparel);
    g_free (srcMeta->extMsg);
    srcMeta->extMsgSize = 0;
  g_free (user_meta->user_meta_data);
  user_meta->user_meta_data = NULL;
static void
generate_vehicle_meta (gpointer data)
  NvDsVehicleObject *obj = (NvDsVehicleObject *) data;
  obj->type = g_strdup ("sedan");
  obj->color = g_strdup ("blue");
  obj->make = g_strdup ("Bugatti");
  obj->model = g_strdup ("M");
  obj->license = g_strdup ("XX1234");
  obj->region = g_strdup ("CA");
static void
generate_person_meta (gpointer data)
  NvDsPersonObject *obj = (NvDsPersonObject *) data;
  obj->age = 45;
  obj->cap = g_strdup ("none");
  obj->hair = g_strdup ("black");
  obj->gender = g_strdup ("male");
  obj->apparel = g_strdup ("formal");
static void
generate_event_msg_meta (gpointer data, gint class_id,
    NvDsObjectMeta * obj_params)
  NvDsEventMsgMeta *meta = (NvDsEventMsgMeta *) data;
  meta->sensorId = 0;
  meta->placeId = 0;
  meta->moduleId = 0;
  meta->sensorStr = g_strdup ("sensor-0");
  meta->ts = (gchar *) g_malloc0 (MAX_TIME_STAMP_LEN + 1);
  meta->objectId = (gchar *) g_malloc0 (MAX_LABEL_SIZE);
  strncpy (meta->objectId, obj_params->obj_label, MAX_LABEL_SIZE);
  generate_ts_rfc3339 (meta->ts, MAX_TIME_STAMP_LEN);
   * This demonstrates how to attach custom objects.
   * Any custom object as per requirement can be generated and attached
   * like NvDsVehicleObject / NvDsPersonObject. Then that object should
   * be handled in payload generator library (nvmsgconv.cpp) accordingly.
  if (class_id == PGIE_CLASS_ID_VEHICLE) {
    meta->type = NVDS_EVENT_MOVING;
    meta->objType = NVDS_OBJECT_TYPE_VEHICLE;
    meta->objClassId = PGIE_CLASS_ID_VEHICLE;
    generate_vehicle_meta (obj);
    meta->extMsg = obj;
    meta->extMsgSize = sizeof (NvDsVehicleObject);
  } else if (class_id == PGIE_CLASS_ID_PERSON) {
    meta->type = NVDS_EVENT_ENTRY;
    meta->objType = NVDS_OBJECT_TYPE_PERSON;
    meta->objClassId = PGIE_CLASS_ID_PERSON;
    generate_person_meta (obj);
    meta->extMsg = obj;
    meta->extMsgSize = sizeof (NvDsPersonObject);
/* osd_sink_pad_buffer_probe  will extract metadata received from OSD
osd_sink_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
                          gpointer u_data)
  guint num_rects = 0;
  NvDsObjectMeta *obj_meta = NULL;
  NvDsDisplayMeta *display_meta = NULL;
  gboolean is_first_object = TRUE;
    int offset = 0;
    for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next)
      obj_meta = (NvDsObjectMeta *)(l_obj->data);
      /** Generate NvDsEventMsgMeta for every object */
      if (is_first_object && !(frame_number % frame_interval)) {
        NvDsEventMsgMeta *msg_meta =
            (NvDsEventMsgMeta *) g_malloc0 (sizeof (NvDsEventMsgMeta));
        msg_meta->bbox.top = obj_meta->rect_params.top;
        msg_meta->bbox.left = obj_meta->rect_params.left;
        msg_meta->bbox.width = obj_meta->rect_params.width;
        msg_meta->bbox.height = obj_meta->rect_params.height;
        msg_meta->frameId = frame_number;
        msg_meta->trackingId = obj_meta->object_id;
        msg_meta->confidence = obj_meta->confidence;
        generate_event_msg_meta (msg_meta, obj_meta->class_id, obj_meta);
        NvDsUserMeta *user_event_meta =
            nvds_acquire_user_meta_from_pool (batch_meta);
        if (user_event_meta) {
          user_event_meta->user_meta_data = (void *) msg_meta;
          user_event_meta->base_meta.meta_type = NVDS_EVENT_MSG_META;
          user_event_meta->base_meta.copy_func =
              (NvDsMetaCopyFunc) meta_copy_func;
          user_event_meta->base_meta.release_func =
              (NvDsMetaReleaseFunc) meta_free_func;
          nvds_add_user_meta_to_frame (frame_meta, user_event_meta);
        } else {
          g_print ("Error in attaching event meta to buffer\n");
    display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
    /* Parameters to draw text onto the On-Screen-Display */
    NvOSD_TextParams *txt_params = &display_meta->text_params[0];
    display_meta->num_labels = 1;
    txt_params->display_text = (char *)g_malloc0(MAX_DISPLAY_LEN);
    offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Frame Number =  %d", frame_number);
    offset = snprintf(txt_params->display_text + offset, MAX_DISPLAY_LEN, "");
    txt_params->x_offset = 10;
    txt_params->y_offset = 12;
    txt_params->font_params.font_name = "Mono";
    txt_params->font_params.font_size = 10;
    txt_params->font_params.font_color.red = 1.0;
    txt_params->font_params.font_color.green = 1.0;
    txt_params->font_params.font_color.blue = 1.0;
    txt_params->font_params.font_color.alpha = 1.0;
    txt_params->set_bg_clr = 1;
    txt_params->text_bg_clr.red = 0.0;
    txt_params->text_bg_clr.green = 0.0;
    txt_params->text_bg_clr.blue = 0.0;
    txt_params->text_bg_clr.alpha = 1.0;
    nvds_add_display_meta_to_frame(frame_meta, display_meta);
  frame_number++;
static gboolean
bus_call(GstBus *bus, GstMessage *msg, gpointer data)
  GMainLoop *main_loop = (GMainLoop *)data;
  switch (GST_MESSAGE_TYPE(msg))
  case GST_MESSAGE_EOS:
    g_print("End of Stream\n");
    g_main_loop_quit(main_loop);
    break;
  case GST_MESSAGE_ERROR:
    gchar *debug;
    GError *error;
    gst_message_parse_error(msg, &error, &debug);
    g_printerr("ERROR from element %s: %s\n",
               GST_OBJECT_NAME(msg->src), error->message);
    if (debug)
      g_printerr("Error details: %s\n", debug);
    g_free(debug);
    g_error_free(error);
    break;
  default:
    break;
  return TRUE;
gboolean
link_element_to_metamux_sink_pad (GstElement *metamux, GstElement *elem,
    gint index)
  gboolean ret = FALSE;
  GstPad *mux_sink_pad = NULL;
  GstPad *src_pad = NULL;
  gchar pad_name[16];
  if (index >= 0) {
    g_snprintf (pad_name, 16, "sink_%u", index);
    pad_name[15] = '\0';
  } else {
    strcpy (pad_name, "sink_%u");
  mux_sink_pad = gst_element_get_request_pad (metamux, pad_name);
  if (!mux_sink_pad) {
    NVGSTDS_ERR_MSG_V ("Failed to get sink pad from metamux");
    goto done;
  src_pad = gst_element_get_static_pad (elem, "src");
  if (!src_pad) {
    NVGSTDS_ERR_MSG_V ("Failed to get src pad from '%s'",
                        GST_ELEMENT_NAME (elem));
    goto done;
  if (gst_pad_link (src_pad, mux_sink_pad) != GST_PAD_LINK_OK) {
    NVGSTDS_ERR_MSG_V ("Failed to link '%s' and '%s'", GST_ELEMENT_NAME (metamux),
    goto done;
  ret = TRUE;
done:
  if (mux_sink_pad) {
    gst_object_unref (mux_sink_pad);
  if (src_pad) {
    gst_object_unref (src_pad);
  return ret;
gboolean
unlink_element_from_metamux_sink_pad (GstElement *metamux, GstElement *elem)
  if (!src_pad) {
    goto done;
  mux_sink_pad = gst_pad_get_peer (src_pad);
    goto done;
  if (!gst_pad_unlink (src_pad, mux_sink_pad)) {
    NVGSTDS_ERR_MSG_V ("Failed to unlink '%s' and '%s'", GST_ELEMENT_NAME (metamux),
    goto done;
  gst_element_release_request_pad(metamux, mux_sink_pad);
  ret = TRUE;
done:
  if (mux_sink_pad) {
  if (src_pad) {
  return ret;
gboolean
link_streamdemux_to_streammux (NvDsParallelGieBin *bin, GstElement *demux, GstElement *mux,
    gint index)
  GstPad *source_tee_src_pad = NULL;
  GstElement *queue = NULL;
  gchar pad_name[16];
  if (!bin->source_tee[index]) {
    bin->source_tee[index] = gst_element_factory_make (NVDS_ELEM_TEE, NULL);
      NVGSTDS_ERR_MSG_V ("Failed to create 'infer_bin_source_tee'");
      goto done;
    gst_bin_add (GST_BIN (bin->bin), bin->source_tee[index]);
    link_element_to_demux_src_pad (demux, bin->source_tee[index], index);
  queue = gst_element_factory_make (NVDS_ELEM_QUEUE, NULL);
  if (!queue) {
    NVGSTDS_ERR_MSG_V ("Could not create 'queue'");
    goto done;
  gst_bin_add (GST_BIN (bin->bin), queue);
  link_element_to_streammux_sink_pad (mux, queue, index);
  link_element_to_tee_src_pad (bin->source_tee[index], queue);
  ret = TRUE;
done:
  if (mux_sink_pad) {
  if (source_tee_src_pad) {
    gst_object_unref (source_tee_src_pad);
  return ret;
gboolean
create_primary_gie_videotemplate_bin (NvDsVideoTemplateConfig *config, NvDsPrimaryGieBin *bin)
  guint i;
  bin->bin = gst_bin_new ("primary_gie_bin");
  if (!bin->bin) {
    NVGSTDS_ERR_MSG_V ("Failed to create 'primary_gie_bin'");
    goto done;
  bin->nvvidconv =
      gst_element_factory_make (NVDS_ELEM_VIDEO_CONV, "primary_gie_conv");
  if (!bin->nvvidconv) {
    NVGSTDS_ERR_MSG_V ("Failed to create 'primary_gie_conv'");
    goto done;
  bin->queue = gst_element_factory_make (NVDS_ELEM_QUEUE, "primary_gie_queue");
  if (!bin->queue) {
    NVGSTDS_ERR_MSG_V ("Failed to create 'primary_gie_queue'");
    goto done;
  bin->primary_gie =
       gst_element_factory_make ("nvdsvideotemplate", "primary_gie");
  if (!bin->primary_gie) {
    NVGSTDS_ERR_MSG_V ("Failed to create 'primary_gie'");
    goto done;
  g_object_set (G_OBJECT (bin->primary_gie),
    "customlib-name", config->customlib_name, NULL);
  for (i = 0; i < config->num_customlib_props; i ++) {
      "customlib-props", config->customlib_props[i], NULL);
  g_object_set (G_OBJECT (bin->nvvidconv), "gpu-id", config->gpu_id, NULL);
  g_object_set (G_OBJECT (bin->nvvidconv), "nvbuf-memory-type",
      config->nvbuf_memory_type, NULL);
  gst_bin_add_many (GST_BIN (bin->bin), bin->queue,
      bin->nvvidconv, bin->primary_gie, NULL);
  NVGSTDS_LINK_ELEMENT (bin->queue, bin->nvvidconv);
  NVGSTDS_LINK_ELEMENT (bin->nvvidconv, bin->primary_gie);
  NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->primary_gie, "src");
  NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->queue, "sink");
  ret = TRUE;
done:
  if (!ret) {
    NVGSTDS_ERR_MSG_V ("%s failed", __func__);
  return ret;
#if 0
static gboolean
create_parallel_infer_bin (guint num_sub_bins, NvDsConfig *config,
    NvDsParallelGieBin *bin, AppCtx *appCtx)
  GstElement *sink_elem = NULL;
  GstElement *src_elem = NULL;
  GstElement *nvvidconv = NULL, *caps_filter = NULL;
  GstCaps *caps = NULL;
  GstCapsFeatures *feature = NULL;
  gchar name[50];
  guint i = 0;
  bin->bin = gst_bin_new ("parallel_infer_bin");
  if (!bin->bin) {
    NVGSTDS_ERR_MSG_V ("Failed to create 'parallel_infer_bin'");
    goto done;
  bin->tee = gst_element_factory_make (NVDS_ELEM_TEE, "infer_bin_tee");
  if (!bin->tee) {
    NVGSTDS_ERR_MSG_V ("Failed to create 'infer_bin_tee'");
    goto done;
  gst_bin_add (GST_BIN (bin->bin), bin->tee);
  bin->muxer = gst_element_factory_make ("nvdsmetamux", "infer_bin_muxer");
  if (!bin->muxer) {
    NVGSTDS_ERR_MSG_V ("Failed to create 'infer_bin_muxer'");
    goto done;
  g_object_set (G_OBJECT (bin->muxer), "config-file",
		 GET_FILE_PATH (config->meta_mux_config.config_file_path), NULL);
  NVGSTDS_ELEM_ADD_PROBE (bin->muxer_buffer_probe_id, bin->muxer, "src",
      body_pose_gie_src_pad_buffer_probe, GST_PAD_PROBE_TYPE_BUFFER,
      appCtx);
  gst_bin_add (GST_BIN (bin->bin), bin->muxer);
  for (i = 0; i < num_sub_bins; i++) {
    if (config->primary_gie_sub_bin_config[i].enable
		    || config->video_template_sub_bin_config[i].enable) {
      if (config->video_template_sub_bin_config[i].enable) {
        if (!create_primary_gie_videotemplate_bin (&config->video_template_sub_bin_config[i],
              &bin->primary_gie_bin[i])) {
          goto done;
      } else {
        if (!create_primary_gie_bin (&config->primary_gie_sub_bin_config[i],
          goto done;
      g_snprintf (name, sizeof (name), "primary_gie_%d_bin", i);
      gst_element_set_name (bin->primary_gie_bin[i].bin, name);
      gst_bin_add (GST_BIN (bin->bin), bin->primary_gie_bin[i].bin);
      sink_elem = bin->primary_gie_bin[i].bin;
      src_elem = bin->primary_gie_bin[i].bin;
    if (config->pre_process_sub_bin_config[i].enable) {
      if (!create_preprocess_bin (&config->pre_process_sub_bin_config[i],
            &bin->preprocess_bin[i])) {
        g_print ("creating preprocess bin failed\n");
        goto done;
      g_snprintf (name, sizeof (name), "preprocess_%d_bin", i);
      gst_element_set_name (bin->preprocess_bin[i].bin, name);
      gst_bin_add (GST_BIN (bin->bin), bin->preprocess_bin[i].bin);
      if (sink_elem) {
        NVGSTDS_LINK_ELEMENT (bin->preprocess_bin[i].bin, sink_elem);
      sink_elem = bin->preprocess_bin[i].bin;
    /* Add video convert to avoid parallel infer operate on the same batch meta */
    nvvidconv = gst_element_factory_make ("nvvideoconvert", NULL);
    caps_filter = gst_element_factory_make ("capsfilter", NULL);
    caps =
        gst_caps_new_simple ("video/x-raw",
        "width", G_TYPE_INT, 1920,
        "height", G_TYPE_INT, 1082,
        NULL);
    feature = gst_caps_features_new ("memory:NVMM", NULL);
    gst_caps_set_features (caps, 0, feature);
    g_object_set (G_OBJECT (caps_filter), "caps", caps, NULL);
    gst_bin_add (GST_BIN (bin->bin), nvvidconv);
    gst_bin_add (GST_BIN (bin->bin), caps_filter);
    NVGSTDS_LINK_ELEMENT (nvvidconv, caps_filter);
    NVGSTDS_LINK_ELEMENT (caps_filter, sink_elem);
    sink_elem = nvvidconv;
    link_element_to_tee_src_pad (bin->tee, sink_elem);
    link_element_to_metamux_sink_pad (bin->muxer, src_elem, i);
  NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->tee, "sink");
  NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->muxer, "src");
  ret = TRUE;
done:
  if (!ret) {
  return ret;
#endif
/* Separate a config file entry with delimiters
 * into strings. */
std::vector<std::string> split_string (std::string input) {
  std::vector<int> positions;
  for (unsigned int i = 0; i < input.size(); i++) {
    if (input[i] == ';')
      positions.push_back(i);
  std::vector<std::string> ret;
  int prev = 0;
  for (auto &j: positions) {
    std::string temp = input.substr(prev, j - prev);
    ret.push_back(temp);
    prev = j + 1;
  ret.push_back(input.substr(prev, input.size() - prev));
  return ret;
/* select streamdemux output sources, then link sources and streammux */
static gboolean link_streamdemux_to_streammux(NvDsConfig *config, NvDsParallelGieBin *bin, int i){
    if (config->primary_gie_sub_bin_config[i].unique_id != config->srcids_config[i].pgie_id) {
        NVGSTDS_ERR_MSG_V ("pgieid %d != branch pgieid %d\n",
        config->primary_gie_sub_bin_config[i].unique_id,
         config->srcids_config[i].pgie_id);
         return ret;
    } else {
      std::string str = config->srcids_config[i].src_ids;
      std::vector<std::string> vec = split_string (str);
      for(int j = 0; j < vec.size(); j++) {
        int id = std::stoi(vec[j]);
	    g_print("link_streamdemux_to_streammux, srid:%d, mux:%d\n", id, i);
        if (!link_streamdemux_to_streammux (bin, bin->demuxer, bin->streammux[i], id)) {
          NVGSTDS_ERR_MSG_V ("source %d cannot be linked to mux's sink pad %p\n",
            id, bin->streammux[i]);
          return ret;
    return true;
static gboolean
  gchar name[50];
  guint i, j;
  std::string str;
  std::vector<std::string> vec;
  guint src_id_num;
  if (!bin->bin) {
    goto done;
  if (!bin->tee) {
    goto done;
  if (!bin->muxer) {
    goto done;
      appCtx);
  sink_elem = bin->muxer;
  if (!queue) {
    goto done;
  link_element_to_metamux_sink_pad (bin->muxer, queue, 0);
  sink_elem = queue;
  bin->demuxer =
      gst_element_factory_make (NVDS_ELEM_STREAM_DEMUX, NULL);
  if (!bin->demuxer) {
    NVGSTDS_ERR_MSG_V ("Failed to create element 'demuxer'");
    goto done;
  g_object_set (G_OBJECT (bin->demuxer), "per-stream-eos", TRUE, NULL);
  gst_bin_add (GST_BIN (bin->bin), bin->demuxer);
  sink_elem = bin->demuxer;
  if (!queue) {
    goto done;
  NVGSTDS_LINK_ELEMENT (queue, sink_elem);
  sink_elem = queue;
    sink_elem = src_elem = NULL;
      if (config->num_secondary_gie_sub_bins > 0 && config->num_secondary_gie_num[i] > 0) {
         if (!create_secondary_gie_bin (config->num_secondary_gie_num[i],
              config->secondary_gie_sub_bin_config[i],
              &bin->secondary_gie_bin[i])) {
           g_print("create_secondary_gie_bin failed");
           goto done;
         g_snprintf (name, sizeof (name), "sgie_%d_bin", i);
         gst_element_set_name (bin->secondary_gie_bin[i].bin, name);
      	 gst_bin_add (GST_BIN (bin->bin), bin->secondary_gie_bin[i].bin);
         sink_elem = bin->secondary_gie_bin[i].bin;
         src_elem = bin->secondary_gie_bin[i].bin;
    //add analysis
    if (config->tracker_config[i].enable && config->dsanalytics_config[i].enable) {
      if (!create_dsanalytics_bin (&config->dsanalytics_config[i],
              &bin->dsanalytics_bin[i])) {
        g_print ("creating dsanalytics bin failed\n");
        goto done;
      g_snprintf (name, sizeof (name), "analytics_%d_bin", i);
      gst_element_set_name (bin->dsanalytics_bin[i].bin, name);
      gst_bin_add (GST_BIN (bin->bin), bin->dsanalytics_bin[i].bin);
      if (sink_elem) {
        NVGSTDS_LINK_ELEMENT (bin->dsanalytics_bin[i].bin, sink_elem);
      sink_elem = bin->dsanalytics_bin[i].bin;
      if (!src_elem) {
          src_elem = bin->dsanalytics_bin[i].bin;
    //add tracker
    if (config->tracker_config[i].enable) {
      if (!create_tracking_bin (&config->tracker_config[i],
              &bin->tracker_bin[i])) {
        g_print ("creating tracker bin failed\n");
        goto done;
      g_snprintf (name, sizeof (name), "tracking_%d_bin", i);
      gst_element_set_name (bin->tracker_bin[i].bin, name);
          bin->tracker_bin[i].bin);
      if (sink_elem) {
        NVGSTDS_LINK_ELEMENT (bin->tracker_bin[i].bin, sink_elem);
      sink_elem = bin->tracker_bin[i].bin;
      if (!src_elem) {
         src_elem = bin->tracker_bin[i].bin;
          goto done;
      } else {
          goto done;
      if (sink_elem) {
        NVGSTDS_LINK_ELEMENT (bin->primary_gie_bin[i].bin, sink_elem);
      if (!src_elem) {
        goto done;
      if (sink_elem) {
    /* streamdemux and streammux to select source to inference */
    bin->streammux[i] =
        gst_element_factory_make (NVDS_ELEM_STREAM_MUX, NULL);
    if (!bin->streammux[i]) {
      NVGSTDS_ERR_MSG_V ("Failed to create element 'streammux'");
      goto done;
    gst_bin_add (GST_BIN (bin->bin), bin->streammux[i]);
     if (config->streammux_config.is_parsed){
      if(!set_streammux_properties (&config->streammux_config,
          bin->streammux[i])){
           NVGSTDS_WARN_MSG_V("Failed to set streammux properties");
    src_id_num = vec.size();
    g_print("i:%d, src_id_num:%d\n", i, src_id_num);
    g_object_set (G_OBJECT (bin->streammux[i]), "batch-size", src_id_num, NULL);
    if(!link_streamdemux_to_streammux(config, bin, i)){
        goto done;
    NVGSTDS_LINK_ELEMENT (bin->streammux[i], sink_elem);
    link_element_to_metamux_sink_pad (bin->muxer, src_elem, i+1);
  ret = TRUE;
done:
  if (!ret) {
  return ret;
static gboolean
add_and_link_broker_sink (AppCtx * appCtx)
  NvDsConfig *config = &appCtx->config;
  /** Only first instance_bin broker sink
   * employed as there's only one analytics path for N sources
   * NOTE: There shall be only one [sink] group
   * with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
   * a) Multiple of them does not make sense as we have only
   * one analytics pipe generating the data for broker sink
   * b) If Multiple broker sinks are configured by the user
   * in config file, only the first in the order of
   * appearance will be considered
   * and others shall be ignored
   * c) Ideally it should be documented (or obvious) that:
   * multiple [sink] groups with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
   * is invalid
  NvDsInstanceBin *instance_bin = &appCtx->pipeline.instance_bins[0];
  NvDsPipeline *pipeline = &appCtx->pipeline;
  for (guint i = 0; i < config->num_sink_sub_bins; i++) {
    if(config->sink_bin_sub_bin_config[i].type == NV_DS_SINK_MSG_CONV_BROKER)
      /** add the broker sink bin to pipeline */
      if(!gst_bin_add (GST_BIN (pipeline->pipeline), instance_bin->sink_bin.sub_bins[i].bin)) {
        return FALSE;
      g_print("add_and_link_broker_sink\n");
      // link the broker sink bin to the sink tee
      if (!link_element_to_tee_src_pad (instance_bin->sink_tee, instance_bin->sink_bin.sub_bins[i].bin)) {
        return FALSE;
  return TRUE;
int main(int argc, char *argv[])
  GOptionContext *ctx = NULL;
  GOptionGroup *group = NULL;
  GstElement *last_elem = NULL;
  NvDsInstanceBin *instance_bin;
  NvDsPipeline *pipeline;
  NvDsConfig *config;
  GstBus *bus = NULL;
  guint bus_watch_id = 0;
  GstPad *osd_sink_pad = NULL;
  GError *error = NULL;
  guint i;
  const gchar *new_mux_str = NULL;
  gboolean use_new_mux = FALSE;
  ctx = g_option_context_new ("Nvidia DeepStream Parallel Demo");
  group = g_option_group_new ("abc", NULL, NULL, NULL, NULL);
  g_option_group_add_entries (group, entries);
  g_option_context_set_main_group (ctx, group);
  g_option_context_add_group (ctx, gst_init_get_option_group ());
  GST_DEBUG_CATEGORY_INIT (NVDS_APP, "NVDS_APP", 0, NULL);
  if (!g_option_context_parse (ctx, &argc, &argv, &error)) {
    NVGSTDS_ERR_MSG_V ("%s", error->message);
    return -1;
  if (print_version) {
    g_print ("deepstream-app version %d.%d.%d\n",
        NVDS_APP_VERSION_MAJOR, NVDS_APP_VERSION_MINOR, NVDS_APP_VERSION_MICRO);
    nvds_version_print ();
    return 0;
  if (print_dependencies_version) {
    nvds_dependencies_version_print ();
    return 0;
  if (!cfg_files) {
    NVGSTDS_ERR_MSG_V ("Specify config file with -c option");
    return_value = -1;
    goto done;
  appCtx = (AppCtx *)g_malloc0 (sizeof (AppCtx));
  appCtx->person_class_id = -1;
  appCtx->car_class_id = -1;
  appCtx->index = i;
  appCtx->active_source_index = -1;
  if (show_bbox_text) {
    appCtx->show_bbox_text = TRUE;
  if (!parse_config_file_yaml (&appCtx->config, cfg_files[0])) {
    NVGSTDS_ERR_MSG_V ("Failed to parse config file '%s'", cfg_files[0]);
    appCtx->return_value = -1;
    goto done;
  /* Standard GStreamer initialization */
  gst_init(&argc, &argv);
  main_loop = g_main_loop_new(NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline->pipeline = gst_pipeline_new("deepstream-tensorrt-openpose-pipeline");
   * Add muxer and < N > source components to the pipeline based
   * on the settings in configuration file.
  if (!create_multi_source_bin (config->num_source_sub_bins,
          config->multi_source_config, &pipeline->multi_src_bin)) {
      g_print ("creating multi source bin failed\n");
      goto done;
  gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->multi_src_bin.bin);
  /* if using new sreammux, nvvideocovnert will scale input resolutions to the same resolution */
  new_mux_str = g_getenv ("USE_NEW_NVSTREAMMUX");
  use_new_mux = !g_strcmp0 (new_mux_str, "yes");
  if (use_new_mux) {
      GstCaps* caps = NULL;
      gchar * caps_string = NULL;
      GstCaps* fiter_caps = NULL;
      char strCaps[MAX_STR_LEN] = {0};
      for (int i = 0; i < config->num_source_sub_bins; i++){
          g_object_get (G_OBJECT (pipeline->multi_src_bin.sub_bins[i].cap_filter1), "caps", &caps, NULL);
          caps_string = gst_caps_to_string (caps);
          snprintf(strCaps, MAX_STR_LEN-1, "%s,width=%d, height=%d", caps_string,
            config->streammux_config.pipeline_width, config->streammux_config.pipeline_height);
          fiter_caps = gst_caps_from_string (strCaps);
          g_object_set (G_OBJECT (pipeline->multi_src_bin.sub_bins[i].cap_filter1), "caps", fiter_caps, NULL);
          printf("strCaps:%s\n", strCaps);
          gst_caps_unref (caps);
          gst_caps_unref (fiter_caps);
          g_free (caps_string);
        pipeline->multi_src_bin.streammux)){
  if (!create_parallel_infer_bin (config->num_primary_gie_sub_bins,
          config, &pipeline->parallel_infer_bin, appCtx)) {
      g_print ("creating parallel infer bin failed\n");
      goto done;
  gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->parallel_infer_bin.bin);
  last_elem = pipeline->parallel_infer_bin.bin;
  NVGSTDS_LINK_ELEMENT (pipeline->multi_src_bin.bin, last_elem);
  /* Add common message converter */
  if (config->msg_conv_config.enable) {
    NvDsSinkMsgConvBrokerConfig *convConfig = &config->msg_conv_config;
    instance_bin->msg_conv = gst_element_factory_make (NVDS_ELEM_MSG_CONV, "common_msg_conv");
    if (!instance_bin->msg_conv) {
      NVGSTDS_ERR_MSG_V ("Failed to create element 'common_msg_conv'");
      goto done;
    g_object_set (G_OBJECT(instance_bin->msg_conv),
          "config", convConfig->config_file_path,
          "msg2p-lib", (convConfig->conv_msg2p_lib ? convConfig->conv_msg2p_lib : "null"),
          "payload-type", convConfig->conv_payload_type,
          "comp-id", convConfig->conv_comp_id,
          "debug-payload-dir", convConfig->debug_payload_dir,
          "multiple-payloads", convConfig->multiple_payloads, NULL);
                  instance_bin->msg_conv);
    NVGSTDS_LINK_ELEMENT (last_elem, instance_bin->msg_conv);
    last_elem = instance_bin->msg_conv;
  if (config->tiled_display_config.enable) {
    if (config->tiled_display_config.columns *
        config->tiled_display_config.rows < config->num_source_sub_bins) {
      if (config->tiled_display_config.columns == 0) {
            (guint) (sqrt (config->num_source_sub_bins) + 0.5);
      config->tiled_display_config.rows =
          (guint) ceil (1.0 * config->num_source_sub_bins /
          config->tiled_display_config.columns);
      NVGSTDS_WARN_MSG_V
          ("Num of Tiles less than number of sources, readjusting to "
          "%u rows, %u columns", config->tiled_display_config.rows,
    if (!create_tiled_display_bin (&config->tiled_display_config,
            &pipeline->tiled_display_bin)) {
      g_print ("creating tiled display bin failed\n");
      goto done;
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiled_display_bin.bin);
    if(config->show_source != -1){
      //default -1 means composite and show all sources
      g_object_set(G_OBJECT(pipeline->tiled_display_bin.tiler), "show-source", config->show_source, NULL);
      g_print("show-source:%d\n", config->show_source);
    NVGSTDS_LINK_ELEMENT (last_elem, pipeline->tiled_display_bin.bin);
    last_elem = pipeline->tiled_display_bin.bin;
  if (config->osd_config.enable) {
    if (!create_osd_bin (&config->osd_config, &instance_bin->osd_bin)) {
      g_print ("creating osd bin failed\n");
      goto done;
    gst_bin_add (GST_BIN (pipeline->pipeline), instance_bin->osd_bin.bin);
    NVGSTDS_LINK_ELEMENT (last_elem, instance_bin->osd_bin.bin);
    last_elem = instance_bin->osd_bin.bin;
    /* Lets add probe to get informed of the meta data generated, we add probe to
     * the sink pad of the osd element, since by that time, the buffer would have
     * had got all the metadata. */
    osd_sink_pad = gst_element_get_static_pad(instance_bin->osd_bin.nvosd, "sink");
    if (!osd_sink_pad)
      g_print("Unable to get sink pad\n");
    else
      gst_pad_add_probe(osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
                        osd_sink_pad_buffer_probe, NULL, NULL);
    GstPad *sink_pad =  gst_element_get_static_pad (nvvidconv1, "src");
    if (!sink_pad)
      g_print ("Unable to get sink pad\n");
    else {
      LatencyCtx *ctx = (LatencyCtx *)g_malloc0(sizeof(LatencyCtx));
      ctx->lock = (GMutex *)g_malloc0(sizeof(GMutex));
      ctx->num_sources = argc - 2;
      gst_pad_add_probe (sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
          latency_measurement_buf_prob, ctx, NULL);
    gst_object_unref (sink_pad);
    GstPad *tiler_pad =  gst_element_get_static_pad (nvtiler, "sink");
    if (!tiler_pad)
      g_print ("Unable to get tiler_pad pad\n");
    else {
      NvDsAppPerfStructInt *str =  (NvDsAppPerfStructInt *)g_malloc0(sizeof(NvDsAppPerfStructInt));
      DemoPerfCtx *perf_ctx = (DemoPerfCtx *)g_malloc0(sizeof(DemoPerfCtx));
      g_mutex_init(&perf_ctx->fps_lock);
      str->context = perf_ctx;
      enable_perf_measurement (str, tiler_pad, argc-2, 1, 0, perf_cb);
    gst_object_unref (tiler_pad);
  //create sink_tee
  instance_bin->sink_tee = gst_element_factory_make (NVDS_ELEM_TEE, "sink_tee");
  if (!instance_bin->sink_tee) {
    NVGSTDS_ERR_MSG_V ("Failed to create 'sink_tee'");
    goto done;
  gst_bin_add (GST_BIN (pipeline->pipeline), instance_bin->sink_tee);
  NVGSTDS_LINK_ELEMENT (last_elem, instance_bin->sink_tee);
  last_elem = instance_bin->sink_tee;
  if (!create_sink_bin (config->num_sink_sub_bins,
        config->sink_bin_sub_bin_config, &instance_bin->sink_bin, 0)) {
    g_print ("creating sink bin failed\n");
    goto done;
  //x264enc will output one buffer after input 66 buffers at default, enable zerolatency property.
  for(int i = 0; i < config->num_sink_sub_bins; i++){
      if(config->sink_bin_sub_bin_config[i].encoder_config.enc_type == NV_DS_ENCODER_TYPE_SW)
        g_object_set (G_OBJECT (instance_bin->sink_bin.sub_bins[i].encoder), "tune", 0x4, NULL);
  gst_bin_add (GST_BIN (pipeline->pipeline), instance_bin->sink_bin.bin);
  NVGSTDS_LINK_ELEMENT (last_elem, instance_bin->sink_bin.bin);
  //link broker to sink-tee
  add_and_link_broker_sink(appCtx);
  /* we add a message handler */
  bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline->pipeline));
  bus_watch_id = gst_bus_add_watch(bus, bus_call, main_loop);
  gst_object_unref(bus);
  /* Set the pipeline to "playing" state */
  gst_element_set_state(pipeline->pipeline, GST_STATE_PLAYING);
  GST_DEBUG_BIN_TO_DOT_FILE(GST_BIN(pipeline->pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "pipeline");
  /* Wait till pipeline encounters an error or EOS */
  g_print("Running...\n");
  g_main_loop_run(main_loop);
done:
  g_print ("Quitting\n");
  if (bus_watch_id) {
    g_print("Returned, stopping playback\n");
    gst_element_set_state(pipeline->pipeline, GST_STATE_NULL);
    g_print("Deleting pipeline\n");
    gst_object_unref(GST_OBJECT(pipeline->pipeline));
    g_source_remove(bus_watch_id);
  if (appCtx) {
    if (appCtx->return_value == -1)
      return_value = -1;
    g_free (appCtx);
  if (main_loop) {
    g_main_loop_unref (main_loop);
  if (ctx) {
    g_option_context_free (ctx);
  if (return_value == 0) {
    g_print ("App run successful\n");
  } else {
    g_print ("App run failed\n");
  gst_deinit ();
  return return_value;
and this is the error
deepstream_parallel_infer_app.cpp: In function 'GstPadProbeReturn osd_sink_pad_buffer_probe(GstPad*, GstPadProbeInfo*, gpointer)':
deepstream_parallel_infer_app.cpp:689:75: warning: zero-length gnu_printf format string [-Wformat-zero-length]
  689 |     offset = snprintf(txt_params->display_text + offset, MAX_DISPLAY_LEN, "");
deepstream_parallel_infer_app.cpp:694:41: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
  694 |     txt_params->font_params.font_name = "Mono";
deepstream_parallel_infer_app.cpp: In function 'int main(int, char**)':
deepstream_parallel_infer_app.cpp:1567:53: error: 'nvvidconv1' was not declared in this scope
 1567 |     GstPad *sink_pad =  gst_element_get_static_pad (nvvidconv1, "src");
deepstream_parallel_infer_app.cpp:1579:54: error: 'nvtiler' was not declared in this scope
 1579 |     GstPad *tiler_pad =  gst_element_get_static_pad (nvtiler, "sink");
make: *** [Makefile:70: deepstream_parallel_infer_app.o] Error 1
You can port the c code to c++ code.
But I am getting this error, how do I fix it? I ported the exact same patch
The error has told you the reason, you need to define the variable before using it. It is just a normal c++ variable usage problem. The c++ programming book may help you. Learn C++ Programming (programiz.com)
But I am asking wrt to deepstream.
GstElement *nvvidconv = NULL;
GstElement *nvtiler = NULL;
is this how I am supposed to do it? do I need to add anything else?
Seems you don’t understand what the code is for.
There is a simpler sample deepstream_tao_apps/apps/tao_detection/deepstream_det_app.c at master · NVIDIA-AI-IOT/deepstream_tao_apps (github.com). This code works too.
Or you can change the code to add the latency_measurement_buf_prob() to the nvdsosd src pad.
i added in
nvvidconv1 = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter1");
nvtiler = gst_element_factory_make("nvmultistreamtiler", "nvtiler");
and this is what i’m getting, it doesn’t print fps
(deepstream-parallel-infer:123562): GStreamer-CRITICAL **: 08:32:03.294: gst_element_get_static_pad: assertion 'GST_IS_ELEMENT (element)' failed
(deepstream-parallel-infer:123562): GStreamer-CRITICAL **: 08:32:03.294: gst_object_unref: assertion 'object != NULL' failed
What do you mean? Are you trying to apply the patch to deepstream-test2?
No, deepstream_parallel_infer_app.cpp
There is no “nvvidconv1” or “nvtiler” in deepstream_parallel_inference_app/tritonclient/sample/apps/deepstream-parallel-infer/deepstream_parallel_infer_app.cpp at master · NVIDIA-AI-IOT/deepstream_parallel_inference_app (github.com).
Please make sure you are familiar with GStreamer before you try to customize any DeepStream sample app.
You may add the probe function in the nvdsosd sink pad. deepstream_parallel_inference_app/tritonclient/sample/apps/deepstream-parallel-infer/deepstream_parallel_infer_app.cpp at master · NVIDIA-AI-IOT/deepstream_parallel_inference_app (github.com)
Thanks for sharing this, I went through the gstreamer docu to add in probe but it is still not very clear.
    if (!osd_sink_pad)
    else
      gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
      enable_perf_measurement (str, osd_sink_pad, argc-2, 1, 0, perf_cb);
      gst_object_unref (osd_sink_pad);
I added in the probe function in the nvdsosd sink pad like this which is giving me seg fault, could you help me with this?
if there’s any easy implementation of how to add a probe to a sink pad, could you share that with me or help me out on this probe itself? thanks
@chanduhna
I met core dump with the latency measurement interface in the deepstream_parallel_inference_app, I’m investigating the root cause. I will be back when there is any progress.
@chanduhna
The following patch works with the NVIDIA-AI-IOT/deepstream_parallel_inference_app: A project demonstrating how to use nvmetamux to run multiple models in parallel. (github.com)
diff.txt (3.8 KB)
Thanks for this patch, core dump issue is gone but it is not printing out the fps for me, this is how it looks
Did it print out the fps for you with this exact patch?
Update the patch
diff.txt (3.8 KB)
This works, thanks a lot!
