• Hardware Platform (Jetson / GPU) Jetson Xavier NX • DeepStream Version 6.0 • JetPack Version (valid for Jetson only) 4.6 • TensorRT Version 8.0.1-1
Hi I’m trying to save .mp4 output when using yolo.
It seems to save output video well when I run it for a minute.
But when I run it for a day, the stored video does not work and shows ‘This file contains no playable streams’.
From the configuration, you used rtsp streaming, but file saving disabled? did you put the wrong properties or you use othe method to save the output? and did you notice whe you run for more than one day, the storage remaining of the device? and which input source you used?
Sorry! both of rtsp streaming and file saving was enabled.
I used 1TB ssd for storage so i think storage does not matter.
For the input source, I used two IP cameras and checked both of them works well
from your screenshot, the video output sink is not enabled.
If it’s enabled, please refer to “4.1 deepstream-app” section in DeepStream SDK FAQ - #10 by mchi to capture the GStreamer Pipeline Graph and sahre with us.
Hi mchi
the sink was enabled.
I tried to use ‘dot -Tpng’ to change dot file to png.
However there was two playing,dot file and i was not sure which file i should use.
so I converted both of them.
please let me know if you need any other file.
Sorry! The 2nd image is too blur.
Could you share the detailed repo files and steps based on
/opt/nvidia/deepstream/deepstream-6.0/sources/objectDetector_Yolo/deepstream_app_config_yoloV3.txt ?
