Deepstream 6.1.1 Could not open resource for reading and writing
• Hardware Platform (Jetson / GPU) Jetson Xavier
• DeepStream Version 6.1.1
• JetPack Version (valid for Jetson only) 5.0.2
• TensorRT Version not sure where to find that
• Issue Type( questions, new requirements, bugs) question
I’m trying to run deepstream-rtsp-in-rtsp-out from the nvidia github and the app crashes at startup with this error message :
Could not open resource for reading and writing. (7): gstrtspsrc.c(7893): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstURIDecodeBin:uri-decode-bin/GstRTSPSrc:source:
Failed to connect. (Generic error)
I tested successfully with this Gstreamer command :
gst-launch-1.0 rtspsrc location=rtsp://192.168.3.11:554/video ! fakesink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:2gKNP6o3ZArhME@192.168.3.55:554/h264Preview_01_main
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (request) SETUP stream 1
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
Are you linking too many sources that your server cannot support? You can add the GST_DEBUG=3 before the cli command to open more log info.
It’s working now. Thanks!
