Jetson Xavier NX
• DeepStream Version
6.0
4.6.2-b5
bug
- Configure deepstream-app to use an RTSP source (
source2
in my config) and keep reconnecting if the connection fails:
[source0]
enable=1
type=2
[source2]
enable=1
type=4
uri=rtsp://localhost:544/rtsp_live0
rtsp-reconnect-interval-sec=1
rtsp-reconnect-attempts=-1 # keep trying reconnecting forever
- Run the app
- When it’s up and running, interrupt that RTSP stream (I use an IP camera so just unplug an Ethernet cable from it).
- After a short while the app finishes the following error message:
ERROR from src_elem1: Could not open resource for reading and writing.
Debug info: gstrtspsrc.c(7469): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstRTSPSrc:src_elem1:
Failed to connect. (Generic error)
It should not be like that because I asked the app to reconnecting to the RTSP source indefinitely.
Solution: it seems like a simple change fixes it (line 143 of deepstream_app.c
if ((i != bin->num_bins) &&
(appCtx->config.multi_source_config[0].type == NV_DS_SOURCE_RTSP))
should be multi_source_config[i]
and it works as expected in my case.
The same applies to line 158.
