I run the deepstream5.0 app example on JetsonNX. When you reinsert the network cable, the following error occurs, causing the program to exit. This error seems to be caused by the failure to obtain the RTSP stream, and the probability of this error is high.
WARNING from source: Could not read from resource.
Debug info: gstrtspsrc.c(5293): gst_rtspsrc_loop_udp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstURIDecodeBin:src_elem/GstRTSPSrc:source:
Unhandled return value -7.
ERROR from source: Could not read from resource.
Debug info: gstrtspsrc.c(5361): gst_rtspsrc_loop_udp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstURIDecodeBin:src_elem/GstRTSPSrc:source:
Could not receive message. (System error)
ERROR from source: Internal data stream error.
Debug info: gstrtspsrc.c(5653): gst_rtspsrc_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstURIDecodeBin:src_elem/GstRTSPSrc:source:
streaming stopped, reason error (-5)
Quitting
App run failed
The system environment is as follows:
Jetpack: 4.5.1 (L4T 32.5.1)
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 7.1
cuDNN Version: 8.0
libNVWarp360 Version: 2.0.1d3
GStreamer Core Library version 1.14.5
libgstrtspserver-1.0-0 1.14.5-0ubuntu1~18.04.1
The main configuration files of the app are as follows:
[source0]
enable=1
## Type: 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=rtsp://admin:1234@xx.xx.xx.xx:554/cam/realmonitor?channel=1&subtype=0
num-sources=1
camera-id=1
gpu-id=0
cudadec-memtype=0
drop-frame-interval=5
[source1]
enable=1
type=3
num-sources=1
camera-id=2
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
## Type: 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=4
rtsp-port=8554
udp-port=5400
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
## 1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
bitrate=4000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=12
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
## Boolean property to inform muxer that sources are live
live-source=1
batch-size=4
batched-push-timeout=40000
## Set muxer output width and height
width=1280
height=720
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
model-engine-file=zj.engine
labelfile-path=labels-zj.txt
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
Also, if there are multiple cameras in the App Source configuration, but one of them is disconnected from the network. Running the deepstream-app program in this state causes the following error:
** INFO: <bus_callback:144>: Pipeline running
ERROR from source: Could not open resource for reading and writing.
Debug info: gstrtspsrc.c(7469): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin5/GstURIDecodeBin:src_elem/GstRTSPSrc:source:
Failed to connect. (Generic error)
Quitting
App run failed
