T4 ( GPU ) • DeepStream Version
6.1 • TensorRT Version
8.2.5.1-1+cuda11.4 or 8.4.1.5-1+cuda11.6 • NVIDIA GPU Driver Version (valid for GPU only)
510.47.03 • Issue Type( questions, new requirements, bugs)
question • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
When cuda 11.6.1 is installed, tensorRT can only be installed in the tar method due to the dependency problem of 8.2.5.1 installation. Isn’t this documentation incorrect?
Hi, @yuweiw . There’s no error msg.
TensorRT version is installed as 8.4.1.5, not 8.2.5.1.
The guide document’s TensorRT version is 8.2.5.1.
I have two questions.
Do you recommend TensorRT 8.2.5.1 version? And can it be installed?
If version 8.4.1.5 is recommended, is there a problem with the version of the guide document?
We suggest TensorRT 8.2.5.1 as our guide says. You can find the version in our guide. We develop and debug the DeepStream 6.1 code in this env, so it could have better compatibility when you use the version we recommended. Thanks
