Deepstream 6.1 run secondary gie on outputs of all previous primary gies; operate-on-gie-id=all
• Hardware Platform (Jetson / GPU) - RTX 2070 dGPU
• DeepStream Version - 6.1
• JetPack Version (valid for Jetson only) - NA
• TensorRT Version - 8.4.2.1
• NVIDIA GPU Driver Version (valid for GPU only) - 510.
• Issue Type( questions, new requirements, bugs) - question on feature
I am trying to create a Deepstream Pipeline that involves multiple detectors configured to run full-frame as primary. I also have a classifier running as secondary as third gie. I want this classifier to work on bboxes from all the previous detectors. Unfortunately, there is a setting called operate-on-gie-id=1 which seems to restrict this classifier to a single primary detector only.
[pgie1]
process-mode=1 #primary  detector
gie-unique-id=1
[pgie2]
process-mode=1 #another primary detector
gie-unique-id=2
[sgie1]
process-mode=2 #secondary clf
gie-unique-id=3
operate-on-gie-id=1 <--- select all previous pgies.
I want to know if its possible to run one classifier in secondary mode to bbox outputs of all previous primary detectors?
You can refer the link below to learn how to use multiple detectors.
https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/back-to-back-detectors
