Deepstream-app multiple primary detectors
Setup:
deepstream-5.1 docker
I am trying to use multiple detctors within deepstream-app. My goal is to predict full frame with first detector and then predict on full frame with second detector. Then I want to process both detectors results in my plugin.
I’ve tried creating secondary-gie with process-mode=1, althought it seems to be detecting (does not draw on osd), but when I am postprocessing in my plugin obj_meta has detections only from first detector, second detector results are always missing.
I have also tried looking into back-to-back example, but so far I am not sure how to implement it in deepstream-app. Any guidance or tips would be really appreciated on what should I change to receive both detectors obj_meta
• DeepStream Version
• TensorRT Version
This should be 0 for full frame
