Ravik
January 2, 2020, 4:03pm
1
For the deepstream-app example, I want to change the secondary classifier to the detector
I have referred to back to back example
/* Change this to 0 to make the 2nd detector act as a primary(full-frame) detector.
When set to 1, it will act as secondary(operates on primary detected objects). */
#define SECOND_DETECTOR_IS_SECONDARY 1
in Deepstream-app how do change secondary classifier to the detector, that operates under the primary detector
create_common_elements (NvDsConfig * config, NvDsPipeline * pipeline,
GstElement ** sink_elem, GstElement ** src_elem,
bbox_generated_callback bbox_generated_post_analytics_cb)
gboolean ret = FALSE;
*sink_elem = *src_elem = NULL;
if (config->primary_gie_config.enable) {
if (config->num_secondary_gie_sub_bins > 0) {
if (!create_secondary_gie_bin (config->num_secondary_gie_sub_bins,
config->primary_gie_config.unique_id,
config->secondary_gie_sub_bin_config,
&pipeline->common_elements.secondary_gie_bin)) {
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline),
pipeline->common_elements.secondary_gie_bin.bin);
if (!*src_elem) {
*src_elem = pipeline->common_elements.secondary_gie_bin.bin;
if (*sink_elem) {
NVGSTDS_LINK_ELEMENT (pipeline->common_elements.secondary_gie_bin.bin,
*sink_elem);
*sink_elem = pipeline->common_elements.secondary_gie_bin.bin;
bcao
January 3, 2020, 8:05am
2
Please refer to secondary_detector_config.txt in back-to-back-detector example to set secondary classifier to secondary detector.
U need to update the secondary classifier config group section as per above mentioned secondary detector config file.
Ravik
January 3, 2020, 11:15am
3
[secondary-gie0]
enable=1
gpu-id=0
#model-engine-file=../../models/lp_eu_full/model_iter_45000.caffemodel_b30_fp16.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=30
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
config-file=lp_eu_full.txt
[tests]
file-loop=0
in lp_eu.txt
[property]
gpu-id=0
process-mode=2
it throws out a segmentation fault
mean-file, gie-unique-id(Default=0), offsets, process-mode (Default=1 i.e. primary),
custom-lib-path, network-mode(Default=0 i.e FP32)
bcao
January 6, 2020, 5:16am
4
Would you mind to share the lp_eu_full.txt which should refer secondary detector config file in comment #2 ?
Ravik
January 6, 2020, 12:27pm
5
[property]
gpu-id=0
model-file=odel_iter_45000.caffemodel
proto-file=net_tensorRT.proto
model-engine-file=model_iter_45000.caffemodel_b30_fp16.engine
labelfile-path=corresp.txt
batch-size=30
process-mode=2
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=2
interval=0
gie-unique-id=2
output-blob-names=[removed, this is working for primary, plugin is tested and working]
parse-bbox-func-name=NvDsInferParseCustomSSD
custom-lib-path=libnvdsinfer_custom_impl_ssd_lp.so
enable-dbscan=1
input-object-min-width=64
input-object-min-height=64
[class-attrs-all]
threshold=0.3
group-threshold=1
## Set eps=0.7 and minBoxes for enable-dbscan=1
eps=0.3
#minBoxes=3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
Do I need to add
operate-on-gie-id=1
gie-unique-id=2
operate-on-class-ids=1;2;3;4;5;6;7
Amycao
January 7, 2020, 9:03am
6
If your case is to make the 2nd detector act as a primary(full-frame) detector, you do not need this.
Ravik
January 7, 2020, 11:30am
7
Primary detector [car, bus] → Secondary detector[ROI] → Secondary classifier[0]–> Secondary classifier[1]
This is the pipeline
Ravik
January 7, 2020, 12:55pm
8
There is no reference of process-mode 2 in the reference documentation
https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/blob/master/back-to-back-detectors/secondary_detector_config.txt
https://docs.nvidia.com/metropolis/deepstream/4.0/dev-guide/#page/DeepStream_Development_Guide%2Fdeepstream_app_config.3.1.html
Amycao
January 8, 2020, 3:16am
9
Gst Properties
process-mode
Infer Processing Mode
1=Primary Mode
2=Secondary Mode
Integer, 1 or 2
Amycao
January 8, 2020, 6:02am
10
goto done;
if (!*src_elem) {
if (*sink_elem) {
*sink_elem);
HI
about change the secondary classifier to the detector, as I know, classifier can not be used as detector
Ravik
January 8, 2020, 10:06am
11
I went through deepstream_primary_gie_bin.c and deepstream_secondary_gie_bin.c
I think we can set it up as detector, need to create bbox function for secondary gie in deepstream_app.c[371]. I will keep you posted
Ravik
January 8, 2020, 10:45am
12
g_object_set (G_OBJECT (secondary_detector), "config-file-path", "secondary_detector_config.txt",
"unique-id", SECONDARY_DETECTOR_UID, "process-mode", <b>SECOND_DETECTOR_IS_SECONDARY ? 2 : 1</b>, NULL);
what does this mean ? unique-id 2, process-mode 1 why do you need to double check ?
Amycao
January 9, 2020, 2:17am
13
process-mode as explained before
unique-id, see this, https://docs.nvidia.com/metropolis/deepstream/plugin-manual/index.html#page/DeepStream_Plugin_Manual%2Fdeepstream_plugin_details.02.01.html%23wwpID0E0IZ0HA
Gst Properties part
Ravik
January 20, 2020, 8:47am
14
Can you release an example using NVinfer as primary and secondary in the same program
Amycao
February 11, 2020, 10:12am
15
Ravik
February 11, 2020, 6:58pm
16
Thanks, we resolved it, we are releasing it at Berlin event.
xh2261
June 9, 2021, 1:17am
17
Hi Ravik, I want to integrate a secondary detector in deepstream-app. How did you modify the source code to support this, could you share some experience? Many thanks
