Deepstream 6.4 Smart Record Video Issue with bbox enabled
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.4
• TensorRT Version 8.6.1
• NVIDIA GPU Driver Version (valid for GPU only) 535
• Issue Type( questions, new requirements, bugs) Bug
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) deepstream_testsr sample app with bbox enabled
What happens is, when we use the smart record bin at the sink end of the pipeline, after the encoder, the resulting video is glitchy with randomly occurring gray/green dots. Interestingly enough, the first video is always fine, but from the second video on, this corrupted video starts to occur. The problem is probably not in the smart record, when it’s used before the decoder at the beginning of the pipeline, videos are all fine.
Another observation is, iframeinterval config for the encoder changes the result. With bigger values, the size of the gray dots and glitches are worse. Making it 1 eliminates these gray dots, but it’s not a good idea and reduces the overall video quality.
This was not happening in deepstream 6.1. What could be the problem here?
Can you describe your specific steps so we can reproduce that on our side? Thanks
Thank you for the reply. Just run the sample app deepstream_testsr with bbox enabled. It should be something like this: ./deepstream-testsr-app rtsp:/source_url --sink-type=1 --bbox-enable=1
The resulting pipeline will be like the following
0.29.09.519062575-pipeline_.pdf (93.4 KB)
As I mentioned, the first recorded video is almost always ok. The problem starts with the next videos.
Could you try to change the enc_type and see if there is still a problem?
Already tried, but it’s still the same, unfortunately.
This test confirmed that the problem was not related to the encoder. As you said before, when add that before the decoder plugin, it works normally.
So you can do the following comparison test to remove some of the plugins to see if there are problems, like nvdsosd, etc…
nvdsosd is not the problem because I saw the same thing also without using it. maybe nvvideoconvert could be the problem, do you think the issue below might be related to what I experience?
https://forums.developer.nvidia.com/t/deepstream-6-4-green-screen-with-rtsp/288979/11
No. That topic will cause the whole picture to be green screen. As you said, it’s just glitchy with randomly occurring gray/green dots. I don’t see any obvious problems on my side, can you narrow it down yourself to see which plugin might have problems? You can also attach the video generated.
I’ll get back to you with several tests on plugins to narrow it down. In the meantime, can I get your opinion on how iframeinterval config changes the behaviour, if it’s not related to the encoder plugin at all? What is your guess?
From this parameter alone, I initially guessed that it was related to the encoder. But as you said, after changing the enc_type, the result is still the same. This is a little weird. Can you double check that the result is the same after changing the enc_type?
