Deepstream 6.1 green frames with RTSP
• Hardware Platform (Jetson / GPU): GPU NVIDIA A100-SXM4-40GB
• DeepStream Version: 6.1
• TensorRT Version: 8.2.5.1
• NVIDIA GPU Driver Version (valid for GPU only): 510.47.03
• Issue Type( questions, new requirements, bugs): bugs
• How to reproduce the issue? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
I am running the nvcr.io/nvidia/deepstream:6.1-devel docker container on a virtualized Linux server. The server has NVIDIA GPU Driver 510.47.03 installed and access to NVIDIA A100-SXM4-40GB GPU. I also have nvidia-container-toolkit installed and have confirmed that the deepstream:6.1-devel container has access to GPU and CUDA features.
I am using the deepstream:6.1-devel container to run deepstream analytics on various RTSP streams from IP cameras. Here is an example of the code I am using. It has been adapted from deepstream-nvdsanalytics (deepstream_python_apps/apps/deepstream-nvdsanalytics at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub).
example.py (14.3 KB)
I am able to successfully run the analytics with video files and some RTSP streams, but other RTSP streams seem to cause problems with the nvv4l2decoder. With some RTSP streams the decoder seems to produce only green frames to the output video.
With some trial and error, I noticed that this has something to do with the decoder buffers as increasing the decoder’s ‘num-extra-surfaces’ property to the maximum value of 24 seems to alleviate the problem. With the 24 extra surfaces only 4 consecutive frames out of 25 each second are green. With less extra surfaces the number of consecutive green frames increases and with 0 extra surfaces all frames are green.
I have also confirmed that the green frames are not caused by the encoding as I can run the same code with nvmultistreamtiler, nvvideoconvert, nvdsosd, nvvideoconvert, capsfilter, avenc_mpeg4, mpeg4videoparse, qtmux and filesink replaced with a fakesink and still see consecutive empty nvds_batch_meta buffers every second.
The IP cameras that I use are from various manufacturers and the ones that are causing this problem seem to be somewhat randomly distributed. I have tested the camera streams with VLC and Gstreamer without Nvidia components and they both produce normal video output. I am sorry but I cannot provide more specific information about the cameras on a public forum. I can share specific information about the cameras privately If needed.
Can you save the video bitstream and playback with and without NV video decoder?
I can save one of the RTSP video streams to a file with:
gst-launch-1.0 -e rtspsrc location=rtsp://URL:PORT ! rtph264depay ! h264parse ! mp4mux ! filesink location=/video.mp4
With the output video file I can run these two pipelines:
gst-launch-1.0 -e filesrc location=/video.mp4 ! qtdemux ! multiqueue ! h264parse ! capsfilter ! avdec_h264 ! videoconvert ! capsfilter ! avenc_mpeg4 ! mpeg4videoparse ! qtmux ! filesink location=/re-encoded_no_nv.mp4
gst-launch-1.0 -e filesrc location=/video.mp4 ! qtdemux ! multiqueue ! h264parse ! capsfilter ! nvv4l2decoder ! nvvideoconvert ! capsfilter ! avenc_mpeg4 ! mpeg4videoparse ! qtmux ! filesink location=/re-encoded_nv.mp4
Both of the pipelines produce a normal video without green frames.
I also quickly tested the same pipelines with RTSP:
gst-launch-1.0 -e rtspsrc location=rtsp://URL:PORT ! rtph264depay ! h264parse ! capsfilter ! avdec_h264 ! videoconvert ! capsfilter ! avenc_mpeg4 ! mpeg4videoparse ! qtmux ! filesink location=rtsp_no_nv.mp4
gst-launch-1.0 -e rtspsrc location= rtsp://URL:PORT ! rtph264depay ! h264parse ! capsfilter ! nvv4l2decoder ! nvvideoconvert ! capsfilter ! avenc_mpeg4 ! mpeg4videoparse ! qtmux ! filesink location=rtsp_nv.mp4
The resulting rtsp_no_nv.mp4 is a normal video from the IP camera while rtsp_nv.mp4 contains only green frames.
It is strange that you can’t reproduce it after save to file. Can you check any difference between them for NV decoder?
What kind of differences should I look for? Can you elaborate what should I test to get you a better description of the problem?
Per your description, the result is fine if save RTSP stream to file. Can you compare the h264parse output between RTSP and local file playback?
I compared the debug output of both pipelines and noticed that the h264parse element in the RTSP pipeline prints a lot of information about dropping data and not complete nal. The same kind of logs were not produced by the video file pipeline.
DEBUG              h264parse gsth264parse.c:186:gst_h264_parse_reset_frame:<h264parse0> reset frame
DEBUG              h264parse gsth264parse.c:1227:gst_h264_parse_handle_frame:<h264parse0> last parse position 0
DEBUG              h264parse gsth264parse.c:1247:gst_h264_parse_handle_frame:<h264parse0> Dropping filler data 1
DEBUG              h264parse gsth264parse.c:1405:gst_h264_parse_handle_frame:<h264parse0> Dropped data
LOG                h264parse gsth264parse.c:1212:gst_h264_parse_handle_frame:<h264parse0> parsing new frame
DEBUG              h264parse gsth264parse.c:1280:gst_h264_parse_handle_frame:<h264parse0> not a complete nal found at offset 3
DEBUG              h264parse gsth264parse.c:1286:gst_h264_parse_handle_frame:<h264parse0> draining, accepting with size 11937
DEBUG              h264parse gsth264parse.c:1333:gst_h264_parse_handle_frame:<h264parse0> complete nal found. Off: 3, Size: 11937
DEBUG              h264parse gsth264parse.c:833:gst_h264_parse_process_nal:<h264parse0> processing nal of type 1 Slice, size 11937
DEBUG              h264parse gsth264parse.c:942:gst_h264_parse_process_nal:<h264parse0> first_mb_in_slice = 0
DEBUG              h264parse gsth264parse.c:945:gst_h264_parse_process_nal:<h264parse0> frame start: 1
DEBUG              h264parse gsth264parse.c:953:gst_h264_parse_process_nal:<h264parse0> parse result 0, first MB: 0, slice type: 0
LOG                h264parse gsth264parse.c:1010:gst_h264_parse_process_nal:<h264parse0> collecting NAL in AVC frame
DEBUG              h264parse gsth264parse.c:431:gst_h264_parse_wrap_nal:<h264parse0> nal length 11937
I also searched for other problems with h264parse and after trial and error found out that by adding a second h264 parse to the pipeline I can get a normal video.
gst-launch-1.0 -e rtspsrc location=rtsp://URL:PORT ! rtph264depay ! h264parse ! video/x-h264, stream-format=byte-stream ! nvv4l2decoder ! nvvideoconvert ! capsfilter ! avenc_mpeg4 ! mpeg4videoparse ! qtmux ! filesink location=rtsp_1_h264parse.mp4
gst-launch-1.0 -e rtspsrc location=rtsp://URL:PORT ! rtph264depay ! h264parse ! video/x-h264, stream-format=avc ! h264parse ! video/x-h264, stream-format=byte-stream ! nvv4l2decoder ! nvvideoconvert ! capsfilter ! avenc_mpeg4 ! mpeg4videoparse ! qtmux ! filesink location=rtsp_2_h264parse.mp4
The first pipeline’s output rtsp_1_h264parse.mp4 contains only green frames but the second pipeline’s output rtsp_2_h264parse.mp4 is a normal video from the IP camera. The second pipeline solves my green frame problem but feels more like a workaround than a fix since the pipeline should not need two h264parse elements.
Sounds like it is RTSP and h264parse compatibility issue.
Sometimes I manage to solve this problem by forcing TCP for the rtspsrc. Try to replace rstp://… by rtspt://…
Hello kesong and motyaedu and sorry for my inactivity.
Lately I have noticed that the problem has disappeared from most of the cameras I use even though I did not change the pipeline. The fact that more cameras are working correctly without changes in the pipeline would suggest that the connection to the cameras might have been bad earlier. So, forcing TCP should also solve this issue as motyaedu suggests and I will try that out once I have the time. But since my pipeline is now mostly working and I also have a workaround this issue is now solved for me. I will post an update if I find out something new when I try out the TCP.
Thanks to both of you for the help.
Glad to know you resolve your issue.
