• Hardware Platform (Jetson Orin NX)
• DeepStream Version 7.0
• JetPack Version 6 36.3
I have been running deepstream for a while, but every few hours the source drops to 0 but it still prints the sensor name and id, it prints the following logs:
Here’s my config:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=4
square-seq-grid=1
[source-list]
num-source-bins=0
use-nvmultiurisrcbin=1
max-batch-size=4
http-ip=localhost
http-port=9010
sgie-batch-size=40
stream-name-display=1
[source-attr-all]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
latency=100
rtsp-reconnect-attempts=3
rtsp-reconnect-interval-sec=60
select-rtp-protocol=4
[streammux]
gpu-id=0
batch-size=4
batched-push-timeout=30000
width=960
height=544
enable-padding=0
nvbuf-memory-type=4
drop-pipeline-eos=1
live-source=1
attach-sys-ts-as-ntp=0
buffer-pool-size=4
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=4
[sink1]
enable=1
msg-broker-conn-str=localhost;6379;test
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_redis_proto.so
msg-conv-msg2p-new-api=0
msg-conv-frame-interval=1
msg-broker-config=/ds-config-files/yolov8s/cfg_redis.txt
msg-conv-payload-type=1
source-id=0
sync=0
type=6
topic=test
[sink2]
enable=0
type=3
container=1
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
[sink3]
enable=1
type=4
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8555
udp-port=5511
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=4
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=4
config-file=config_infer_primary_yoloV8_nx16.txt
model-engine-file=/yolov8s/model_b4_gpu0_int8.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
[tracker]
enable=1
tracker-width=960
tracker-height=544
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=config_tracker_NvDCF_PNv2.6_Interval_1_PVA.yml;config_tracker_NvDCF_PNv2.6_Interval_1_PVA.yml
sub-batches=2:2
gpu-id=0
display-tracking-id=1
### LPD model
[secondary-gie0]
enable=1
#model-engine-file=/yolov8s/model/LPDNet_usa_pruned_tao5.onnx_b40_gpu0_int8.engine
gpu-id=0
batch-size=4
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=2;3;5;7
#operate-on-class-ids=0;1;2;3;4;5;6;7;8;9;10;11;12;13;14;15;16;17;18;19
config-file=lpd_yolov4-tiny_us.txt
#config-file=test.txt
#classifier-async-mode=1
# LPR model
[secondary-gie1]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=5
operate-on-gie-id=4
config-file=lpr_config_sgie_us.txt
### VahicleMakeNet Model
[secondary-gie2]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=6
operate-on-gie-id=1
config-file=config_infer_secondary_vehicleMake.txt
# VahicleTypeNet Model
[secondary-gie3]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=7
operate-on-gie-id=1
#config-file=vehicle_typenet_config_sgie.txt
config-file=config_infer_secondary_vehicleType.txt
# VahicleColorNet Model
[secondary-gie4]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=8
operate-on-gie-id=1
config-file=config_infer_secondary_vehicleColor.txt
[tracker2]
enable=1
tracker-width=960
tracker-height=544
sub-batches=2:2
gpu-id=0
[tests]
file-loop=1
