After running deepstream for a period of time, the perf module stopped printing
• Hardware Platform (Jetson / GPU) Jetson AGX
• DeepStream Version 7.0
**• JetPack Version (valid for Jetson only) 6.0 GA
**• TensorRT Version 8.6
**• NVIDIA GPU Driver Version (valid for GPU only) 540.3.0
**• Issue Type( questions, new requirements, bugs) questions
This is the new topic from: Disconnecting after reaching the reconnection count, there is still information about this stream in printing - #25 by kesong
I have found a reproduction phenomenon,
Operation steps
  1. Wait for automatic deletion after adding the stream
  2. Add the stream again within 10 seconds after automatic deletion.
    And I saw this phenomenon in the log
    The screenshot below
    log20241101.zip (1.7 MB)
0:05:25.695709822 e[32m 19e[00m 0xfffec00060c0 e[33;01mWARN e[00m e[00m nvmultiurisrcbin gstdsnvmultiurisrcbin.cpp:1509:s_stream_api_impl:<src_nvmultiurisrcbin>e[00m Failed to add sensor id=[29]; Already added
Excuse me, could you please help confirm if there are any issues with the tracking section of the configuration file
Many Thanks
config.txt (5.6 KB)
The config.txt seems fine. Maybe the issue related with add/remove camera. Is it possible to write one script to send add/remove camera command to reproduce the issue?
I have a question to consult,
Log print
Added stream : sub-batch = 1 seq index = 0 pad index = 2
Is adding a video stream to the tracking module a successful indicator ?
what do sub-batch seq index and
pad index mean?
Because I found that the number of printed
Added streams
is greater than the actual number of added streams
The log come from: /opt/nvidia/deepstream/deepstream-7.0/sources/gst-plugins/gst-nvtracker/nvtracker_proc.cpp.
sub-batch is the index of sub-batch in nvtracker configure file. seq index means the number index in the sub-batch. pad index means the sink pad index of nvstreammux.
Is it a successful indicator about adding a video stream to the tracking module?
Yes, I suspect the issue is related with the sleep time between add/remove stream. Can you use one script to add/remove stream? So you can modify the sleep time to verify the issue.
Yes I try it
Found the steps for 100% reproduction
  1. Ensure that the maximum quantity in the track is 8
  2. Write a script that uses web APIs to add 7 streams
  3. Execute script
  4. Select a flow to delete
  5. Wait for a period of time to continue executing 3 and 4 (combined execution), and after executing 2-4 times, this phenomenon occurs
It has already appeared 2-3 times
Can you share the test script which can reproduce the issue.
test.txt (2.2 KB)
Excuting 3 will add 7 streams, but excuting 4 only remove one stream. How to ensure the max stream is 8?
Are you referring to mutiuri_strc-bin or tracker?
Repeat execution 3 (Repeatedly using this script afterwards)
Because the configfile is only configed with 8 streams
I suspect that when Deepstream deleted the stream, Track did not delete the video stream
Yes, not sure if you can reproduce the issue with below steps:
  1. add 8 streams
  2. remove one stream
  3. sleep 30 seconds
  4. add one stream
You can repeat 2-3-4 steps.
I tried three times yesterday and this phenomenon all appeared.
If it weren’t for the deepstreamtest5 issue, I don’t know if it was caused by code changes here
