Releasing streammux pad hangs gstreamer pipeline when adding and deleting rtsp source multiple times
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1.1
• TensorRT Version 8.2.2
• NVIDIA GPU Driver Version (valid for GPU only) 515.65.01
• Issue Type( questions, new requirements, bugs) bugs
Created pipeline based on deepstream_reference_apps/runtime_source_add_delete at master · NVIDIA-AI-IOT/deepstream_reference_apps · GitHub. Added around 10-11 rtsp sources and periodically doing add/remove cameras.
  • observed that after couple of add/remove cameras, DS pipeline got stuck in release pad for stream max
One more scenario is : Add invalid RTSP source along with other RTSP source hangs the streammux.
Below is code for remove source.
def stop(self):
    This method helps to stop camera source
    :return: None
    if self.source_bin:
        # Retrieve sink pad to be released,
        # https: // forums.developer.nvidia.com / t / deepstream - pipeline - hangs - on - gst - element - set - state - uridecodebin / 169009
        padname = "%s_%u" % ("sink", self.stream_index)
        sinkpad = Gstreamer.get_static_pad(self.streammux, padname)
        if sinkpad:
            Gstreamer.send_new_eos_event(sinkpad)
            #time.sleep(Stream.SLEEP_TIME_FOR_FLUSH)
            state_return = Gstreamer.set_state(self.source_bin, Gstreamer.null_state)
            if state_return in [
                Gstreamer.change_return_success,
                Gstreamer.change_return_async
                Gstreamer.send_flush_stop_event(sinkpad)
                Gstreamer.release_request_pad(self.streammux, sinkpad)
                # Remove the source bin from the pipeline
                Gstreamer.remove_element_from_pipeline(self.pipeline, self.source_bin)
                logger.info(f"source removed successfully : {self.stream_id}")
            elif state_return == Gstreamer.change_return_failure:
                logger.info(f"state change failure : {self.stream_id}")
Can you try the python sample deepstream_python_apps/apps/runtime_source_add_delete at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com)?
Thanks Fiona.
yes, I will try and update it. I have created application based on this deepstream_python_apps/apps/runtime_source_add_delete at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub example only. trying on this application requires some customisation as my application keep running all sources for long run and I I can delete few camera and add few more using UI interface.
is there way I can enable Nvidia elements logs to see where exactly it stuck. if I enabled logs with GST_DEBUG with level > 3 then it prints lots of log which make difficult for debugging.
I found another hang with nvtracker element. I have added probe sink and source pad on tracker and doing additional and removal of camera at regular interval. I can see sink pad logs are coming from tracker but not source pad.
I have observed it hangs entire pipeline. is there way to check where it can hang in nvtracker element.
How many cameras do you have? Have you set the maximum source number as the nvstreammux batch-size and set nvmultistreammux columns and rows correctly?
The GST_DEBUG can set element level log either, so you must know which element you want to track. https://gstreamer.freedesktop.org/documentation/tutorials/basic/debugging-tools.html?gi-language=c
The better way is to find out a simple app to reproduce the hang so that we can reproduce in our side.
Have added 8 cameras and doing addition and deletion of camera one by one , making sure 4 cameras remain active into pipeline.
yes, maximum source number into nvstreammux batch-size set to 32. not using nvmultistreammux. below is pipeline.
streammux → nvinferserver (PGIE) → queue → tracker → queue → nvinferserver (SGIE) → queue → nvmsgconv → nvmsgbroker
We are using triton-server over grpc.
Let me customise deepstream_python_apps/apps/runtime_source_add_delete at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub this and share with steps to reproduce this issue.
Hello Fiona,
I have updated deepstream-test3 app with runtime add/delete source and testing with nvinferserver configuration to reproduce above issue and application work fine until I delete one of source randomly and perf reports 0 fps for all sources. Looks like all source bin went to pause state.
Below are logs for same and also attached deepstream-test3.tar.gz (deepstream app with config). peoplenet model I could not upload as size is >100MB. I created peoplenet model engine file with batch size 32. I have used peoplenet model suggested in README file in deepstream-test3.
root@ai_service:/app#
root@ai_service:/app# cd /opt/nvidia/deepstream/deepstream/
LICENSE.txt README entrypoint.sh samples/ user_additional_install.sh
LicenseAgreement.pdf README.rhel install.sh sources/ version
LicenseAgreementContainer.pdf bin/ lib/ uninstall.sh
root@ai_service:/app# cd /opt/nvidia/deepstream/deepstream/sources/
SONYCAudioClassifier/ apps/ gst-plugins/ libs/ objectDetector_SSD/ tools/
TritonOnnxYolo/ deepstream_python_apps/ includes/ objectDetector_FasterRCNN/ objectDetector_Yolo/ tracker_DeepSORT/
root@ai_service:/app# cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/
.git/ .python-app-pipeline.png 3rdparty/ HOWTO.md README.md apps/ docs/ tests/
.gitmodules .test3-app.png FAQ.md LICENSE THIRD_PARTY_LICENSE bindings/ notebooks/
root@ai_service:/app# cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/
README deepstream-nvdsanalytics/ deepstream-ssd-parser/ deepstream-test3/
common/ deepstream-opticalflow/ deepstream-test1/ deepstream-test3.tar.gz
deepstream-demux-multi-in-multi-out/ deepstream-preprocess-test/ deepstream-test1-rtsp-out/ deepstream-test4/
deepstream-imagedata-multistream/ deepstream-rtsp-in-rtsp-out/ deepstream-test1-usbcam/ runtime_source_add_delete/
deepstream-imagedata-multistream-redaction/ deepstream-segmentation/ deepstream-test2/
root@ai_service:/app# cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test3
root@ai_service:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test3# ls
README config_infer_primary_peoplenet.txt config_triton_grpc_infer_primary_peoplenet.txt deepstream_test_3.py dstest_tracker_config.txt
config.pbtxt config_tracker_NvDCF_perf.yml config_triton_infer_primary_peoplenet.txt dstest3_pgie_config.txt tracker_config.yml
root@ai_service:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test3# python3 deepstream_test_3.py -i rtsp://20.166.69.85:8554/live/stream1 rtsp://20.166.69.85:8554/live/stream2 rtsp://20.166.69.85:8554/live/stream3 rtsp://20.166.69.85:8554/live/stream4 rtsp://20.166.69.85:8554/live/stream5 rtsp://20.166.69.85:8554/live/stream6 rtsp://20.166.69.85:8554/live/stream7 rtsp://20.166.69.85:8554/live/stream8 rtsp://20.166.69.85:8554/live/stream9 rtsp://20.166.69.85:8554/live/stream10 --pgie nvinferserver -c config_triton_infer_primary_peoplenet.txt --no-display
{‘input’: [‘rtsp://20.166.69.85:8554/live/stream1’, ‘rtsp://20.166.69.85:8554/live/stream2’, ‘rtsp://20.166.69.85:8554/live/stream3’, ‘rtsp://20.166.69.85:8554/live/stream4’, ‘rtsp://20.166.69.85:8554/live/stream5’, ‘rtsp://20.166.69.85:8554/live/stream6’, ‘rtsp://20.166.69.85:8554/live/stream7’, ‘rtsp://20.166.69.85:8554/live/stream8’, ‘rtsp://20.166.69.85:8554/live/stream9’, ‘rtsp://20.166.69.85:8554/live/stream10’], ‘configfile’: ‘config_triton_infer_primary_peoplenet.txt’, ‘pgie’: ‘nvinferserver’, ‘no_display’: True, ‘file_loop’: False, ‘disable_probe’: False, ‘silent’: False}
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream1]
source-bin-00
Creating source_bin 1
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream2]
source-bin-01
Creating source_bin 2
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream3]
source-bin-02
Creating source_bin 3
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream4]
source-bin-03
Creating source_bin 4
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream5]
source-bin-04
Creating source_bin 5
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream6]
source-bin-05
Creating source_bin 6
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream7]
source-bin-06
Creating source_bin 7
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream8]
source-bin-07
Creating source_bin 8
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream9]
source-bin-08
Creating source_bin 9
Creating uridecodebin for [rtsp://20.166.69.85:8554/live/stream10]
source-bin-09
Creating Pgie
Creating nvtracker
Creating tiler
Creating nvvidconv
Creating nvosd
Creating Fakesink
At least one of the sources is live
WARNING: Overriding infer-config batch-size 0 with number of sources 10
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing…
0 : rtsp://20.166.69.85:8554/live/stream1
1 : rtsp://20.166.69.85:8554/live/stream2
2 : rtsp://20.166.69.85:8554/live/stream3
3 : rtsp://20.166.69.85:8554/live/stream4
4 : rtsp://20.166.69.85:8554/live/stream5
5 : rtsp://20.166.69.85:8554/live/stream6
6 : rtsp://20.166.69.85:8554/live/stream7
7 : rtsp://20.166.69.85:8554/live/stream8
8 : rtsp://20.166.69.85:8554/live/stream9
9 : rtsp://20.166.69.85:8554/live/stream10
Starting pipeline
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvMultiObjectTracker] Initialized
0:00:01.932453910 3360 0x29b5d60 WARN nvinferserver gstnvinferserver_impl.cpp:315:validatePluginConfig: warning: Configuration file batch-size reset to: 10
WARNING: infer_proto_utils.cpp:144 auto-update preprocess.network_format to IMAGE_FORMAT_RGB
INFO: infer_trtis_backend.cpp:206 TrtISBackend id:1 initialized model: peoplenet
Decodebin child added: source
Warning: gst-library-error-quark: Configuration file batch-size reset to: 10 (5): gstnvinferserver_impl.cpp(315): validatePluginConfig (): /GstPipeline:pipeline0/GstNvInferServer:primary-inference
Decodebin child added: decodebin0
Decodebin child added: decodebin1
Decodebin child added: decodebin2
Decodebin child added: rtph264depay1
Decodebin child added: rtph264depay2
Decodebin child added: rtph264depay0
Decodebin child added: decodebin3
Decodebin child added: h264parse0
Decodebin child added: h264parse1
Decodebin child added: capsfilter0
Decodebin child added: rtph264depay3
Decodebin child added: h264parse2
Decodebin child added: capsfilter1
Decodebin child added: h264parse3
Decodebin child added: capsfilter2
Decodebin child added: capsfilter3
Decodebin child added: nvv4l2decoder0
Decodebin child added: nvv4l2decoder2
Decodebin child added: nvv4l2decoder1
Decodebin child added: nvv4l2decoder3
Decodebin child added: decodebin4
Decodebin child added: rtph264depay4
Decodebin child added: decodebin5
Decodebin child added: h264parse4
Decodebin child added: decodebin6
Decodebin child added: decodebin7
Decodebin child added: rtph264depay5
Decodebin child added: rtph264depay6
Decodebin child added: capsfilter4
Decodebin child added: decodebin8
Decodebin child added: decodebin9
Decodebin child added: h264parse5
Decodebin child added: h264parse6
Decodebin child added: nvv4l2decoder4
Decodebin child added: rtph264depay7
Decodebin child added: rtph264depay8
Decodebin child added: h264parse7
Decodebin child added: capsfilter5
Decodebin child added: nvv4l2decoder5
Decodebin child added: rtph264depay9
Decodebin child added: h264parse8
Decodebin child added: capsfilter6
Decodebin child added: nvv4l2decoder6
Decodebin child added: capsfilter7
Decodebin child added: h264parse9
Decodebin child added: capsfilter8
Decodebin child added: capsfilter9
Decodebin child added: nvv4l2decoder7
Decodebin child added: nvv4l2decoder8
Decodebin child added: nvv4l2decoder9
In cb_newpad
gstname= video/x-raw
sink_6
Decodebin linked to pipeline
In cb_newpad
sink_0
In cb_newpad
sink_5
In cb_newpad
sink_4
In cb_newpad
sink_8
In cb_newpad
sink_3
In cb_newpad
sink_9
In cb_newpad
sink_1
In cb_newpad
sink_7
In cb_newpad
sink_2
**PERF: {‘stream0’: 0.0, ‘stream1’: 0.0, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 0.0, ‘stream7’: 0.0, ‘stream8’: 0.0, ‘stream9’: 0.0}
**PERF: {‘stream0’: 10.85, ‘stream1’: 10.85, ‘stream2’: 10.85, ‘stream3’: 10.85, ‘stream4’: 10.85, ‘stream5’: 10.85, ‘stream6’: 10.85, ‘stream7’: 10.85, ‘stream8’: 10.85, ‘stream9’: 10.85}
**PERF: {‘stream0’: 13.6, ‘stream1’: 13.6, ‘stream2’: 13.6, ‘stream3’: 13.6, ‘stream4’: 13.6, ‘stream5’: 13.6, ‘stream6’: 13.6, ‘stream7’: 13.6, ‘stream8’: 13.6, ‘stream9’: 13.6}
**PERF: {‘stream0’: 9.4, ‘stream1’: 9.4, ‘stream2’: 9.4, ‘stream3’: 9.4, ‘stream4’: 9.4, ‘stream5’: 9.4, ‘stream6’: 9.4, ‘stream7’: 9.4, ‘stream8’: 9.4, ‘stream9’: 9.4}
**PERF: {‘stream0’: 14.2, ‘stream1’: 14.2, ‘stream2’: 14.2, ‘stream3’: 14.2, ‘stream4’: 14.2, ‘stream5’: 14.2, ‘stream6’: 14.2, ‘stream7’: 14.2, ‘stream8’: 14.2, ‘stream9’: 14.2}
**PERF: {‘stream0’: 14.0, ‘stream1’: 14.0, ‘stream2’: 14.0, ‘stream3’: 14.0, ‘stream4’: 14.0, ‘stream5’: 14.0, ‘stream6’: 14.0, ‘stream7’: 14.0, ‘stream8’: 14.0, ‘stream9’: 14.0}
**PERF: {‘stream0’: 11.4, ‘stream1’: 11.4, ‘stream2’: 11.4, ‘stream3’: 11.4, ‘stream4’: 11.4, ‘stream5’: 11.4, ‘stream6’: 11.4, ‘stream7’: 11.4, ‘stream8’: 11.4, ‘stream9’: 11.4}
**PERF: {‘stream0’: 11.2, ‘stream1’: 11.2, ‘stream2’: 11.2, ‘stream3’: 11.2, ‘stream4’: 11.2, ‘stream5’: 11.2, ‘stream6’: 11.2, ‘stream7’: 11.2, ‘stream8’: 11.2, ‘stream9’: 11.2}
**PERF: {‘stream0’: 9.8, ‘stream1’: 9.8, ‘stream2’: 9.8, ‘stream3’: 9.8, ‘stream4’: 9.8, ‘stream5’: 9.8, ‘stream6’: 9.8, ‘stream7’: 9.8, ‘stream8’: 9.8, ‘stream9’: 9.8}
**PERF: {‘stream0’: 15.4, ‘stream1’: 15.4, ‘stream2’: 15.4, ‘stream3’: 15.4, ‘stream4’: 15.4, ‘stream5’: 15.4, ‘stream6’: 15.4, ‘stream7’: 15.4, ‘stream8’: 15.4, ‘stream9’: 15.4}
**PERF: {‘stream0’: 11.6, ‘stream1’: 11.6, ‘stream2’: 11.6, ‘stream3’: 11.6, ‘stream4’: 11.6, ‘stream5’: 11.6, ‘stream6’: 11.6, ‘stream7’: 11.6, ‘stream8’: 11.6, ‘stream9’: 11.6}
Calling Stop 1
STATE CHANGE SUCCESS
sink_1
**PERF: {‘stream0’: 3.6, ‘stream1’: 3.6, ‘stream2’: 3.6, ‘stream3’: 3.6, ‘stream4’: 3.6, ‘stream5’: 3.6, ‘stream6’: 3.6, ‘stream7’: 3.6, ‘stream8’: 3.6, ‘stream9’: 3.6}
**PERF: {‘stream0’: 0.4, ‘stream1’: 0.2, ‘stream2’: 0.4, ‘stream3’: 0.4, ‘stream4’: 0.4, ‘stream5’: 0.4, ‘stream6’: 0.4, ‘stream7’: 0.4, ‘stream8’: 0.4, ‘stream9’: 0.2}
deepstream-test3.tar.gz (14.8 KB)
Hi Fiona,
It looks like when we set batch-push-timeout property of nvstreammux to a high value like here 4000000, nvstreammux causes the pipeline to stop when there is a change on the sinkpads. I believe it is probably that it has data from the stream in nvstreammux and it cannot handle it nicely while it no longer has the pad. We get lucky when we set batch-push-timeout to small value as nvstreammux has more chances to flush its buffers.
I believe nvstreammux cannot handle dynamic changes well here as seen on the example app. Could you please investigate this issue on the nvstreammux element?
Sending EOS event before unlinking, or starting flush before unlinking, or setting source element’s state to NULL doesn’t help. When nvstreammux gets these events it again halts the pipeline.
Can you upgrade to DeepStream 6.2? I have verified with DeepStream 6.2 with your modified app, it works.
Sure @Fiona.Chen , Let me try with DS 6.2, Do you think streammux has fixes around issue being reported in DS 6.2?
There are some bug fix patches with nvstreammux, maybe it is related to this issue.
Thank you @Fiona.Chen , Let me try it and update you.
Hello @Fiona.Chen ,
I have tried DS 6.2 and I can still see pipeline gets stuck randomly with number of sources. with DS 6.2, it stucks without dynamic addition/deletion of sources.
Attached are logs with GST_DEBUG=4 along with custom test app. I could regenerate same issue with /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test3/deepstream_test_3.py without any modification.
used below commands to test.
python3 deepstream_test_3.py -i rtsp://74.234.85.155:8554/live/stream1 rtsp://74.234.85.155:8554/live/stream2 rtsp://74.234.85.155:8554/live/stream3 rtsp://74.234.85.155:8554/live/stream4 rtsp://74.234.85.155:8554/live/stream5 rtsp://74.234.85.155:8554/live/stream6 rtsp://74.234.85.155:8554/live/stream7 rtsp://74.234.85.155:8554/live/stream8 rtsp://74.234.85.155:8554/live/stream9 rtsp://74.234.85.155:8554/live/stream10 -c config_infer_primary_peoplenet.txt -g nvinfer --no-display -s
ds6.2.log (1.2 MB)
deepstream_test_3.py (26.2 KB)
Hi @Fiona.Chen ,
I can reproduce this issue with DS 6.2 with lower timeout value also. it always stuck with 10 rtsp sources. I did not try lesser.
I can not reproduce with your app and 10 rtsp streams. Can you tell us which GPU you are using? Have you installed the DeepStream 6.2 as described in Quickstart Guide — DeepStream 6.2 Release documentation?
Hi Fiona,
I am using T4 GPU and I am using nvcr.io/nvidia/deepstream:6.2-triton container image and downloaded peoplenet model based on instruction given in README.
I have followed instruction given in Quickstart Guide — DeepStream 6.2 Release documentation. Nothing much done.
  1. Installed driver and build tool dependencies as describe in Quick Start guide.
  2. Installed docker, Nvidia-container tool kit and pulled docker image
Thanks,
Dilip Patel
Have you run “user_additional_install.sh” and “user_deepstream_python_apps_install.sh” in /opt/nvidia/deepstream/deepstream-6.2 to setup the pyds? Can the original python deepstream-test3 work in your docker? deepstream_python_apps/apps/deepstream-test3 at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
I have used ./user_deepstream_python_apps_install.sh --version 1.1.6 to setup pyds and deepstream.
I am seeing same issue with original python deepstream-test3 app in my container with 10 RTSP sources.
Hi @Fiona.Chen ,
I did setup my container again and tested with original python deepstream-test3 and it seems working now.
Do not know what has messed up yesteday’s test, let me test with my custom app also and verify.
Thanks for prompt response.
