Hi @Fiona.Chen ,
It stopped working after 2-3 attempts. It stuck after some interval.
I’ve run your app for 1 hour, it is still working with my 10 rtsp sources.
Can you enable the rtspsrc log only to check whether there is anything wrong? export GST_DEBUG=rtspsrc:7
Please find attached logs with GST_DEBUG=rtspsrc:7.
You can see after line number 4444, no logs for PERF.
deepstream-test3-ds6.2-rtsplog.txt (1.6 MB)
Seems the rtsp sources are fine. There is no clue until now. Can you try to add some probe functions in the pipeline to check where the frames are bloacked?
Some ip cameras have limitations of the connected clients number, can you check whether your ip camera has such limitation?
Hi Fiona,
One weird observation with custom app, I shared.
If I add GLib.timeout_add_seconds(60, delete_sources, g_source_bin_list) to set timer to delete few source after 60 seconds, to regenerate streammux hang on delete camera with larger batch size, pipeline halts with my custom app exactly after 60 seconds.
If I comment that line and keep custom app identical to original app, it works.
I am investigating what is happened when timer is initiated. Do you any recommendation for dynamic addition/deletion of cameras to use timer or not?
Hi Fiona,
I have found some issue with custom application and after fixing those, I can see delete source happen successfully and I could regenerate original issue which is reported with DS 6.1.1 with higher stream-max batch-size.
With stream-max batch-timeout 4000000
root@EICStreamingTesting:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test3# python3 deepstream_test_3.py -i rtsp://74.234.85.155:8554/live/stream1 rtsp://74.234.85.155:8554/live/stream2 rtsp://74.234.85.155:8554/live/stream3 rtsp://74.234.85.155:8554/live/stream4 rtsp://74.234.85.155:8554/live/stream5 rtsp://74.234.85.155:8554/live/stream6 rtsp://74.234.85.155:8554/live/stream7 rtsp://74.234.85.155:8554/live/stream8 rtsp://74.234.85.155:8554/live/stream9 rtsp://74.234.85.155:8554/live/stream10 -c config_infer_primary_peoplenet.txt -g nvinfer --no-display -s
{‘input’: [‘rtsp://74.234.85.155:8554/live/stream1’, ‘rtsp://74.234.85.155:8554/live/stream2’, ‘rtsp://74.234.85.155:8554/live/stream3’, ‘rtsp://74.234.85.155:8554/live/stream4’, ‘rtsp://74.234.85.155:8554/live/stream5’, ‘rtsp://74.234.85.155:8554/live/stream6’, ‘rtsp://74.234.85.155:8554/live/stream7’, ‘rtsp://74.234.85.155:8554/live/stream8’, ‘rtsp://74.234.85.155:8554/live/stream9’, ‘rtsp://74.234.85.155:8554/live/stream10’], ‘configfile’: ‘config_infer_primary_peoplenet.txt’, ‘pgie’: ‘nvinfer’, ‘no_display’: True, ‘file_loop’: False, ‘disable_probe’: False, ‘silent’: True}
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating source_bin 1
Creating source bin
source-bin-01
Creating source_bin 2
Creating source bin
source-bin-02
Creating source_bin 3
Creating source bin
source-bin-03
Creating source_bin 4
Creating source bin
source-bin-04
Creating source_bin 5
Creating source bin
source-bin-05
Creating source_bin 6
Creating source bin
source-bin-06
Creating source_bin 7
Creating source bin
source-bin-07
Creating source_bin 8
Creating source bin
source-bin-08
Creating source_bin 9
Creating source bin
source-bin-09
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating Fakesink
At least one of the sources is live
Warning: ‘input-dims’ parameter has been deprecated. Use ‘infer-dims’ instead.
WARNING: Overriding infer-config batch-size 32 with number of sources 10
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing…
0 : rtsp://74.234.85.155:8554/live/stream1
1 : rtsp://74.234.85.155:8554/live/stream2
2 : rtsp://74.234.85.155:8554/live/stream3
3 : rtsp://74.234.85.155:8554/live/stream4
4 : rtsp://74.234.85.155:8554/live/stream5
5 : rtsp://74.234.85.155:8554/live/stream6
6 : rtsp://74.234.85.155:8554/live/stream7
7 : rtsp://74.234.85.155:8554/live/stream8
8 : rtsp://74.234.85.155:8554/live/stream9
9 : rtsp://74.234.85.155:8554/live/stream10
Starting pipeline
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING
in CUDA C++ Programming Guide
0:00:05.290610431 4466 0x7faab8002330 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/samples/models/tao_pretrained_models/peopleNet/V2.6/resnet34_peoplenet_int8.etlt_b10_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 12x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 3x34x60
0:00:05.338383629 4466 0x7faab8002330 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/samples/models/tao_pretrained_models/peopleNet/V2.6/resnet34_peoplenet_int8.etlt_b10_gpu0_int8.engine
0:00:05.343453911 4466 0x7faab8002330 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:config_infer_primary_peoplenet.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Decodebin child added: decodebin3
Decodebin child added: decodebin1
Decodebin child added: decodebin4
Decodebin child added: decodebin2
Decodebin child added: rtph264depay0
Decodebin child added: rtph264depay3
Decodebin child added: rtph264depay2
Decodebin child added: rtph264depay1
Decodebin child added: h264parse0
Decodebin child added: h264parse1
Decodebin child added: h264parse2
Decodebin child added: rtph264depay4
Decodebin child added: capsfilter1
Decodebin child added: capsfilter0
Decodebin child added: capsfilter2
Decodebin child added: h264parse3
Decodebin child added: capsfilter3
Decodebin child added: h264parse4
Decodebin child added: capsfilter4
Decodebin child added: nvv4l2decoder0
Decodebin child added: decodebin5
Decodebin child added: decodebin6
Decodebin child added: decodebin7
Decodebin child added: rtph264depay5
Decodebin child added: decodebin8
Decodebin child added: rtph264depay6
Decodebin child added: h264parse5
Decodebin child added: h264parse6
Decodebin child added: capsfilter5
Decodebin child added: capsfilter6
Decodebin child added: rtph264depay7
Decodebin child added: h264parse7
Decodebin child added: capsfilter7
Decodebin child added: rtph264depay8
Decodebin child added: h264parse8
Decodebin child added: capsfilter8
Decodebin child added: nvv4l2decoder1
Decodebin child added: nvv4l2decoder2
Decodebin child added: nvv4l2decoder3
Decodebin child added: nvv4l2decoder4
Decodebin child added: decodebin9
Decodebin child added: rtph264depay9
Decodebin child added: h264parse9
Decodebin child added: capsfilter9
Decodebin child added: nvv4l2decoder5
Decodebin child added: nvv4l2decoder6
Decodebin child added: nvv4l2decoder7
Decodebin child added: nvv4l2decoder8
Decodebin child added: nvv4l2decoder9
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7fab43f5e400 (GstCapsFeatures at 0x7faa300b5100)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fab43f5e340 (GstCapsFeatures at 0x7faa4c08e6a0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fab43f5e400 (GstCapsFeatures at 0x7faa4c08dea0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fab43f5e340 (GstCapsFeatures at 0x7faa200a5aa0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fab43f5e400 (GstCapsFeatures at 0x7faa5c0af820)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fab43f5e340 (GstCapsFeatures at 0x7faa64093500)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fab43f5e400 (GstCapsFeatures at 0x7faa2803dc00)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fab43f5e340 (GstCapsFeatures at 0x7faa5809a040)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fab43f5e400 (GstCapsFeatures at 0x1fd270c0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fab43f5e340 (GstCapsFeatures at 0x26f028a0)>
**PERF: {‘stream0’: 0.0, ‘stream1’: 0.0, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 0.0, ‘stream7’: 0.0, ‘stream8’: 0.0, ‘stream9’: 0.0}
**PERF: {‘stream0’: 12.06, ‘stream1’: 12.06, ‘stream2’: 12.06, ‘stream3’: 12.06, ‘stream4’: 12.06, ‘stream5’: 12.06, ‘stream6’: 12.06, ‘stream7’: 12.06, ‘stream8’: 12.06, ‘stream9’: 12.06}
**PERF: {‘stream0’: 12.0, ‘stream1’: 12.0, ‘stream2’: 12.0, ‘stream3’: 12.0, ‘stream4’: 12.0, ‘stream5’: 12.0, ‘stream6’: 12.0, ‘stream7’: 12.0, ‘stream8’: 12.0, ‘stream9’: 12.0}
**PERF: {‘stream0’: 11.8, ‘stream1’: 11.8, ‘stream2’: 11.8, ‘stream3’: 11.8, ‘stream4’: 11.8, ‘stream5’: 11.8, ‘stream6’: 11.8, ‘stream7’: 11.8, ‘stream8’: 11.8, ‘stream9’: 11.8}
**PERF: {‘stream0’: 12.19, ‘stream1’: 12.19, ‘stream2’: 12.19, ‘stream3’: 12.19, ‘stream4’: 12.19, ‘stream5’: 12.19, ‘stream6’: 12.19, ‘stream7’: 12.19, ‘stream8’: 12.19, ‘stream9’: 12.19}
**PERF: {‘stream0’: 11.99, ‘stream1’: 11.99, ‘stream2’: 11.99, ‘stream3’: 11.99, ‘stream4’: 11.99, ‘stream5’: 11.99, ‘stream6’: 11.99, ‘stream7’: 11.99, ‘stream8’: 11.99, ‘stream9’: 11.99}
**PERF: {‘stream0’: 9.6, ‘stream1’: 9.6, ‘stream2’: 9.6, ‘stream3’: 9.6, ‘stream4’: 9.6, ‘stream5’: 9.6, ‘stream6’: 9.6, ‘stream7’: 9.6, ‘stream8’: 9.6, ‘stream9’: 9.6}
**PERF: {‘stream0’: 14.2, ‘stream1’: 14.2, ‘stream2’: 14.2, ‘stream3’: 14.2, ‘stream4’: 14.2, ‘stream5’: 14.2, ‘stream6’: 14.2, ‘stream7’: 14.2, ‘stream8’: 14.2, ‘stream9’: 14.2}
Delete camera
Killed
Creating Pipeline
Creating streamux
Creating source bin
source-bin-00
Creating source bin
source-bin-01
Creating source bin
source-bin-02
Creating source bin
source-bin-03
Creating source bin
source-bin-04
Creating source bin
source-bin-05
Creating source bin
source-bin-06
Creating source bin
source-bin-07
Creating source bin
source-bin-08
Creating source bin
source-bin-09
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating Fakesink
Now playing…
Starting pipeline
0:00:05.274539931 4585 0x7f1738002330 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/samples/models/tao_pretrained_models/peopleNet/V2.6/resnet34_peoplenet_int8.etlt_b10_gpu0_int8.engine
0:00:05.324425198 4585 0x7f1738002330 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/samples/models/tao_pretrained_models/peopleNet/V2.6/resnet34_peoplenet_int8.etlt_b10_gpu0_int8.engine
0:00:05.329316957 4585 0x7f1738002330 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:config_infer_primary_peoplenet.txt sucessfully
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f580 (GstCapsFeatures at 0x7f16b40339a0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f460 (GstCapsFeatures at 0x7f16ac02c020)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f580 (GstCapsFeatures at 0x7f16a8071a00)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f460 (GstCapsFeatures at 0x7f16dc087200)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f580 (GstCapsFeatures at 0x7f1690091960)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f460 (GstCapsFeatures at 0x7f16e03af200)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f580 (GstCapsFeatures at 0x7f169c080e80)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f460 (GstCapsFeatures at 0x7f1690091340)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f580 (GstCapsFeatures at 0x7f16b408e8c0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f17c4c0f460 (GstCapsFeatures at 0x7f16e40378e0)>
**PERF: {‘stream0’: 11.95, ‘stream1’: 11.95, ‘stream2’: 11.95, ‘stream3’: 11.95, ‘stream4’: 11.95, ‘stream5’: 11.95, ‘stream6’: 11.95, ‘stream7’: 11.95, ‘stream8’: 11.95, ‘stream9’: 11.93}
**PERF: {‘stream0’: 12.2, ‘stream1’: 12.2, ‘stream2’: 12.2, ‘stream3’: 12.2, ‘stream4’: 12.2, ‘stream5’: 12.2, ‘stream6’: 12.2, ‘stream7’: 12.2, ‘stream8’: 12.2, ‘stream9’: 12.2}
Delete camera
1
2
Calling Stop 8
exception
^CExiting app
Creating Pipeline
Creating streamux
Creating source bin
source-bin-00
Creating source bin
source-bin-01
Creating source bin
source-bin-02
Creating source bin
source-bin-03
Creating source bin
source-bin-04
Creating source bin
source-bin-05
Creating source bin
source-bin-06
Creating source bin
source-bin-07
Creating source bin
source-bin-08
Creating source bin
source-bin-09
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating Fakesink
Now playing…
Starting pipeline
0:00:05.292361795 4703 0x7fedb0002330 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/samples/models/tao_pretrained_models/peopleNet/V2.6/resnet34_peoplenet_int8.etlt_b10_gpu0_int8.engine
0:00:05.340010247 4703 0x7fedb0002330 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/samples/models/tao_pretrained_models/peopleNet/V2.6/resnet34_peoplenet_int8.etlt_b10_gpu0_int8.engine
0:00:05.345038406 4703 0x7fedb0002330 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:config_infer_primary_peoplenet.txt sucessfully
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fee3e16d3a0 (GstCapsFeatures at 0x7fed2c07ae40)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fee3e16d340 (GstCapsFeatures at 0x7fed500dbb60)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fee3e16d3a0 (GstCapsFeatures at 0x7fee280ac860)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fee3e16d340 (GstCapsFeatures at 0x7fee280ac100)>
In cb_newpad
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fee3e16d3a0 (GstCapsFeatures at 0x7fed2408c180)>
features= <Gst.CapsFeatures object at 0x7fee3e16d4c0 (GstCapsFeatures at 0x7fed500dae40)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fee3e16d340 (GstCapsFeatures at 0x7fed280af8e0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fee3e16d3a0 (GstCapsFeatures at 0x7fed20046680)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fee3e16d340 (GstCapsFeatures at 0x7fed4000a060)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fee3e16d3a0 (GstCapsFeatures at 0x7fed3408fb80)>
**PERF: {‘stream0’: 12.12, ‘stream1’: 12.12, ‘stream2’: 12.12, ‘stream3’: 12.12, ‘stream4’: 12.12, ‘stream5’: 12.12, ‘stream6’: 12.12, ‘stream7’: 12.12, ‘stream8’: 12.12, ‘stream9’: 12.12}
Calling Stop 7
STATE CHANGE SUCCESS
sink_7
**PERF: {‘stream0’: 7.8, ‘stream1’: 7.8, ‘stream2’: 7.8, ‘stream3’: 7.8, ‘stream4’: 7.8, ‘stream5’: 7.8, ‘stream6’: 7.8, ‘stream7’: 7.8, ‘stream8’: 7.8, ‘stream9’: 7.8}
**PERF: {‘stream0’: 0.2, ‘stream1’: 0.2, ‘stream2’: 0.2, ‘stream3’: 0.2, ‘stream4’: 0.2, ‘stream5’: 0.2, ‘stream6’: 0.2, ‘stream7’: 0.0, ‘stream8’: 0.2, ‘stream9’: 0.2}
**PERF: {‘stream0’: 0.4, ‘stream1’: 0.4, ‘stream2’: 0.4, ‘stream3’: 0.4, ‘stream4’: 0.4, ‘stream5’: 0.4, ‘stream6’: 0.4, ‘stream7’: 0.0, ‘stream8’: 0.4, ‘stream9’: 0.4}
^CExiting app
With Stream-mux batch-size : 33000
Creating Pipeline
Creating streamux
Creating source bin
source-bin-00
Creating source bin
source-bin-01
Creating source bin
source-bin-02
Creating source bin
source-bin-03
Creating source bin
source-bin-04
Creating source bin
source-bin-05
Creating source bin
source-bin-06
Creating source bin
source-bin-07
Creating source bin
source-bin-08
Creating source bin
source-bin-09
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating Fakesink
Now playing…
Starting pipeline
0:00:05.295024002 4821 0x7faf74002330 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/samples/models/tao_pretrained_models/peopleNet/V2.6/resnet34_peoplenet_int8.etlt_b10_gpu0_int8.engine
0:00:05.343152792 4821 0x7faf74002330 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/samples/models/tao_pretrained_models/peopleNet/V2.6/resnet34_peoplenet_int8.etlt_b10_gpu0_int8.engine
0:00:05.348139750 4821 0x7faf74002330 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:config_infer_primary_peoplenet.txt sucessfully
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac400 (GstCapsFeatures at 0x7faed408e060)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac340 (GstCapsFeatures at 0x7faedc060260)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac400 (GstCapsFeatures at 0x7faf00093ac0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac340 (GstCapsFeatures at 0x7faefc0ac720)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac400 (GstCapsFeatures at 0x7faf000932a0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac340 (GstCapsFeatures at 0x7faefc0a6420)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac520 (GstCapsFeatures at 0x7faf0408cac0)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac4c0 (GstCapsFeatures at 0x7faf1c38f580)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac520 (GstCapsFeatures at 0x7faef808ea60)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7fafffcac4c0 (GstCapsFeatures at 0x7faf1408d4c0)>
**PERF: {‘stream0’: 12.06, ‘stream1’: 12.06, ‘stream2’: 12.06, ‘stream3’: 12.06, ‘stream4’: 12.07, ‘stream5’: 12.06, ‘stream6’: 12.06, ‘stream7’: 12.06, ‘stream8’: 12.06, ‘stream9’: 12.07}
Calling Stop 2
sink_2
**PERF: {‘stream0’: 12.0, ‘stream1’: 12.0, ‘stream2’: 7.4, ‘stream3’: 12.0, ‘stream4’: 12.0, ‘stream5’: 12.0, ‘stream6’: 12.0, ‘stream7’: 12.0, ‘stream8’: 12.0, ‘stream9’: 12.0}
**PERF: {‘stream0’: 12.0, ‘stream1’: 12.0, ‘stream2’: 0.0, ‘stream3’: 12.0, ‘stream4’: 12.0, ‘stream5’: 12.0, ‘stream6’: 12.0, ‘stream7’: 12.0, ‘stream8’: 12.0, ‘stream9’: 12.0}
**PERF: {‘stream0’: 11.99, ‘stream1’: 11.99, ‘stream2’: 0.0, ‘stream3’: 11.99, ‘stream4’: 11.99, ‘stream5’: 11.99, ‘stream6’: 11.99, ‘stream7’: 11.99, ‘stream8’: 11.99, ‘stream9’: 11.99}
**PERF: {‘stream0’: 12.19, ‘stream1’: 12.19, ‘stream2’: 0.0, ‘stream3’: 12.19, ‘stream4’: 12.19, ‘stream5’: 12.19, ‘stream6’: 12.19, ‘stream7’: 12.19, ‘stream8’: 12.19, ‘stream9’: 12.19}
**PERF: {‘stream0’: 11.8, ‘stream1’: 11.8, ‘stream2’: 0.0, ‘stream3’: 11.8, ‘stream4’: 11.8, ‘stream5’: 11.8, ‘stream6’: 11.8, ‘stream7’: 11.8, ‘stream8’: 11.8, ‘stream9’: 11.8}
Calling Stop 0
sink_0
**PERF: {‘stream0’: 7.2, ‘stream1’: 12.0, ‘stream2’: 0.0, ‘stream3’: 12.0, ‘stream4’: 12.0, ‘stream5’: 12.0, ‘stream6’: 11.8, ‘stream7’: 12.0, ‘stream8’: 12.0, ‘stream9’: 12.0}
**PERF: {‘stream0’: 0.0, ‘stream1’: 12.0, ‘stream2’: 0.0, ‘stream3’: 12.0, ‘stream4’: 12.0, ‘stream5’: 12.0, ‘stream6’: 12.2, ‘stream7’: 12.0, ‘stream8’: 12.0, ‘stream9’: 12.0}
**PERF: {‘stream0’: 0.0, ‘stream1’: 11.99, ‘stream2’: 0.0, ‘stream3’: 11.99, ‘stream4’: 11.99, ‘stream5’: 11.99, ‘stream6’: 11.99, ‘stream7’: 11.99, ‘stream8’: 11.99, ‘stream9’: 11.99}
**PERF: {‘stream0’: 0.0, ‘stream1’: 12.0, ‘stream2’: 0.0, ‘stream3’: 12.0, ‘stream4’: 12.0, ‘stream5’: 12.0, ‘stream6’: 12.0, ‘stream7’: 12.0, ‘stream8’: 12.0, ‘stream9’: 12.0}
Calling Stop 4
sink_4
**PERF: {‘stream0’: 0.0, ‘stream1’: 11.99, ‘stream2’: 0.0, ‘stream3’: 11.99, ‘stream4’: 7.2, ‘stream5’: 11.99, ‘stream6’: 11.99, ‘stream7’: 11.99, ‘stream8’: 11.99, ‘stream9’: 11.99}
**PERF: {‘stream0’: 0.0, ‘stream1’: 12.19, ‘stream2’: 0.0, ‘stream3’: 12.19, ‘stream4’: 0.0, ‘stream5’: 12.19, ‘stream6’: 12.19, ‘stream7’: 12.19, ‘stream8’: 12.19, ‘stream9’: 12.19}
**PERF: {‘stream0’: 0.0, ‘stream1’: 11.79, ‘stream2’: 0.0, ‘stream3’: 11.79, ‘stream4’: 0.0, ‘stream5’: 11.79, ‘stream6’: 11.79, ‘stream7’: 11.79, ‘stream8’: 11.79, ‘stream9’: 11.79}
**PERF: {‘stream0’: 0.0, ‘stream1’: 11.99, ‘stream2’: 0.0, ‘stream3’: 11.99, ‘stream4’: 0.0, ‘stream5’: 11.99, ‘stream6’: 11.99, ‘stream7’: 11.99, ‘stream8’: 11.99, ‘stream9’: 11.99}
The timeout is better to be set according to the FPS of the sources.
Current pad releasing/adding will impact nvstreammux since “It tries to collect an average of (batch-size/num-source) frames per batch from each source (if all sources are live and their frame rates are all the same). ”Gst-nvstreammux — DeepStream 6.2 Release documentation
You may try “export NVSTREAMMUX_ADAPTIVE_BATCHING=yes” to avoid the waiting.
Thanks Fiona,
I will test and update.
Hi @Fiona.Chen ,
I have tested with NVSTREAMUX_ADPATIVE_BATCHING and it seems working but has another observation. All sources shows same frame/seconds, even which is weird.
**PERF: {‘stream0’: 0.2, ‘stream1’: 0.2, ‘stream2’: 0.2, ‘stream3’: 0.2, ‘stream4’: 0.2, ‘stream5’: 0.2, ‘stream6’: 0.0, ‘stream7’: 0.2, ‘stream8’: 0.2, ‘stream9’: 0.2}
**PERF: {‘stream0’: 13.0, ‘stream1’: 13.0, ‘stream2’: 13.0, ‘stream3’: 13.0, ‘stream4’: 13.0, ‘stream5’: 13.0, ‘stream6’: 14.97, ‘stream7’: 13.0, ‘stream8’: 13.0, ‘stream9’: 13.0}
Calling Stop 3
sink_3
**PERF: {‘stream0’: 5.2, ‘stream1’: 5.2, ‘stream2’: 5.2, ‘stream3’: 5.2, ‘stream4’: 5.2, ‘stream5’: 5.2, ‘stream6’: 5.2, ‘stream7’: 5.2, ‘stream8’: 5.2, ‘stream9’: 5.2}
**PERF: {‘stream0’: 24.79, ‘stream1’: 24.79, ‘stream2’: 24.79, ‘stream3’: 0.0, ‘stream4’: 24.79, ‘stream5’: 24.79, ‘stream6’: 24.79, ‘stream7’: 24.79, ‘stream8’: 24.79, ‘stream9’: 24.79}
**PERF: {‘stream0’: 14.79, ‘stream1’: 14.79, ‘stream2’: 14.79, ‘stream3’: 0.0, ‘stream4’: 14.79, ‘stream5’: 14.79, ‘stream6’: 14.79, ‘stream7’: 14.79, ‘stream8’: 14.79, ‘stream9’: 14.79}
**PERF: {‘stream0’: 15.0, ‘stream1’: 15.0, ‘stream2’: 15.0, ‘stream3’: 0.0, ‘stream4’: 15.0, ‘stream5’: 15.0, ‘stream6’: 15.0, ‘stream7’: 15.0, ‘stream8’: 15.0, ‘stream9’: 15.0}
**PERF: {‘stream0’: 11.39, ‘stream1’: 11.39, ‘stream2’: 11.39, ‘stream3’: 0.0, ‘stream4’: 11.39, ‘stream5’: 11.39, ‘stream6’: 11.39, ‘stream7’: 11.39, ‘stream8’: 11.39, ‘stream9’: 11.39}
**PERF: {‘stream0’: 18.39, ‘stream1’: 18.39, ‘stream2’: 18.39, ‘stream3’: 0.0, ‘stream4’: 18.39, ‘stream5’: 18.39, ‘stream6’: 18.39, ‘stream7’: 18.39, ‘stream8’: 18.39, ‘stream9’: 18.39}
**PERF: {‘stream0’: 14.99, ‘stream1’: 14.99, ‘stream2’: 14.99, ‘stream3’: 0.0, ‘stream4’: 14.99, ‘stream5’: 14.99, ‘stream6’: 14.99, ‘stream7’: 14.99, ‘stream8’: 14.99, ‘stream9’: 14.99}
Calling Stop 0
sink_0
**PERF: {‘stream0’: 8.0, ‘stream1’: 8.0, ‘stream2’: 8.0, ‘stream3’: 0.0, ‘stream4’: 8.0, ‘stream5’: 8.0, ‘stream6’: 8.0, ‘stream7’: 8.0, ‘stream8’: 8.0, ‘stream9’: 8.0}
**PERF: {‘stream0’: 0.2, ‘stream1’: 22.2, ‘stream2’: 22.2, ‘stream3’: 0.0, ‘stream4’: 22.2, ‘stream5’: 22.2, ‘stream6’: 22.0, ‘stream7’: 22.2, ‘stream8’: 22.2, ‘stream9’: 22.2}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.99, ‘stream2’: 14.99, ‘stream3’: 0.0, ‘stream4’: 14.99, ‘stream5’: 14.99, ‘stream6’: 14.99, ‘stream7’: 14.99, ‘stream8’: 14.99, ‘stream9’: 14.99}
**PERF: {‘stream0’: 0.0, ‘stream1’: 15.0, ‘stream2’: 15.0, ‘stream3’: 0.0, ‘stream4’: 15.0, ‘stream5’: 15.0, ‘stream6’: 15.0, ‘stream7’: 15.0, ‘stream8’: 15.0, ‘stream9’: 15.0}
**PERF: {‘stream0’: 0.0, ‘stream1’: 15.19, ‘stream2’: 15.19, ‘stream3’: 0.0, ‘stream4’: 15.19, ‘stream5’: 15.19, ‘stream6’: 15.19, ‘stream7’: 15.19, ‘stream8’: 15.19, ‘stream9’: 15.19}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.98, ‘stream2’: 14.98, ‘stream3’: 0.0, ‘stream4’: 14.98, ‘stream5’: 14.98, ‘stream6’: 14.98, ‘stream7’: 14.98, ‘stream8’: 14.98, ‘stream9’: 14.98}
Calling Stop 4
sink_4
**PERF: {‘stream0’: 0.0, ‘stream1’: 7.79, ‘stream2’: 7.79, ‘stream3’: 0.0, ‘stream4’: 7.79, ‘stream5’: 7.79, ‘stream6’: 7.79, ‘stream7’: 7.79, ‘stream8’: 7.79, ‘stream9’: 7.79}
**PERF: {‘stream0’: 0.0, ‘stream1’: 22.38, ‘stream2’: 22.38, ‘stream3’: 0.0, ‘stream4’: 0.2, ‘stream5’: 22.38, ‘stream6’: 22.18, ‘stream7’: 22.38, ‘stream8’: 22.38, ‘stream9’: 22.38}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.78, ‘stream2’: 14.78, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 14.78, ‘stream6’: 14.78, ‘stream7’: 14.78, ‘stream8’: 14.78, ‘stream9’: 14.78}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.99, ‘stream2’: 14.99, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 14.99, ‘stream6’: 14.99, ‘stream7’: 14.99, ‘stream8’: 14.99, ‘stream9’: 14.99}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.98, ‘stream2’: 14.98, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 14.98, ‘stream6’: 14.98, ‘stream7’: 14.98, ‘stream8’: 14.98, ‘stream9’: 14.98}
**PERF: {‘stream0’: 0.0, ‘stream1’: 11.2, ‘stream2’: 11.2, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 11.2, ‘stream6’: 11.2, ‘stream7’: 11.2, ‘stream8’: 11.2, ‘stream9’: 11.2}
**PERF: {‘stream0’: 0.0, ‘stream1’: 18.58, ‘stream2’: 18.58, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 18.58, ‘stream6’: 18.58, ‘stream7’: 18.58, ‘stream8’: 18.58, ‘stream9’: 18.58}
**PERF: {‘stream0’: 0.0, ‘stream1’: 15.0, ‘stream2’: 15.0, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 15.0, ‘stream6’: 15.0, ‘stream7’: 15.0, ‘stream8’: 15.0, ‘stream9’: 15.0}
Calling Stop 5
sink_5
**PERF: {‘stream0’: 0.0, ‘stream1’: 7.79, ‘stream2’: 7.79, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 7.79, ‘stream6’: 7.79, ‘stream7’: 7.79, ‘stream8’: 7.79, ‘stream9’: 7.79}
**PERF: {‘stream0’: 0.0, ‘stream1’: 22.58, ‘stream2’: 22.58, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.2, ‘stream6’: 22.38, ‘stream7’: 22.58, ‘stream8’: 22.58, ‘stream9’: 22.58}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.99, ‘stream2’: 14.99, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 14.99, ‘stream7’: 14.99, ‘stream8’: 14.99, ‘stream9’: 14.99}
**PERF: {‘stream0’: 0.0, ‘stream1’: 15.0, ‘stream2’: 15.0, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 15.0, ‘stream7’: 15.0, ‘stream8’: 15.0, ‘stream9’: 15.0}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.78, ‘stream2’: 14.78, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 14.78, ‘stream7’: 14.78, ‘stream8’: 14.78, ‘stream9’: 14.78}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.98, ‘stream2’: 14.98, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 14.98, ‘stream7’: 14.98, ‘stream8’: 14.98, ‘stream9’: 14.98}
**PERF: {‘stream0’: 0.0, ‘stream1’: 10.99, ‘stream2’: 10.99, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 10.99, ‘stream7’: 10.99, ‘stream8’: 10.99, ‘stream9’: 10.99}
**PERF: {‘stream0’: 0.0, ‘stream1’: 18.78, ‘stream2’: 18.78, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 18.78, ‘stream7’: 18.78, ‘stream8’: 18.78, ‘stream9’: 18.78}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.79, ‘stream2’: 14.79, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 14.79, ‘stream7’: 14.79, ‘stream8’: 14.79, ‘stream9’: 14.79}
Calling Stop 2
sink_2
**PERF: {‘stream0’: 0.0, ‘stream1’: 7.59, ‘stream2’: 7.59, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 7.59, ‘stream7’: 7.59, ‘stream8’: 7.59, ‘stream9’: 7.59}
**PERF: {‘stream0’: 0.0, ‘stream1’: 22.6, ‘stream2’: 0.2, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 22.4, ‘stream7’: 22.6, ‘stream8’: 22.6, ‘stream9’: 22.6}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.98, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 14.98, ‘stream7’: 14.98, ‘stream8’: 14.98, ‘stream9’: 14.98}
**PERF: {‘stream0’: 0.0, ‘stream1’: 15.0, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 15.0, ‘stream7’: 15.0, ‘stream8’: 15.0, ‘stream9’: 15.0}
**PERF: {‘stream0’: 0.0, ‘stream1’: 15.18, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 15.18, ‘stream7’: 15.18, ‘stream8’: 15.18, ‘stream9’: 15.18}
Calling Start 4
Creating uridecodebin for [rtsp://74.234.85.155:8554/live/stream5]
source-bin-04
STATE CHANGE NO PREROLL
total sources : 6
Decodebin child added: decodebin10
Decodebin child added: rtph264depay10
Decodebin child added: h264parse10
Decodebin child added: capsfilter10
Decodebin child added: nvv4l2decoder10
In cb_newpad
sink_4
Decodebin linked to pipeline
**PERF: {‘stream0’: 0.0, ‘stream1’: 10.2, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 10.2, ‘stream7’: 10.2, ‘stream8’: 10.2, ‘stream9’: 10.2}
**PERF: {‘stream0’: 0.0, ‘stream1’: 0.2, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 0.0, ‘stream5’: 0.0, ‘stream6’: 0.0, ‘stream7’: 0.2, ‘stream8’: 0.2, ‘stream9’: 0.2}
**PERF: {‘stream0’: 0.0, ‘stream1’: 8.8, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 8.6, ‘stream5’: 0.0, ‘stream6’: 8.8, ‘stream7’: 8.8, ‘stream8’: 8.8, ‘stream9’: 8.8}
**PERF: {‘stream0’: 0.0, ‘stream1’: 15.0, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 15.0, ‘stream5’: 0.0, ‘stream6’: 15.0, ‘stream7’: 15.0, ‘stream8’: 15.0, ‘stream9’: 15.0}
**PERF: {‘stream0’: 0.0, ‘stream1’: 10.8, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 10.8, ‘stream5’: 0.0, ‘stream6’: 10.8, ‘stream7’: 10.8, ‘stream8’: 10.8, ‘stream9’: 10.8}
**PERF: {‘stream0’: 0.0, ‘stream1’: 18.99, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 18.99, ‘stream5’: 0.0, ‘stream6’: 18.99, ‘stream7’: 18.99, ‘stream8’: 18.99, ‘stream9’: 18.99}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.99, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 14.99, ‘stream5’: 0.0, ‘stream6’: 14.99, ‘stream7’: 14.99, ‘stream8’: 14.99, ‘stream9’: 14.99}
**PERF: {‘stream0’: 0.0, ‘stream1’: 14.98, ‘stream2’: 0.0, ‘stream3’: 0.0, ‘stream4’: 14.98, ‘stream5’: 0.0, ‘stream6’: 14.98, ‘stream7’: 14.98, ‘stream8’: 14.98, ‘stream9’: 14.98}
Since your timeout is a very large value, the time is enough for the nvstreammux to construct the full batch by the round-robin algorithm. So the FPS for each channel matches the number of batches per second.
I understand this, but nvstreammux should never cause pipeline to halt. That requires investigation from your side. My theory is that when we set batch push timeout high and try to make modifications on the sources, nvstreammux still has old stream’s data in its buffer and gets a request to delete existing source when nvstreammux is processing. If batch push timeout is short, nvstreammux has a chance to flush and process pad release request. It seems like nvstreammux is running on the main thread only which kinda confirms this theory.
However, if streams are at different rates, even though we set batch push timeout to lower value we may still see this issue happening. It looks like nvstreammux is not handling it well.
The “batched-push-timeout” is used to control the batch construction, so you need to set reasonable value according to the actual FPS of your sources if you don’t want it to impact the pipeline process.
The following log is what I got with “batched-push-timeout=400”:
**PERF: {‘stream0’: 25.95, ‘stream1’: 3.99, ‘stream2’: 23.95, ‘stream3’: 25.95, ‘stream4’: 23.95, ‘stream5’: 23.95, ‘stream6’: 0.0, ‘stream7’: 25.95, ‘stream8’: 0.0, ‘stream9’: 25.95}
**PERF: {‘stream0’: 25.94, ‘stream1’: 7.98, ‘stream2’: 25.94, ‘stream3’: 21.95, ‘stream4’: 23.95, ‘stream5’: 21.95, ‘stream6’: 0.0, ‘stream7’: 21.95, ‘stream8’: 0.0, ‘stream9’: 23.95}
**PERF: {‘stream0’: 25.97, ‘stream1’: 7.99, ‘stream2’: 21.97, ‘stream3’: 25.97, ‘stream4’: 27.96, ‘stream5’: 25.97, ‘stream6’: 0.0, ‘stream7’: 23.97, ‘stream8’: 0.0, ‘stream9’: 27.96}
**PERF: {‘stream0’: 25.98, ‘stream1’: 6.0, ‘stream2’: 25.98, ‘stream3’: 27.98, ‘stream4’: 19.99, ‘stream5’: 23.98, ‘stream6’: 0.0, ‘stream7’: 21.99, ‘stream8’: 0.0, ‘stream9’: 23.98}
**PERF: {‘stream0’: 27.96, ‘stream1’: 3.99, ‘stream2’: 17.98, ‘stream3’: 19.97, ‘stream4’: 23.97, ‘stream5’: 21.97, ‘stream6’: 0.0, ‘stream7’: 23.97, ‘stream8’: 0.0, ‘stream9’: 25.97}
**PERF: {‘stream0’: 23.97, ‘stream1’: 5.99, ‘stream2’: 25.97, ‘stream3’: 25.97, ‘stream4’: 29.96, ‘stream5’: 25.97, ‘stream6’: 0.0, ‘stream7’: 21.97, ‘stream8’: 0.0, ‘stream9’: 25.97}
If “batched-push-timeout” is too short, it may cause every single frame be inferenced and processed but not in batch. The total performance will be impacted. So it is very important to arrange a proper “batched-push-timeout” value which may be a compromise decision by you.
