After running deepstream for a period of time, the perf module stopped printing
**• Hardware Platform (Jetson / GPU)6.1
**• DeepStream Version 7.1
**• JetPack Version (valid for Jetson only)6.1
**• TensorRT Version 10.3
**• NVIDIA GPU Driver Version (valid for GPU only)540.4.0
The Type of this mechine is Orin AGX 64G
In the new version, this issue has occurred twice. I will upgrade the log level again later to confirm if this issue has been resolved?
logger.zip (1006.6 KB)
Please also share the configure files. Thanks!
test5_config_file_nvmultiurisrcbin_src_list_attr_all.txt (8.4 KB)
Frequent addition and deletion may be one of the factors that cause trackers. From these two logs, it seems that there are some other reasons as well.
There is a very strange phenomenon in the picture above,
0.00 (18.83)
Question 0.00 is a real-time value, 18.83 is an average value, right?
0.00 (18.82) lasted for a long time, with no decrease in the average value and no automatic deletion
I don’t know if it has anything to do with the instability of the flow here?
I found you don’t enable model which can run on DLA. New JPS which based on DeepStream 7.1 will release soon. Is it possible to wait new JPS release and test on the new JPS release?
I have used DLA
config_infer_primary.txt (3.4 KB)
I added it here
I try it
Can you answer my question?
Yes, you are right.
Kevin, This phenomenon has occurred for the third time. Below are the logs. Please take a look, they are quite large
Link: https://pan.baidu.com/s/1ttvSr9WfghaXWYtJkdI_rg?pwd=abcd Extract code: abcd
I will also analyze it
It doesn’t seem to be a track issue
I have some issue to download it. Can you share less log which the issue happen?
I try it
you try downloading it on either side as well
I set the log level to 4
I suggest you download it if possible, as this log is more comprehensive
logger.txt (875.3 KB)
This is the last time the nearby logs were printed
Please use below setting to do your test. Seems you removed “select-rtp-protocol=4” in your configure file.
rtsp-reconnect-interval-sec=10
rtsp-reconnect-attempts=1
