Deepstream isn't running more
After 30 days running, deepstream do not run more. I deleted and configure the camera again and there were no results.
I checked all 3 services and the status is active running:
$ sudo systemctl status jetson-redis
$ sudo systemctl status jetson-ingress
$ sudo systemctl status jetson-vst
$ sudo docker ps
CONTAINER ID   IMAGE                                                   COMMAND                  CREATED        STATUS             PORTS     NAMES
06289b383fd9   nvcr.io/nvidia/jps/vst:v1.2.58_aarch64                  "sh -c '/root/vst_re…"   24 hours ago   Up About an hour             vst
3d239148f290   nvcr.io/nvidia/jps/ialpha-ingress-arm64v8:0.10          "sh -c '/nginx.sh 2>…"   24 hours ago   Up 24 hours                  ingress
6223d6cc8ae2   redisfab/redistimeseries:master-arm64v8-jammy           "docker-entrypoint.s…"   24 hours ago   Up 24 hours                  redis
7ba627101c57   nvcr.io/nvidia/jps/vst:nvstreamer_v0.2.31_aarch64       "sh -c '/root/vst_re…"   3 weeks ago    Up 24 hours                  nvstreamer
1bbc93fdb7aa   prom/node-exporter                                      "/bin/node_exporter …"   6 weeks ago    Up 24 hours                  nodeexporter
ff1d7c40b9a8   grafana/grafana                                         "/run.sh"                6 weeks ago    Up 24 hours                  grafana
a63af8dfd2d4   nvcr.io/nvidia/jps/jps-metric-exporter:v1.4.0_arm64v8   "/usr/bin/shelless_u…"   6 weeks ago    Up 24 hours                  jps-metric-exporter
171e0fc53188   prom/prometheus                                         "/bin/prometheus --c…"   6 weeks ago    Up 24 hours                  prometheus
d1f7807aa68e   nvcr.io/nvidia/jps/its-monitoring:v1.6.1_arm64          "/root/its_monitorin…"   6 weeks ago    Up 24 hours                  its-monitoring
e0522894370b   prom/pushgateway                                        "/bin/pushgateway"       6 weeks ago    Up 24 hours                  push-gateway
7ce056d8ccc2   prom/alertmanager                                       "/bin/alertmanager -…"   6 weeks ago    Up 24 hours                  alert-manager
677ac18e68cf   nvcr.io/nvidia/jps/sdr:jps-v2.0.4                       "sh -c '/wdm/dist/sd…"   6 weeks ago    Up 24 hours                  sdr-emdx
37a00896bc46   nvcr.io/nvidia/jps/emdx-analytics:jps_v1.1.1            "python3 gunicorn --…"   6 weeks ago    Up 24 hours                  emdx-analytics-02
e5fe84d0ae5d   nvcr.io/nvidia/jps/emdx-analytics:jps_v1.1.1            "python3 gunicorn --…"   6 weeks ago    Up 24 hours                  emdx-analytics-01
eb7c320562b4   nvcr.io/nvidia/jps/sdr:jps-v2.0.4                       "sh -c '/wdm/dist/sd…"   6 weeks ago    Up 24 hours                  sdr
803a047fef45   nvcr.io/nvidia/jps/sdr-reprovision-controller:jps-v1    "/bin/sh -c ./entryp…"   6 weeks ago    Up 24 hours                  sdr-reprovision-controller
82460b085953   nvcr.io/nvidia/jps/deepstream:7.0-jps-v1.1.1            "sh -c 'deepstream-t…"   6 weeks ago    Up 24 hours                  deepstream
fcc8be481644   nvcr.io/nvidia/jps/emdx-analytics-web-api:jps_v1.1.1    "python3 gunicorn --…"   6 weeks ago    Up 24 hours                  emdx-webapi
Can you share the log of deepstream and Kernel log?
Logs:
deepstream.zip (90.7 KB)
kern.zip (7.7 MB)
I found many PVA crash log in Kernel log. Can you have a try with CUDA backend nvtracker by modify deepstream config: ll-config-file=config_tracker_NvDCF_PNv2.6_Interval_1_PVA.yml;config_tracker_NvDCF_PNv2.6_Interval_1_PVA.yml;config_tracker_NvDCF_PNv2.6_Interval_1_CUDA.yml?
What is PVA?
I’ll do the new config on DS.
You can check the information of PVA in here: VPI - Vision Programming Interface: Architecture
