Unable to see video analytics with metropolis
I installed Metropolis ai_nvr sample on a Jetson Orin NX 16GB. I have connected it to an IP Camera (Axis M3065-V) and am able to see live video in the livestream tab.
However, when I open VLC to rtsp://localhost:8555/ds-test or rtsp://localhost:8556/ds-test, VLC is unable to open the stream.
docker logs -f deepstream prints the following:
Active sources: 1
Mon Feb 12 22:58:15 2024
PERF(0):
29.05 (29.28) source_id : 0 stream_name AXIS-M3065-V
Active sources : 0
PERF(1):
ps. I had installed a second stream from a video file through nvstreamer, and I have since removed that stream.
Are you trying to play the output stream on the same Jetson Orin device? If not, you will need to use the device IP rather than localhost. Based on the log snippet you posted, the overlay stream at rtsp://<IP-OF-JETSON>:8555/ds-test should be up. rtsp://<IP-OF-JETSON>:8556/ds-test will not work as there are currently no sources on the second pipeline on your system.
If that does not work, please try restarting the DeepStream container using sudo docker restart deepstream , wait until the stream appears again in DeepStream logs, then try playing the overlay stream.
reinstalled Jetpack 6.0DP to my AGX Orin, reinstalled Metropolis.
Followed the steps above, I do see a live stream in the VST UI, but still no luck opening rtsp://localhost:8555/ds-test in VLC.
I tried 8556 port, and also tried with using the IP address. It made no difference.
Can you check the log of deepstream container: docker logs deepstream?
The logs are long, but in the end it shows:
Active sources : 2
**PERF: FPS 1 (Avg) FPS 0 (Avg)
Fri Mar 15 17:18:23 2024
PERF(0):
28.40 (29.05) source_id : 1 stream_name AXIS%20M3065-V
28.40 (29.04) source_id : 0 stream_name SENSOR
Active sources : 0
PERF(1):
Note that I have two cameras: one real IP camera, AXIS-M3065-V
Other is nvstreamer virtual camera showing a video file.
Both are viewable as livestream in VST
Please note the output of deepstream.log
jetson@ubuntu:~$ sudo tail -f /data/logging-volume/deepstream.log | grep -v “^$”
Active sources : 2
Fri Mar 15 18:56:59 2024
PERF(0):
29.23 (29.05) source_id : 1 stream_name AXIS%20M3065-V
29.23 (29.04) source_id : 0 stream_name SENSOR
Active sources : 0
PERF(1):
Active sources : 2
Fri Mar 15 18:57:04 2024
PERF(0):
28.94 (29.05) source_id : 1 stream_name AXIS%20M3065-V
28.94 (29.04) source_id : 0 stream_name SENSOR
Active sources : 0
PERF(1):
Active sources : 2
Fri Mar 15 18:57:09 2024
PERF(0):
29.01 (29.05) source_id : 1 stream_name AXIS%20M3065-V
29.01 (29.04) source_id : 0 stream_name SENSOR
Active sources : 0
PERF(1):
sudo netstat -tulpn | grep 8555
tcp 0 0 0.0.0.0:8555 0.0.0.0:* LISTEN 21041/deepstream-mo
Now, I am able to view the Video Analytics
Glad to know you can video the Video Analytics.
