Deepstream 7.1 destroyed rtsp output
• Hardware Platform (Jetson / GPU) - GPU
• DeepStream Version - 7.1
• TensorRT Version - 10.3.0.26
• NVIDIA GPU Driver Version (valid for GPU only) - 565.57.01
• Issue Type( questions, new requirements, bugs) - not stable rtsp output without detections
• How to reproduce the issue ? I attached code with logs and config
Description
Detector: Deepstream YOLO, CUDA 12.7
Python app ( pipeline.py)
I checked rtsp output, it is not stable with drops it is being destroyed, additional I can’t see detections, I ve checked frame info from tracks it is empty (see ds.log).
ffplay logs:
[rtsp @ 0x785a78000cc0] max delay reached. need to consume packet[rtsp @ 0x785a78000cc0] RTP: missed 17 packets[rtsp @ 0x785a78000cc0] max delay reached. need to consume packet[rtsp @ 0x785a78000cc0] RTP: missed 1 packets[rtsp @ 0x785a78000cc0] max delay reached. need to consume packet[rtsp @ 0x785a78000cc0] RTP: missed 15 packets[rtsp @ 0x785a78000cc0] max delay reached. need to consume packet[rtsp @ 0x785a78000cc0] RTP: missed 1 packets[h264 @ 0x785a78e4cb00] out of range intra chroma pred mode f=0/0[h264 @ 0x785a78e4cb00] error while decoding MB 51 6[h264 @ 0x785a78e4cb00] concealing 7438 DC, 7438 AC, 7438 MV errors in I frame[rtsp @ 0x785a78000cc0] max delay reached. need to consume packet[rtsp @ 0x785a78000cc0] RTP: missed 1 packets[rtsp @ 0x785a78000cc0] max delay reached. need to consume packet
The problem repeats itself with deepstream-app config, not stable rtsp without detections
deepstream.zip (9.0 KB)
  1. Your input source is a RTSP source. Please enable “select-rtp-protocol” as TCP protocol to improve the rtsp source quality. select-rtp-protocol
  2. Your [streammux] group set “batched-push-timeout=-1” configuration which is not proper for live source. Please set the value as “1/fps of your input RTSP source”.
  3. Please set “qos=0” in your [sink0] group. DeepStream Reference Application - deepstream-app — DeepStream documentation
set select-rtp-protocol=4, batched-push-timeout=17000, 33000, 40000 (I have 60 FPS on input rtsp) but result is the same, frame drops, destroyed pictures
[h264 @ 0x74f65c1cef00] concealing 1789 DC, 1789 AC, 1789 MV errors in I frame
[rtsp @ 0x74f65c000cc0] max delay reached. need to consume packet26
[rtsp @ 0x74f65c000cc0] RTP: missed 17 packets
[rtsp @ 0x74f65c000cc0] RTP: missed 10 packets
[h264 @ 0x74f65c1953c0] corrupted macroblock 53 63 (total_coeff=-1)
[h264 @ 0x74f65c1953c0] error while decoding MB 53 63
[h264 @ 0x74f65c1953c0] concealing 596 DC, 596 AC, 596 MV errors in P frame
[h264 @ 0x74f65c1b2140] corrupted macroblock 53 56 (total_coeff=16)
[h264 @ 0x74f65c1b2140] error while decoding MB 53 56
[h264 @ 0x74f65c1b2140] concealing 1436 DC, 1436 AC, 1436 MV errors in P frame
[rtsp @ 0x74f65c000cc0] RTP: missed 18 packets
[rtsp @ 0x74f65c000cc0] RTP: missed 1 packets
[h264 @ 0x74f65c143880] Invalid level prefix897KB sq=    0B f=27/27
[h264 @ 0x74f65c143880] error while decoding MB 32 38
[h264 @ 0x74f65c143880] concealing 3617 DC, 3617 AC, 3617 MV errors in P frame
[rtsp @ 0x74f65c000cc0] max delay reached. need to consume packet27
[rtsp @ 0x74f65c000cc0] RTP: missed 9 packets
[h264 @ 0x74f65cc630c0] Invalid level prefix486KB sq=    0B f=27/27
[h264 @ 0x74f65cc630c0] error while decoding MB 100 65
[h264 @ 0x74f65cc630c0] concealing 309 DC, 309 AC, 309 MV errors in I frame
[rtsp @ 0x74f65c000cc0] RTP: missed 11 packets
[h264 @ 0x74f65c1646c0] out of range intra chroma pred mode f=27/27
[h264 @ 0x74f65c1646c0] error while decoding MB 100 31
[h264 @ 0x74f65c1646c0] concealing 4389 DC, 4389 AC, 4389 MV errors in P frame
[h264 @ 0x74f65c1953c0] ref 32 overflowvq=  320KB sq=    0B f=28/28
[h264 @ 0x74f65c1953c0] error while decoding MB 43 24
[h264 @ 0x74f65c1953c0] concealing 5286 DC, 5286 AC, 5286 MV errors in P frame
[rtsp @ 0x74f65c000cc0] max delay reached. need to consume packet28
[rtsp @ 0x74f65c000cc0] RTP: missed 106 packets
  26.47 M-V:  0.044 fd=   3 aq=    0KB vq=  488KB sq=    0B f=28/28
Where did you run ffplay? The same device where the DeepStream app is runing? What is the CPU loading when you run your DeepStream app?
ffplay is launched from a local desktop, deepstream is launched on a remote server without a display.
CPU loading 40-50%
Then it may be a ethernet issue. Please check with your network configurations.
so these errors:
invalid, non monotonically increasing dtscorrupt decoded frame / corrupted macroblockmax delay reached. need to consume packet
caused of network? It seems strange, because I can check input rtsp stream and it s stable
The output is also transferred through ethernet.
ok, I will check with another networj and come back with the results, thanks for your answers
[rtsp @ 0x753fb0000cc0] RTP: dropping old packet received too late
    Last message repeated 3 times
    Last message repeated 128 times
    Last message repeated 356 times
    Last message repeated 201 times
    Last message repeated 165 times
    Last message repeated 97 times
    Last message repeated 222 times
    Last message repeated 78 times
    Last message repeated 153 times
[rtsp @ 0x753fb0000cc0] max delay reached. need to consume packet
[rtsp @ 0x753fb0000cc0] RTP: missed 6 packets
    Last message repeated 87 times
    Last message repeated 100 times
[rtsp @ 0x753fb0000cc0] RTP: missed 56 packets
    Last message repeated 57 times
    Last message repeated 46 times
    Last message repeated 83 times
I ve checked it on local machine, the stream has become more stable, but artifacts are visible, it is being destroyed, when adding streams, the artifacts increase and stability disappears.
Maybe there are some params for setting stable multi re-streamming in config?
Apparently it is a network bandwidth problem. Please check with your network configurations.
ok, thanks for your help, I ll close issue
I have additional details about python app code, when I start it, all stages of pipe run successfully, but in logs I see (3 fps) on single stream and very low gpu usage, can you check this code or should i start a new topic?
Please create new topic for new issue.
the next episode here: https://forums.developer.nvidia.com/t/deepstream-7-1-multi-stream-python-pipe-error/344700
