Deepstream and TensorRT inference results difference
Hi. I have a binary classification model in ONNX format, which I converted to the .engine format using FP32 precision. To verify that the conversion was successful, I wrote a script that runs inference on the .engine file and returns the results. I tested the model on a set of images with known ground truth labels, and the outputs from the .engine model closely matched those from the original ONNX model.
Next, I wanted to validate that the model behaves the same when integrated into a DeepStream pipeline. However, I noticed that the outputs from the DeepStream pipeline differ significantly from those obtained with the script.
For example, for an image with a ground truth label of 0, the script produced a prediction of 0.1309, while the DeepStream pipeline output was 0.7418. For other images, the differences are similarly large. Predictions for obvious true positive samples are consistent (close to 1, e.g., ~0.999), but for other cases, the discrepancy is significant.
The model expects an input size of 1x3x384x384, and I have ensured that images are preprocessed correctly in both the script and the DeepStream pipeline. I’m trying to understand what could be causing this discrepancy since both nvinfer and script use the same
The script for.engine model inference :
engine_classification_inference .py.txt (8.0 KB)
Nvinfer config:
[property]
gpu-id=0
net-scale-factor=0.007843137255
offsets=127.5;127.5;127.5
model-color-format=0 # 0=RGB, 1=BGR
model-engine-file=binary_model.engine
labelfile-path=labels.txt
network-input-order=0
batch-size=1
network-type=1 # classifier
process-mode=1
gie-unique-id=1
classifier-threshold=0.1
scaling-compute-hw=2
interval=0
maintain-aspect-ratio=1
The Deepstream pipeline schema:
Can you tell us the following information:
• DeepStream Version
• TensorRT Version
Seems the sentence is not complete. The same of what?
Yes, here’s the full sentence:
I’m trying to understand what could be causing this discrepancy since both nvinfer and script use the same preprocessing, and in both cases they should take the same inputs in accordance with the attached nvinfer configuration.
• Hardware Platform (Jetson / GPU): Nvidia Jetson AGX ORIN
• DeepStream Version: DeepStreamSDK 7.1.0
• TensorRT Version: 10.9.0.34
DeepStream 7.1 GA is compatible to TensorRT 10.3. Please confirm with your environment again.
Please make sure you comparison is based on the same TensorRT version.
You’re right. There was a discrepancy between the TensorRT version in the Python environment and the one installed on the device.
Now both are using TensorRT 10.3.0, but the difference in model outputs still persists.
  1. Please refer to DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums to make sure your parameters and settings are correct.
  2. The default preprocessing algorithm inside gst-nvinfer is not pytorch or opencv aligned. You may consider to use the new preprocessing library if your model is very sensitive to the preprocess algorithm. deepstream_tao_apps/apps/tao_others/deepstream_custom_preprocessing_app at master · NVIDIA-AI-IOT/deepstream_tao_apps
Hi! Since we haven’t heard back from you for a while, we’re assuming everything is resolved and will close this topic. If you need any further help, don’t hesitate to open a new topic. Thanks!
