Deepstream-app config change video/x-raw format
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.1.1
• JetPack Version (valid for Jetson only) 5.0.2
*• Issue Type( questions, new requirements, bugs) New requirements
I like use DeepStream Reference Application - deepstream-app.
I read the document.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_ref_app_deepstream.html#source-group
Can I change video/x-raw format for using deepstream-app_config.txt?
I don’t wanna use custom program to change that.
I wanna use deepstream-app config.
Can you add the fuction next deepstream vision?
The deepstream-app is open source sample. You can change the code as needed.
CSI type has 1 custom caps, V4L2 has 1 custom caps and 1 default caps1?
Maybe I need to change the deepstream_source_bin.c and deepstream_sources.h and deepstream_config_file_parser.c, and then add custom setting?
OK, I understand that, however I hope have a chance to see the function in the next vesion, thank you.
