I am not able to run deepstream app with a 3G-SDI camera which outputs video in YV12 format. Is there any way to pass the video format to deepstream app ?
Can you provide platform and software information with the template?
• DeepStream Version
• TensorRT Version
What kind of camera? CSI, USB or RTSP? How did you get the YV12 format video from camera with gstreamer?
Hi ,
Please find below the details:
Hardware Platform : TX2i
Deepstream version : 5.0
TensorRT version: 7.1.3.0
I am using 3G-SDI camera which is connected to mPCIE card. The device is recognised as /dev/video1. I am able to see the image by running following command:
gst-launch-1.0 v4l2src io-mode=2 device=/dev/video0 ! video/x-raw,width=1920,height=1080,format=YV12 ! xvimagesink sync=false&
The video format supported by this device is found by running the command:
jetson@jetson-desktop:~$ v4l2-ctl -d /dev/video1 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘MPEG’ (compressed)
Name : H264 Encoded Stream
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.020s (50.000 fps)
Size: Discrete 1280x1024
Size: Discrete 1920x1080
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1680x1050
Index : 1
Pixel Format: 'YV12'
Name : YVU 4:2:0 12bpp
Index : 2
Pixel Format: 'YU12'
Name : YUV 4:2:0 12bpp
Index : 3
Pixel Format: 'NV12'
Name : NV12 4:2:0 12bpp
This is the change made into deepstream_app_config file :
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
#width=1280
#height=720
width=1920
height=1080
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=1
camera-width=1920
camera-height=1080
camera-fps-n=15
camera-fps-d=1
camera-v4l2-dev-node=1
[streammux]
gpu-id=0
batch-size=1
batched-push-timeout=-1
width=1920
height=1080
nvbuf-memory-type=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
[osd]
enable=1
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
batch-size=1
gie-unique-id=1
interval=0
labelfile-path=ssd_coco_labels.txt
model-engine-file=sample_ssd_relu6.uff_b1_gpu0_fp32.engine
config-file=config_infer_primary_ssd.txt
nvbuf-memory-type=0
I am able to successfully run the same app with USB camera which is /dev/video2.
Goutam
That’s good! Since nvvideoconvert only support I420,P010_10LE, NV12, BGRx, RGBA,or GRAY8 format input, you can use “videoconvert” to convert YV12 to I420 or NV12 format, and then use nvvideoconvert to convert the video to NVMM NV12 format for DeepStream.
Thanks. I am little new to this. Can you please elaborate more ? Which file do i need to make these changes? Any steps/instructions will be helpful.
The camera supports more than one format (YV12, YU12, NV12) and deepstream-app can not set the format with config file. You may need to try to modify the deepstream-app source codes.
In /opt/nvidia/deepstream/deepstream-5.0/sources/apps/apps-common/src/deepstream_source_bin.c, the camera source is created in create_camera_source_bin() function.
You may try to change the following codes
caps1 = gst_caps_new_simple (“video/x-raw”,
“width”, G_TYPE_INT, config->source_width, “height”, G_TYPE_INT,
config->source_height, “framerate”, GST_TYPE_FRACTION,
config->source_fps_n, config->source_fps_d, NULL);
to the codes of
config->source_fps_n, config->source_fps_d, “format”, “YV12”, NULL);
And you need to rebuild deepstream-app and run the new deepstream-app to check whether it works.
