When I write code according to this pipeline component diagram, when converting mat, I can’t use source_ ID correctly distinguishes video streams, I want to know what causes it and what I should do to distinguish it correctly!
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
For your quesiton, could you share a diff file about what you are trying to do and what’s the error log.
In addition, you can check Deepstream sample code snippet to see if any help.
