Hello
my system is as below
Xavier NX
Deepstream 5.0
Jetpack 4.4
Hello
Xavier NX
Deepstream 5.0
Jetpack 4.4
By default the window system is X11 in nveglglessink plugin:
winsys : Takes in strings "x11" or "wayland" to specify the windowing system to be used
flags: readable, writable
String. Default: "x11"
Please set the property in deepstream-test1 and try again.
surely i already change the x11
Please refer to this post and try:
See if running it in rc.local works.
hello
it doesnot work for me
because i use weston environment
Does it work with nvoverlaysink plugin? The sink plugin should work in X11 and Weston.
