I add something in ${HOME}/configs/PGIE-FP16-CarType-CarMake-CarColor.txt
[server]
port=2222
wait-for-client-output=0
dump-client-image-crop=0
crop-width=640
crop-height=480
crop-format=1
crop-color-format=1
Then I do
$ nvgstiva-app -c ${HOME}/configs/PGIE-FP16-CarType-CarMake-CarColor.txt
I get log in terminal:
CLASS_IDS TO OEPRATE ON gie_id(0) : 2:
** ERROR: <create_processing_instance:779>: Could not create element nvivatxrxserver
** ERROR: <create_processing_instance:890>: create_processing_instance failed
** ERROR: <create_pipeline:1024>: create_pipeline failed
** ERROR: main:384: Failed to create pipeline
Quitting
App run failed
Can I ask whether it is the correct way to display the video with detecting boxes on another ubuntu host machine or what can I do to stream the output results of deepstream while the nvgstiva is running?
