Deepstream display for test apps
• Hardware Platform (Jetson / GPU) —GPU, T4 ec2 instance
• DeepStream Version — 5.0
• JetPack Version (valid for Jetson only) — NA
• TensorRT Version
Can someone guide on how to stream/run deepstream python test apps on the docker container on ec2 ubuntu instance.
X11 display is shared with the container, but how to run the GUI of the apps?
Does it require vnc/firefox set-up separately on the container?
Download python binding package (deepstream_python_v0.9.tbz2) from : https://developer.nvidia.com/deepstream-getting-started
Copy the package into docker, then install:
tar xpf deepstream_python_v0.9.tbz2
cd deepstream_python_v0.9
tar xpf ds_pybind_v0.9.tbz2 -C /opt/nvidia/deepstream/deepstream/sources/
then, python gets installed under /opt/nvidia/deepstream/deepstream/sources/
with xhost + executed before launching the docker, docker can connect the display to
he host’s X display.
And, you can also refer to deepstream_python_apps/HOWTO.md at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub about how to install python binding.
