After Installing DeepStream SDK on Jetson,I use the command line “ nvgstiva-app -c {HOME}/configs/PGIE-FP16-CarType-CarMake-CarColor.txt” to confirm that the DeepStream installation is successful,but fail:
------------> 0,128,128:1,0,0:2,0,0:3,0,0:4,0,0:5,0,0: -----------------
------------> 0,1920,1080:1,100,1080:2,1920,1080:3,1920,1080:4,0,0:5,0,0: -----------------
CLASS_IDS TO OEPRATE ON gie_id(0) : 2:
------------> 0,128,128:1,0,0:2,0,0:3,0,0:4,0,0:5,0,0:6,0,0:7,0,0:8,0,0:9,0,0:10,0,0:11,0,0: -----------------
------------> 0,1920,1080:1,100,1080:2,1920,1080:3,1920,1080:4,0,0:5,0,0:6,0,0:7,0,0:8,0,0:9,0,0:10,0,0:11,0,0: -----------------
------------> 0,128,128:1,0,0:2,0,0:3,0,0:4,0,0:5,0,0:6,0,0:7,0,0:8,0,0:9,0,0:10,0,0:11,0,0:12,0,0:13,0,0:14,0,0:15,0,0:16,128,1920:17,0,100:18,0,1920:19,0,1920:20,0,0:21,0,0:22,0,0:23,0,0: -----------------
------------> 0,1920,1080:1,100,1080:2,1920,1080:3,1920,1080:4,0,0:5,0,0:6,0,0:7,0,0:8,0,0:9,0,0:10,0,0:11,0,0:12,0,0:13,0,0:14,0,0:15,0,0:16,1080,1:17,1080,1:18,1080,4:19,1080,4:20,0,0:21,0,0:22,0,0:23,0,0: -----------------
------------> 0,0:1,0:2,0: -----------------
------------> 0,0,0:1,0,0:2,0,0: -----------------
------------> 0,1920,1080:1,100,1080:2,1920,1080: -----------------
------------> 0,0.200000,0.100000,3,0:1,0.200000,0.100000,3,0:2,0.200000,0.100000,3,0: -----------------
CPU usage measurement requires governor to be set to performance------------> 0,0.0,1.0,0.0:1,0.0,1.0,1.0:2,0.0,0.0,1.0:3,1.0,1.0,0.0 -----------------
Error while initialize EGL display connection
nvbuf_utils: Invalid width=0 height=0 layout=0
NvBufferCreateEx with memtag 0 failed
nvcaffegie: NvBufferCreateEx failed
What is the problem?anyone met and how to solve? Thanks.
