• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.1
• TensorRT Version 10.5.0.18
• NVIDIA GPU Driver Version (valid for GPU only) 560.35.03
• Issue Type( questions, new requirements, bugs) Bug
Pipeline:
nvurisrcbin -> nvstreammux -> nvinfer -> nvtracker -> nvdspreprocess
Description:
I’m encountering a batch-related issue with my pipeline. I’ve implemented a custom transform function in the nvdspreprocess
plugin. However, within the top-level function (called by the preprocessing plugin), the NvDsPreProcessBatch *batch
argument has a mismatch:
batch->units.size()
== 1batch->batch_meta->num_frames_in_batch
== 2 (as expected, withbatch_size == 2
set in the upstreamnvstreammux
Interestingly, the issue resolves when I set batch_size == 1
in nvstreammux
, but this underutilizes resources.
Has anyone encountered this issue, or can provide guidance on why the batch->units.size()
does not align with num_frames_in_batch
