DeepStream frame get to openCV Mat
Jetson NX Xavier
• DeepStream Version
5.1
4.5.1
• TensorRT Version
7.1.3.0
Question
Deepstream_Pose_Estimation sample code : GitHub - NVIDIA-AI-IOT/deepstream_pose_estimation: This is a sample DeepStream application to demonstrate a human pose estimation pipeline.
Hello
I am developing applications using Deepstream Pose estimation Code through Xavier NX.
Under certain conditions, we want to save the frame as a jpg image, and we tried to run it by referring to the code in several topics in forum, but the results were as below.
Currently, I think the step setting value may be the cause of the problem when generating mat of opencv, but I couldn’t find a satisfactory solution, so I ask for your help.
LTQERctHCg
5o-MjB5heD
first image is set to frame_step (surface->surfaceList[frame_meta->batch_id].pitch)
second image is set to cv:Mat:AUTO_STEP
below is my code
/* MetaData to handle drawing onto the on-screen-display */
static void create_display_meta(Vec2D &objects, Vec3D &normalized_peaks, NvDsFrameMeta *frame_meta, int frame_width, int frame_height, GstBuffer *buf)
int K = topology.size();
int count = objects.size();
NvDsBatchMeta *bmeta = frame_meta->base_meta.batch_meta;
NvDsDisplayMeta *dmeta = nvds_acquire_display_meta_from_pool(bmeta);
nvds_add_display_meta_to_frame(frame_meta, dmeta);
GstMapInfo map;
memset (&map, 0, sizeof (map));
NvBufSurface *surface = NULL;
cv::Mat frame;
if(gst_buffer_map(buf, &map, GST_MAP_READ)){
surface = (NvBufSurface *)map.data;
 NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ);
 NvBufSurfaceSyncForCpu(surface, -1, -1);
gint frame_width = (gint)surface->surfaceList[frame_meta->batch_id].width;
gint frame_height = (gint)surface->surfaceList[frame_meta->batch_id].height;
void *frame_data = surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0];
size_t frame_step = surface->surfaceList[frame_meta->batch_id].pitch;
frame = cv::Mat(frame_height, frame_width, CV_8UC4, frame_data, cv::Mat::AUTO_STEP);//frame_step-frame_width);
Mat out_mat = cv::Mat (cv::Size(MUXER_OUTPUT_WIDTH, MUXER_OUTPUT_HEIGHT), CV_8UC3);
cv::cvtColor (frame, out_mat, cv::COLOR_RGBA2BGR);
cv::imwrite("../../../ddmMP4/face/test2.jpg", frame);
cv::imwrite("../../../ddmMP4/face/test.jpg", out_mat);
NvBufSurfaceUnMap(surface, -1, -1);
gst_buffer_unmap (buf, &map);
For saving a whole frame to a JPEG file, please refer to this patch:
RTSP camera access frame issue - #19 by DaneLLL
solved. Thankyou!
