Hardware: Jetson Xavier NX
Software: DeepStream-App (6.1)
How to save images after tracking plug-ins;
The current format is:
First case:1920-1080-1920-NVBUF_COLOR_FORMAT_NV12_709_ER
Second case:1920-1080-2048-NVBUF_COLOR_FORMAT_NV12
zm@ubuntu:~$ deepstream-app --version-all
deepstream-app version 6.1.0
DeepStreamSDK 6.1.0
CUDA Driver Version: 11.4
CUDA Runtime Version: 11.4
TensorRT Version: 8.4
cuDNN Version: 8.3
libNVWarp360 Version: 2.0.1d3
#if 1 //Jetson Plan A
NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ_WRITE);
// NvBufSurfaceSyncForCpu(surface, -1, -1);
// NvBufSurfaceSyncForDevice(surface, -1, -1);
memcpy(src_data, (char *)surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0], surface->surfaceList[frame_meta->batch_id].dataSize);
NvBufSurfaceUnMap(surface, -1, -1);
#else //Jetson Plan B
NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ);
// NvBufSurfaceSyncForCpu(surface, frame_meta->batch_id, -1);
// NvBufSurfaceSyncForDevice (surface, -1, -1);
NvBufSurfacePlaneParams *pParams = &surface->surfaceList[frame_meta->batch_id].planeParams;
unsigned int offset = 0;
for (unsigned int num_planes = 0; num_planes < pParams->num_planes; num_planes++)
if (num_planes > 0)
offset += pParams->height[num_planes - 1] * (pParams->bytesPerPix[num_planes - 1] * pParams->width[num_planes - 1]);
for (unsigned int h = 0; h < pParams->height[num_planes]; h++)
memcpy((void *)(src_data + offset + h * pParams->bytesPerPix[num_planes] * pParams->width[num_planes]),
(void *)((char *)surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[num_planes] + h * pParams->pitch[num_planes]),
pParams->bytesPerPix[num_planes] * pParams->width[num_planes]);
g_print("LINE:%d Size:%d-%d\n", __LINE__, pParams->bytesPerPix[num_planes] * pParams->width[num_planes], pParams->height[num_planes]);
#endif
#else //dGPU Plan C
cudaMemcpy((void *)src_data,
(void *)surface->surfaceList[frame_meta->batch_id].dataPtr,
surface->surfaceList[frame_meta->batch_id].dataSize,
cudaMemcpyDeviceToHost);
#endif
I couldn’t get a valid image with any of the above combinations.
I can obtain the following pictures through plan A:
