I know this question has been posted multiple times however I’ve seemed to run into a different issue.
My application requires a snapshot at a certain time interval, I’m able to save frames as a jpeg but it gets saved as a grayscale image instead of rgb. This is roughly my save snapshot method. Is it an opencv error on my part or am I missing something? Thanks in advance.
void saveSnapshot() {
GstBuffer *inbuf = GST_PAD_PROBE_INFO_BUFFER(info);
GstMapInfo in_map_info;
NvBufSurface *surface = NULL;
memset(&in_map_info, 0, sizeof(in_map_info));
if (!gst_buffer_map(inbuf, &in_map_info, GST_MAP_READ)) {
g_error("Error: Failed to map gst buffer\n");
gst_buffer_unmap (inbuf, &in_map_info);
return;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (inbuf);
NvDsMetaList *l_frame = nullptr;
surface = (NvBufSurface*) in_map_info.data;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
int queue_number = frame_meta->pad_index;
if (surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0] == NULL) {
if (NvBufSurfaceMap(surface, frame_meta->batch_id, 0, NVBUF_MAP_READ_WRITE) != 0) {
g_error("Buffer map to be accessed by CPU failed\n");
/* Cache the mapped data for CPU access */
NvBufSurfaceColorFormat color_format = surface->surfaceList[frame_meta->batch_id].colorFormat;
if (color_format == NVBUF_COLOR_FORMAT_NV12) {
LOG(INFO) << "Color format is nv12";
NvBufSurfaceSyncForCpu(surface, frame_meta->batch_id, 0);
cv::Mat in_mat = cv::Mat(surface->surfaceList[frame_meta->batch_id].planeParams.height[0],
surface->surfaceList[frame_meta->batch_id].planeParams.width[0],
CV_8UC4,
surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0],
surface->surfaceList[frame_meta->batch_id].planeParams.pitch[0]);
cv::Mat bgr_frame = cv::Mat(cv::Size(surface->surfaceList[frame_meta->batch_id].planeParams.height[0], surface->surfaceList[frame_meta->batch_id].planeParams.width[0]), CV_8UC3);
cv::cvtColor(in_mat, bgr_frame, cv::COLOR_RGBA2BGR);
std::string file_name = “test" + ".jpg";
cv::imwrite(file_name, bgr_frame);
gst_buffer_unmap(inbuf, &in_map_info);
• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 6.0.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 470.63
